  On 3/4/2019 at 2:03 PM, FRANK333 said:
still have the same problem?
Expand
 Yeah, It can't works at all.
[    0.000000]   Normal zone: 1152 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 131072 pages, LIFO batch:31
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
[    2.876113] [TTM] Zone  kernel: Available graphics memory: 252532 kiB
[    6.055402] random: fast init done
[    6.761472] systemd[1]: Set hostname to <opione2>.
[    8.603638] gpio-20 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    8.825062] thermal thermal_zone0: failed to read out thermal zone (-110)
[   10.501758] random: crng init done
[   57.867241] w1_master_driver w1_bus_master1: Attaching one wire slave 00.800000000000 crc 8c
[  116.503399] w1_master_driver w1_bus_master1: Attaching one wire slave 00.400000000000 crc 46
[  163.347210] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c00000000000 crc ca
  On 3/4/2019 at 1:59 PM, mantouboji said:
I use the same hardware configuration for a long time , running very well under kernel 3.x
Expand
I also had problems working, I reloaded armbian with the new kernel, connected sensor and resistance (checking that the circuit is correct) and works continuously for months.
Read my previous posts and connect everything as I did I must work! (from what you posted seems just the sensor that is mounted badly)
I'm sorry if I insist.:)
Expand
In /boot/armbianEnv.txt, along with adding w1-gpio to overlays, did you provided W1 parameters, param_w1_pin and param_w1_pin_int_pullup ?
Are you sure you have the proper pin ?
I'm about to start tinkering with a DS18B20 clone on an Orange Pi Zero running Armbian buster with Linux 5.4.31-sunxi.
I will re-read the whole thread to avoid any obvious mistake.
@gounthar
how i did it with my OPZero:
Enable w1-gpio
add
param_w1_pin=PA10
to armbianEnv.txt
and connect your DS18B20 like these..
| OPi Zero GPIO Pin      |  18B20  | Widerstand  |
|Pin 17 3.3V   | braun   |   VCC   |-|4,7kOhm|-¬ |
|Pin 26 1-wire | blau 	 |   Data  |------------ |
|Pin 9  GND    | schwarz |   GND   |			 |
Its working fine :-)
[   11.862342] Driver for 1-wire Dallas network protocol.
[   11.881792] gpio-10 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[   11.914947] w1_master_driver w1_bus_master1: Attaching one wire slave 28.3c01a8160ce7 crc a8
It looks like it has been detected. I now have to find where the information is stored.
I may have found it:
cat /sys/devices/w1_bus_master1/28-3c01a8160ce7/hwmon/hwmon0/temp1_input
23437
Thanks a lot!
@gounthar
i do this:
root@zero-bk:~# cd /sys/bus/w1/devices
root@zero-bk:/sys/bus/w1/devices# ls -l
insgesamt 0
lrwxrwxrwx 1 root root 0 Apr 21 14:09 28-02161f5ca2ee -> ../../../devices/w1_bus_master1/28-02161f5ca2ee
lrwxrwxrwx 1 root root 0 Apr 21 18:45 w1_bus_master1 -> ../../../devices/w1_bus_master1
root@zero-bk:/sys/bus/w1/devices# cat /sys/devices/w1_bus_master1/28-02161f5ca2ee/w1_slave
51 01 4b 46 7f ff 0c 10 ab : crc=ab YES
51 01 4b 46 7f ff 0c 10 ab t=21062
Thanks. I don't know yet what this output means, but I'll find out.
Anyway, I tried to install RPi-Monitor, but it looks like something failed along the path:
sudo armbianmonitor -r
Installing RPi-Monitor. This can take up to 5 minutes. Be patient pleaseE: Unable to locate package rpimonitor
/usr/bin/armbianmonitor: line 697: /usr/share/rpimonitor/scripts/updatePackagesStatus.pl: No such file or directory
Now patching RPi-Monitor to deal correctly with H3
Now you're able to enjoy RPi-Monitor at http://192.168.0.21:8888
poddingue@orangepizero-ups:/sys/bus/w1/devices$ wget http://192.168.0.21:8888
--2020-04-21 21:55:21--  http://192.168.0.21:8888/
Connecting to 192.168.0.21:8888... failed: Connection refused.
gounthar ,
If you intend to use rpi-monitor to control the temperatures of the sensors I recommend you to leave it alone, I use domoticz works well and it's simple, if you need more info open a new post.
