Baos Posted March 7, 2016 Posted March 7, 2016 For /etc/update-motd.d/30-sysinfo I noticed it likes to say my system is up 6 seconds and then when I check with uptime I notice it's wrong and has been up for hours or over a day. Just curious if there is a reason for not doing it in a way similar to this? function displaytime { # we need dedicated function local X=$(/usr/bin/uptime -p) printf "Up time: " printf "\x1B[92m%s\x1B[0m\t\t" "$X" } 2
Igor Posted March 7, 2016 Posted March 7, 2016 We need Wheezy - Jessie - Trusty - generic solution that's why I tried to do this workaround. Your proposed solution is failing in Wheezy. Thanks for reporting - I haven't notice that it's broken.
vlad Posted March 7, 2016 Posted March 7, 2016 i have experienced something similar after posting my dynamic motd update, and it look pretty similar to what @baos is describing. From my understanding the files from /etc/update-motd.d/* are executed by the PAM-API on successful login, other information i found on the ubuntu wiki suggest that the motd is actually updated via crontab - but i couldn't find any information regarding this in the armbian implementation so the information i found must be outdated Given the information above i think the the PAM updates the motd on every successful login but it actually reads the motd (/etc/motd) from the previous successful login - this is easy to check just login twice and see if the uptime is reported correct for my setup i made some changes to the pam.d files and its reports correctly - i will post them as soon as i have access to my box.
Baos Posted March 7, 2016 Author Posted March 7, 2016 Thanks Igor. I figured as much. I will try and work with the code, also taking into account vlad's analysis. Will post results. Oh, and fyi, my proposed solution also fell victim to the same bug today. The bug can be confirmed by having the motd output the current time. 1
tkaiser Posted March 7, 2016 Posted March 7, 2016 As long as we're talking about shell scripts a simple date >>/tmp/wtf.txt uptime >>/tmp/wtf.txt set +x exec 2>>/tmp/wtf.txt in the script's header should help improve analysis a bit.
vlad Posted March 7, 2016 Posted March 7, 2016 ok so on a quick search looks like there are some discrepancies on what the pam_motd is supposed to do and what it actually does https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=743286 https://bugs.launchpad.net/ubuntu/+source/shadow/+bug/1169558 http://unix.stackexchange.com/questions/246436/how-to-set-a-dynamic-message-of-the-day-motd-in-debian-jessie-8-2-for-ssh anyway this is how i fixed the problem on my armbian first edit the /etc/pam.d/login and /etc/pam.d/sshd and comment this line (in both files) session optional pam_motd.so motd=/run/motd.dynamic noupdate and create a link from /run/motd.dynamic to /etc/motd/ ln -s /run/motd.dynamic /etc/motd reopen your session and the motd should be updated every time on login 1
Vishnu Das Posted April 28, 2016 Posted April 28, 2016 We need Wheezy - Jessie - Trusty - generic solution that's why I tried to do this workaround. Your proposed solution is failing in Wheezy. Thanks for reporting - I haven't notice that it's broken. Hi, I am using Armbian 5.04 (Debian Jessy build) on my Banana Pi board. So far everything is working great. There's just one thing that bothers me, whenever I ssh into my Banana Pi, the welcome screen always greets me with the banner "Banana Pro" instead of actually showing "Banana Pi". Is this an intentional behavior or does the OS is detecting my board wrongly ?
sooperior Posted April 29, 2016 Posted April 29, 2016 There is nothing wrong, Banana Pi and Pro share the same image (even if they have different hardware). If you are very pissed you can edit /etc(update-mot.d/10-header and look for a line toilet -f standard -F metal $(cat /var/run/machine.id) and change it to toilet -f standard -F metal "Banana" or, as I did, comment out the line and save space #toilet -f standard -F metal $(cat /var/run/machine.id)
Vishnu Das Posted April 29, 2016 Posted April 29, 2016 There is nothing wrong, Banana Pi and Pro share the same image (even if they have different hardware). If you are very pissed you can edit /etc(update-mot.d/10-header and look for a line toilet -f standard -F metal $(cat /var/run/machine.id) and change it to toilet -f standard -F metal "Banana" or, as I did, comment out the line and save space #toilet -f standard -F metal $(cat /var/run/machine.id) Thanks, it worked. I am facing another issue regarding audio playback using the vanilla kernel. There is no sound via the analog audio jack. aplay -l does show my playback device though. Should I need to configure something ?
sooperior Posted April 30, 2016 Posted April 30, 2016 Do you have...? Alsa installed Analog jack selected as output device (by default can be hdmi) Device unmuted in alsa (some time it is muted by default) Kindly note that if you ask for something totally different than the title, you should open a new post. That will be useful for other users with the same problem
