Cubietruck SD-card or power supply or whatever - need some troubleshooting advice
AlbertB
42 minutes ago, AlbertB said:
Linux alarm 4.18.5
This is exactly my first recommendation. Check our DEV, which is 4.18.5 ... 4.14.y has some issues which we are trying to find and fix.
But if you give me the commands
I have no idea how this system was put together. We support Armbian, not hardware. The serial console costs 2USD and would save us a lot of time.
3 minutes ago, AlbertB said:
Regarding the serial console adaptor: can you recommend my anything or will such a thing form ebay do the job just fine?
Probably. I am using  those from:
https://www.ebay.de/itm/6Pin-USB-2-0-to-TTL-UART-Module-Serial-Converter-CP2102-STC-Replace-Ft232-Module-/401092508083
Also, this seller is trustworthy.
5 minutes ago, AlbertB said:
The cubietruck froze during
It froze for me once ... then when I tried to catch some info ... I made an extensive stress test, compiling a kernel and installing various things all at once ... it didn't want to freeze again in 24h. Strange.
