FRANK333 Posted January 21, 2019 Posted January 21, 2019 martin, I wrote this, because I think that mantouboji has connected badly the sensor.
Guest Posted March 4, 2019 Posted March 4, 2019 I use the same hardware configuration for a long time , running very well under kernel 3.x
FRANK333 Posted March 4, 2019 Posted March 4, 2019 4 minutes ago, mantouboji said: I use the same hardware configuration for a long time , running very well under kernel 3.x still have the same problem?
Guest Posted March 4, 2019 Posted March 4, 2019 3 minutes ago, FRANK333 said: still have the same problem? Yeah, It can't works at all. [ 0.000000] Normal zone: 1152 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 131072 pages, LIFO batch:31 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920 [ 2.876113] [TTM] Zone kernel: Available graphics memory: 252532 kiB [ 6.055402] random: fast init done [ 6.761472] systemd[1]: Set hostname to <opione2>. [ 8.603638] gpio-20 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file [ 8.825062] thermal thermal_zone0: failed to read out thermal zone (-110) [ 10.501758] random: crng init done [ 57.867241] w1_master_driver w1_bus_master1: Attaching one wire slave 00.800000000000 crc 8c [ 116.503399] w1_master_driver w1_bus_master1: Attaching one wire slave 00.400000000000 crc 46 [ 163.347210] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c00000000000 crc ca
FRANK333 Posted March 4, 2019 Posted March 4, 2019 22 minutes ago, mantouboji said: I use the same hardware configuration for a long time , running very well under kernel 3.x I also had problems working, I reloaded armbian with the new kernel, connected sensor and resistance (checking that the circuit is correct) and works continuously for months. Read my previous posts and connect everything as I did I must work! (from what you posted seems just the sensor that is mounted badly) I'm sorry if I insist.
martinayotte Posted March 4, 2019 Posted March 4, 2019 11 minutes ago, mantouboji said: Yeah, It can't works at all. In /boot/armbianEnv.txt, along with adding w1-gpio to overlays, did you provided W1 parameters, param_w1_pin and param_w1_pin_int_pullup ? Are you sure you have the proper pin ?
gounthar Posted April 21, 2020 Posted April 21, 2020 I'm about to start tinkering with a DS18B20 clone on an Orange Pi Zero running Armbian buster with Linux 5.4.31-sunxi. I will re-read the whole thread to avoid any obvious mistake.
FRANK333 Posted April 21, 2020 Posted April 21, 2020 gounthar, activate 1wire, edit armbianEnv.txt, connect the sensor (with pull-up resistor) to the pi pins correctly, and it will work everything 1
MacBreaker Posted April 21, 2020 Posted April 21, 2020 @gounthar how i did it with my OPZero: Enable w1-gpio add param_w1_pin=PA10 to armbianEnv.txt and connect your DS18B20 like these.. +------------------------------------------------+ | OPi Zero GPIO Pin | 18B20 | Widerstand | |------------------------|---------|-------------| |Pin 17 3.3V | braun | VCC |-|4,7kOhm|-¬ | |Pin 26 1-wire | blau | Data |------------ | |Pin 9 GND | schwarz | GND | | +------------------------------------------------+ Its working fine :-) 1
gounthar Posted April 21, 2020 Posted April 21, 2020 Thanks a lot, folks, that will help me for sure!
gounthar Posted April 21, 2020 Posted April 21, 2020 [ 11.862342] Driver for 1-wire Dallas network protocol. [ 11.881792] gpio-10 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file [ 11.914947] w1_master_driver w1_bus_master1: Attaching one wire slave 28.3c01a8160ce7 crc a8 It looks like it has been detected. I now have to find where the information is stored. I may have found it: cat /sys/devices/w1_bus_master1/28-3c01a8160ce7/hwmon/hwmon0/temp1_input 23437 Thanks a lot!
MacBreaker Posted April 21, 2020 Posted April 21, 2020 @gounthar i do this: root@zero-bk:~# cd /sys/bus/w1/devices root@zero-bk:/sys/bus/w1/devices# ls -l insgesamt 0 lrwxrwxrwx 1 root root 0 Apr 21 14:09 28-02161f5ca2ee -> ../../../devices/w1_bus_master1/28-02161f5ca2ee lrwxrwxrwx 1 root root 0 Apr 21 18:45 w1_bus_master1 -> ../../../devices/w1_bus_master1 root@zero-bk:/sys/bus/w1/devices# cat /sys/devices/w1_bus_master1/28-02161f5ca2ee/w1_slave 51 01 4b 46 7f ff 0c 10 ab : crc=ab YES 51 01 4b 46 7f ff 0c 10 ab t=21062
gounthar Posted April 21, 2020 Posted April 21, 2020 Thanks. I don't know yet what this output means, but I'll find out. Anyway, I tried to install RPi-Monitor, but it looks like something failed along the path: sudo armbianmonitor -r Installing RPi-Monitor. This can take up to 5 minutes. Be patient pleaseE: Unable to locate package rpimonitor /usr/bin/armbianmonitor: line 697: /usr/share/rpimonitor/scripts/updatePackagesStatus.pl: No such file or directory Now patching RPi-Monitor to deal correctly with H3 Now you're able to enjoy RPi-Monitor at http://192.168.0.21:8888 poddingue@orangepizero-ups:/sys/bus/w1/devices$ wget http://192.168.0.21:8888 --2020-04-21 21:55:21-- http://192.168.0.21:8888/ Connecting to 192.168.0.21:8888... failed: Connection refused.
FRANK333 Posted April 21, 2020 Posted April 21, 2020 gounthar , If you intend to use rpi-monitor to control the temperatures of the sensors I recommend you to leave it alone, I use domoticz works well and it's simple, if you need more info open a new post. 1
