eejeel Posted September 14, 2018 Posted September 14, 2018 I'am running the latest Stretch server version on a PiOne (Linux 4.14.65-sunxi). I think that something is going wrong with the logrotate. The rotation is done in /var/log.hdd directory (see also the scripts in /etc/logrotate.d/). But the original file of each is in /var/log directory and is not "cleared" after the rename, because it is not renamed. So, if Zram copies /var/log directory to the /var/log.hdd directory, the original file in /var/log with old logging and included new logging is written to the /var/log.hdd directory. In the next logrotate this growing file is compressed. In this situation/in my case the compressed files contains all the loggings and not only the loggings of the last day or week or month, depending which file is compressed. And the file is still growing and growing. Is my conclusion right or is something wrong in my Stretch installation. In the latest case, I could not find it. Please give me a hint.
dmeey Posted September 20, 2018 Posted September 20, 2018 I have already adressed this issue with a little demonstrations script in this thread: however, nobody answered yet. 1
Markus Rohner-Bührer Posted November 25, 2018 Posted November 25, 2018 Yes, Same problem here. var/log in ZRAM grows and grows. I see no sense in rotating logs on var/log.hdd What would be a feasible solution? Change all cron jobs?
Igor Posted November 25, 2018 Posted November 25, 2018 2 hours ago, Markus Rohner-Bührer said: Yes, Same problem here. var/log in ZRAM grows and grows. I see no sense in rotating logs on var/log.hdd What would be a feasible solution? Change all cron jobs? It should work this way: https://github.com/armbian/build/blob/master/packages/bsp/common/usr/lib/armbian/armbian-truncate-logs # write to SD /usr/lib/armbian/armbian-ramlog write >/dev/null 2>&1 # rotate logs on "disk" chown root.root -R /var/log.hdd /usr/sbin/logrotate --force /etc/logrotate.conf # truncate /usr/bin/find /var/log -name '*.log' -or -name '*.xz' -or -name 'lastlog' -or -name 'messages' -or -name 'debug' -or -name 'syslog' | xargs truncate --size 0 /usr/bin/find /var/log -name 'btmp' -or -name 'wtmp' -or -name 'faillog' | xargs truncate --size 0 # remove /usr/bin/find /var/log -name '*.[0-9]' -or -name '*.gz' | xargs rm >/dev/null 2>&1 triggered by cron job: */15 * * * * root /usr/lib/armbian/armbian-truncate-logs Where is the problem?
DoubleHP Posted December 21, 2018 Posted December 21, 2018 Previous time I asked where to report bugs: New bug: It's an old bug, met by many people, already reported and fixed by several distros, but, I still had it on a fresh new install: The problem and the fix: https://www.raspberrypi.org/forums/viewtopic.php?f=82&t=218609&p=1406567#p1406567 known bugs: https://bugs.launchpad.net/ubuntu/+source/watchdog/+bug/1448924 https://bugzilla.redhat.com/show_bug.cgi?id=1259816 # systemctl status watchdog.service â watchdog.service - watchdog daemon Loaded: loaded (/lib/systemd/system/watchdog.service; static; vendor preset: enabled) Active: inactive (dead) echo "WantedBy=default.target" >> /lib/systemd/system/watchdog.service systemctl daemon-reload systemctl enable watchdog reboot # wait 2 mn, because it needs to reboot twice. # systemctl status watchdog.service â watchdog.service - watchdog daemon Loaded: loaded (/lib/systemd/system/watchdog.service; enabled; vendor preset: enabled) Active: active (running) since Fri 2018-12-21 03:02:14 CET; 58s ago Process: 1122 ExecStart=/bin/sh -c [ $run_watchdog != 1 ] || exec /usr/sbin/watchdog $watchdog_options (code=exited, status=0/SUCCESS) Process: 1120 ExecStartPre=/bin/sh -c [ -z "${watchdog_module}" ] || [ "${watchdog_module}" = "none" ] || /sbin/modprobe $watchdog_module (code=exited, status=0/SUCCESS) Main PID: 1126 (watchdog) CGroup: /system.slice/watchdog.service ââ1126 /usr/sbin/watchdog Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: int=1s realtime=yes sync=no soft=no mla=5 mem=0 Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: ping: no machine to check Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: file: /var/log/syslog:0 Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: pidfile: no server process to check Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: interface: no interface to check Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: temperature: maximum = 80 Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: temperature: /sys/class/thermal/thermal_zone0/temp Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: test=none(0) repair=none(0) alive=/dev/watchdog heartbeat=none to=...ce=no Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: watchdog now set to 10 seconds Dec 21 03:02:14 opi-06-app-c13 watchdog[1126]: hardware watchdog identity: sunxi-wdt Hint: Some lines were ellipsized, use -l to show in full.
Melroy van den Berg Posted May 6, 2019 Posted May 6, 2019 Quote /usr/sbin/logrotate --force /etc/logrotate.conf logrotate_script: 2: logrotate_script: /usr/lib/rsyslog.hdd/rsyslog-rotate: not found error: error running non-shared postrotate script for /var/log.hdd/syslog of '/var/log.hdd/syslog ' logrotate_script: 2: logrotate_script: /usr/lib/rsyslog.hdd/rsyslog-rotate: not found error: error running shared postrotate script for '/var/log.hdd/mail.info /var/log.hdd/mail.warn /var/log.hdd/mail.err /var/log.hdd/mail.log /var/log.hdd/daemon.log /var/log.hdd/kern.log /var/log.hdd/auth.log /var/log.hdd/user.log /var/log.hdd/lpr.log /var/log.hdd/cron.log /var/log.hdd/debug /var/log.hdd/messages
Igor Posted May 8, 2019 Posted May 8, 2019 You seems to have some old version. Edit /etc/logrotate.d/rsyslog and fix path from /usr/lib/rsyslog.hdd/rsyslog-rotate to /usr/lib/rsyslog/rsyslog-rotate
Sinan Posted March 22, 2020 Posted March 22, 2020 After weeks of searching I finally found out why my /var/log folder fills up and armbian log2ram service can not make the expected housekeeping. /usr/lib/armbian/armbian-truncate-logs script ONLY truncates files in /var/log folder but not its subfolders. I have samba in my case. I have edited the script and added /var/log/samba as another line to be truncated and problem solved.
Igor Posted March 22, 2020 Posted March 22, 2020 4 hours ago, Sinan said: I have solved the problem by manually editing the script. Perhaps submit a fix? https://github.com/armbian/build/tree/master/packages/bsp/common/usr/lib/armbian
Sinan Posted March 22, 2020 Posted March 22, 2020 4 hours ago, Igor said: Perhaps submit a fix? I am not that much experienced but this is what I added to /usr/lib/armbian/armbian-truncate-logs # truncate /usr/bin/find /var/log -name '*.log' -or -name '*.xz' -or -name 'lastlog' -or -name 'messages' -or -name 'debug' -or -name 'sysl$ /usr/bin/find /var/log -name 'btmp' -or -name 'wtmp' -or -name 'faillog' -or -name 'firewalld' | xargs truncate --size 0 >/dev/n$ /usr/bin/find /var/log -name 'mail.err' -or -name 'mail.info' -or -name 'mail.warning' | xargs truncate --size 0 >/dev/null 2>&1 # I have added line below /usr/bin/find /var/log/samba -name '*.log' -or -name 'log.*' | xargs truncate --size 0 >/dev/null 2>&1
Mark4Arm Posted November 22, 2021 Posted November 22, 2021 Hi Igor, all, I had issues with the 'remove' line matching on psad's logging of bad IP addresses as folders matching the bad IP address in /var/log/psad The quick fix for me was to add '-type f' to the find commands in /usr/lib/armbian/armbian-truncate-logs to filter to just files. The diff is below: Quote --- /usr/lib/armbian/armbian-truncate-logs.orig 2021-11-22 22:24:33.697314625 +0000 +++ /usr/lib/armbian/armbian-truncate-logs 2021-11-22 22:21:47.266662399 +0000 @@ -23,11 +23,11 @@ # rotate logs on "disk" /usr/sbin/logrotate --force /etc/logrotate.conf # truncate - /usr/bin/find /var/log -name '*.log' -or -name '*.xz' -or -name 'lastlog' -or -name 'messages' -or -name 'debug' -or -name 'syslog' | xargs -r truncate --size 0 - /usr/bin/find /var/log -name 'btmp' -or -name 'wtmp' -or -name 'faillog' -or -name 'firewalld' | xargs -r truncate --size 0 - /usr/bin/find /var/log -name 'mail.err' -or -name 'mail.info' -or -name 'mail.warning' | xargs -r truncate --size 0 + /usr/bin/find /var/log -type f -name '*.log' -or -name '*.xz' -or -name 'lastlog' -or -name 'messages' -or -name 'debug' -or -name 'syslog' | xargs -r truncate --size 0 + /usr/bin/find /var/log -type f -name 'btmp' -or -name 'wtmp' -or -name 'faillog' -or -name 'firewalld' | xargs -r truncate --size 0 + /usr/bin/find /var/log -type f -name 'mail.err' -or -name 'mail.info' -or -name 'mail.warning' | xargs -r truncate --size 0 # remove - /usr/bin/find /var/log -name '*.[0-9]' -or -name '*.gz' | xargs -r rm -f + /usr/bin/find /var/log -type f -name '*.[0-9]' -or -name '*.gz' | xargs -r rm -f # vacuum systemd-journald [ -d /var/log/journal ] && journalctl --vacuum-size=${JOURNAL_SIZE} fi The trivial diff is free for anyone to use (if anyone was worried about licensing). Cheers, Mark
