the boot with bionic-minimal-rock64-0.7.9-1067-arm64.img.xz ( it stop at the end )
DDR version 1.10 20171106
In
DDR3
333MHz
Bus Width=32 Col=11 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=2048MB
ddrconfig:2
OUT
Boot1 Release Time: 2017-06-12, version: 2.44
ChipType = 0x11, 171
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7456MB
FwPartOffset=2000 , 2000
SdmmcInit=0 0
BootCapSize=0
UserCapSize=15193MB
FwPartOffset=2000 , 0
StorageInit ok = 226015
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
LoadTrustBL
LoadTrustBL error:-1
Raw SecureMode = 0
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x59ba4
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):0ac3e1a
NOTICE:  BL31: Built : 09:14:58, Nov 15 2017
NOTICE:  BL31:Rockchip release version: v1.3
INFO:    ARM GICv2 driver initialized
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 1
INFO:    plat_rockchip_pmu_init: pd status 0xe
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-126-g2a74125 #46        Thu Dec 14 08:21:08 UTC 2017 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.4
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.02-RK3328-06-02632-g6d55d18 (Jan 24 2018 - 14:26:32)
CPU: rk3328
cpu version = 1
CPU's clock information:
    arm pll = 600000000HZ
    general pll = 491519999HZ
    ddr pll = 664000000HZ
    codec pll = 1200000000HZ
    new pll = 594000000HZ
Board:  Rockchip platform Board
Uboot as second level loader
DRAM:  Found dram banks: 1
Adding bank:0000000000200000(000000007fe00000)
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01e00000
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 0
SDCard Update.
storage init OK!
Using default environment
GetParam
W: Invalid Parameter's tag (0x00000000)!
Invalid parameter
remotectl v0.1
pwm freq=0x23c346
pwm_freq_nstime=0x1aa
No pmic detect.
    arm pll = 1200000000HZ
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 0000-00-00#0.00
empty serial no.
Writing env to storage...
done
normal boot.
no fuel gauge found
no fuel gauge found
read logo on state from dts [0]
no fuel gauge found
'recovery' does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
'backup' does not seem to be a partition nor an address
Unable to boot:backup
try to start rockusb
Edited by Tido
added Spoiler with Code box
@martos
will you please make use of the function: Spoiler and Code.  Your posts are kilometers long, for this the forum software offers tools named before.  Thank you
Thank you Mr. Balbes, for the update to manually change the Device tree.  Now, my crappy Rockshit box (SCISHION AI ONE Android 8.1 TV Box - SILVER US PLUG) has an OS To look forward to.  I tested ALL of the device trees included in your firmware, and finally found ONE that worked reasonably well (rk3328-evb.dtb).   Some of the device trees would NOT boot at all, most would scroll, but not completely install.
Now the work begins, I am using it on a 65" 4k TV, so the fonts are soooooo tiny, I can't read them unless I am 3 feet from the screen.  I will be digging to see if I can find a solution, unless some one on here can tell me how, in layman's terms...
This is the firmware that I used  >>>  Armbian_5.59_Rk3328-tv_Ubuntu_xenial_default_4.4.152_desktop_20180831.img.xz   <<<
Thanks.
Edit:  After trying to set everything up, I noticed that this Rockshit device is pathetically slow, compared to one of my older Amlogic S905 boxes.  Not sure why it is so slow, more testing then, I will give up this box.
One last thing, since you had a correct device tree for this box, I will see if it will work on LIbreELEC or CoreELEC.
13 hours ago, martos said:
boot xenial-minimal-rock64-0.5.15-136-arm64.img
I see a lot of interesting things here ....
Try to erase the bootloader from the SD card with version 5.59, with the command "dd if=/dev/zero of=you_device bs=1 count=400" and try to start the system using a regular u-boot. This may not work because u-boot android may have different settings.
By default, the maximum available screen resolution is turned on (you probably have 3080 x 2160 for 4K), try to enable lower resolution in the screen settings , for example 1920x1080. At the same time minimal screen settings it speeds up the system. By the way, I think the launch Libreelec possible, it is necessary, by analogy with Armbian, if collect the generic version.
I built a new version of the 20180903 image without including u-boot. This option should try to use a regular u-boot (for those who have a problem with determining the type of memory).
Does anyone have any information what sources are used to build u-boot in Android firmware ? Or it is possible to obtain the output of the command "printenv" and "help" from the console UART in u-boot Android.
For my version the boot delay it's put at 0, so i can't stop it.
I try CTRL+C to stop the u-boot but nothing, if you can find an option to stop it i can try.
If you try to use the "space" or "Enter" keys ? Can you show the entire Android startup log ?
Yes ( i try all the keys) but the boot delay is at 0 so don't stop and i read with google :
"It is possible to configure u-Boot at build time so that it will ignore
any character from the console and always do autoboot. a u-Boot
configured in this way is used, for instance, for secure boot."
Show command output on PC "fdisk -l" to SD card with the image xenial-minimal-rock64-0.5.15-136-arm64.img
Have you tried to move the boot loader from SD card xenial-minimal-rock64-0.5.15-136-arm64 to SD card with Armbian 5.59 ?
The update  image 20180904.
Added a utility to full backup and restore the entire eMMC "ddbr". Checked mode the backup MVR9. Now if you try to check the recovery mode.
I tried to run Armbian on MVR9 with different dtb files. The test system runs with almost all options rk3328*. When using the (rk3328-evb.dtb) option, the system is very slow. The dtb at a different part of the iron does not work (this is understandable). Therefore, those who try to start the system on their TV boxes, I recommend manually check all options dtb (copy in turn to the root FAT and rename to "dtb.img " all options rk3328*). Perhaps you will find one that will work better than others.
During the test I found out (for myself) that on MVR9 the boot block from eMMC is started first and then it tries to start the secondary boot loader either from SD card or, if it does not find it there, from eMMC (on other TV boxes it is possible it is differently). On V88, I see the same algorithm. So there is a chance to use a universal image and only change the secondary loader to run on different models of TV boxes.
New version of the image 20180809.
Changes.
Added the function to install the system in eMMC. Pay attention, this option is available ONLY for TV models Boxing MVR9 and compatible models. If you try to install the system in eMMC for non-supported systems, you will get a brick.
The order of installation in eMMC.
1. Download, unzip and burn the image to SD card.
2. Start Armbian on the TV box and perform the initial setup of the system.
3. If the system works correctly and you are satisfied, run the utility "ddbr" and create a full backup of eMMC (this is a prerequisite).
4. Rename the file "/boot/mvr9-uboot.img" in "/boot/uboot.img".
5. Run as user "root" script "/boot/create-mbr-linux.sh"
6. To run the script "/root/install.sh"
Pay attention to the correct operation of the installation procedure need to comply strictly with the order of the steps.
Added another version of the image 20180909.
On the model MVR9 image Xenial-desktop earned WiFi (maybe will work BT, I haven't checked). To use this version, you must manually add the correct DTB. For MVR9 model you need to copy the file " /dtb/rockchip/rk3328-box-trn9.dtb" in the root of the FAT partition and rename to "dtb.img"
Have you checked reaction to u-boot replacement ? I've put together some new u-boot options for different Board models. It will be interesting to check their behavior, whether the system will be able to start with them.
I have my V88 Piano box booting using the 09092018 image but I'm trying to get wifi working.  How can I tell if the onboard wifi is being recognized?  Is there something I can look for in dmesg?  I'm not seeing anything in network setting that would tell me there is a wifi device configured.
You can see the output of "ip a"
45 minutes ago, mmss said:
I would like to buy a new box, is rk3328 faster than the s912?
Sorry, I didn't understand your question.
In cpu only s912 la more powerfull only rk3399 have more cpu power. But rockchip give more information than  amlogic to opensource ...
2 hours ago, balbes150 said:
 IMHO I would compare rk3328 to s905x2\d2.
Ref: https://www.cnx-software.com/2017/11/27/amlogic-s905x-vs-rockchip-rk3328-vs-allwinner-h6/
CPU wise roughly: RK3399 > Amlogic S912 > Allwinner H6 > Amlogic S905X = RK3328
On the other hand, there are very few H6 based TV Box and majority of them are based on S912/S905W and RK3328. Some of the RK3328 based boxes have the advantages of higher memory and storage) (4GB/64G) compared to S912 based (usually 3GB/32GB) and S905W based (usually 2GB/16GB). I like my recently bought X96 Mini but I also ordered Rock64 and RK3328 based box (H96 Max 4GB/64GB) and S912 based box (H96 Pro Plus 3GB/32GB) to play with Android and follow the Armbian development here. The RK3328 based TV box is actually more expensive than S912 based because of the higher memory/storage.
