Marco-Omniabit Posted August 2, 2018 Posted August 2, 2018 Hello, I installed Armbian on Nanopi M1 Plus. I used it for a couple of days but now I encountered a problem: the boot stops after the following writing appears: "started hostname service" I tried to wait several minutes but nothing happens anymore Best regards Marco UPDATE: The problem occurs when the device is powered only by the Debug UART, probably the pc usb is not enough to power it
Igor Posted August 3, 2018 Posted August 3, 2018 19 hours ago, Marco-Omniabit said: probably the pc usb is not enough to power it Not probably, but for sure -> https://forum.armbian.com/forum/31-sd-card-and-power-supply/
