Hello everbody,
thank you very much for your comprehensive answers and letting me know that the issue is caused by an EOL fact.
So i changed to the recommended builds, but unfortunately it seems that none of it is bootable, or useable, neither Xenial, nor jessie, not even the newest bionic.
Is there some sort of general problem that makes those builds unbootlable?
Jessie
Xenial
On 7/14/2018 at 12:07 PM, Igor said:
for
Your first screenshot shows "fs_devread read error" followed by "File not found" ...
This means that your image on SDCard was badly written !
Make sure you use Etcher to write images and don't use crappy sdcards ...
I think U-boot 2018.07 RC1 was never used on stable/supported builds. This is automated nightly or user built ...
Using etcher 1.4.4, also tried win32diskimager and SD card is a Samsung Evo Plus
Tried again all the Images from Ubuntu and Debian, still no success
Regarding the automated nightly or user built, i took that picture off a freshly installed image, havent switched the kernel, or the built to nightly, since it was never starting in the first place
Double checked all the Images with another SD card (SanDisk), still no success
anybody an idea?
also the xenial image isn´t booting up ethernet and showes the call trace message
1 hour ago, Vin said:
anybody an idea?
Problems with a network are known on this board. Sometimes helps to switch to 100Mb port or using other cables ... make sure you read all text at the download page.
a similar problem on orange pi win plus.
1G does not work with mikrotik hap ac. only 100.
I thought my device broken ))
Now it is clear. Thanks.
p.s. fs_devread  i has too ))
C'mon. You're using a nightly built! These are unsupported for a reason. Period.
You show a screenshot with u-boot 2018.07 so requirement is an image built after June 2018 while all our stable images are from January or earlier: https://dl.armbian.com/pine64/archive/
Start over from scratch this time reading, understanding and following our documentation: https://docs.armbian.com/User-Guide_Getting-Started/
Nope. Igor mentioned problems that affected a few batches of Pine64 that are related to the Gigabit Ethernet PHY on the board and require to set some undocumented bits adjusting registers in the PHY. How should another A64 board be affected by that?
Assumed there was a hardwareproblem with the Pine64 board and decided to buy a newer Rock64, having similar problems with the provided stable  images, doesnt seem to boot up, also bought a new SD Card.
