Benno Eigenmann Posted October 2, 2018 Posted October 2, 2018 @data benno@orangepilite2:/etc/NetworkManager$ cat NetworkManager.conf [main] dns=default rc-manager=file plugins=ifupdown,keyfile [ifupdown] managed=true [device] wifi.scan-rand-mac-address=no
data Posted October 2, 2018 Posted October 2, 2018 Wrong file. Please do 'cat /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf'
Benno Eigenmann Posted October 2, 2018 Posted October 2, 2018 cat default-wifi-powersave-on.conf [connection] wifi.powersave = 3
data Posted October 2, 2018 Posted October 2, 2018 3 means powersave enabled. Change that to 2 and reboot. Then check for powersave again
Benno Eigenmann Posted October 2, 2018 Posted October 2, 2018 OK Looks more pleasing benno@orangepilite2:~$ iwconfig wlan0 IEEE 802.11 ESSID:"OpenWrt_5" Mode:Managed Frequency:5.22 GHz Access Point: 14:CC:20:F1:6D:48 Bit Rate=433.3 Mb/s Tx-Power=31 dBm Retry short limit:7 RTS thr:off Fragment thr:off Power Management:off Link Quality=46/70 Signal level=-64 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0 lo no wireless extensions. https://github.com/armbian/build/commit/40e5ce955b39e689a35c05016cbdfcaba5d5f26c
Igor Posted October 2, 2018 Posted October 2, 2018 Ooops. I added wrong number. Will be corrected asap.Wrote on mobile
junnikokuki Posted October 2, 2018 Author Posted October 2, 2018 7 hours ago, Igor said: Ooops. I added wrong number. Will be corrected asap. Wrote on mobile Your 40e5ce955b39e689a35c05016cbdfcaba5d5f26c commit on wifi power save has an issue, cause the networkmanager can not start. echo -e "[connection]\nwifi.powersave = 3" > /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf this will leave a -e on begining of the file before [connection].
Igor Posted October 2, 2018 Posted October 2, 2018 30 minutes ago, junnikokuki said: Your 40e5ce955b39e689a35c05016cbdfcaba5d5f26c commit on wifi power save has an issue, cause the networkmanager can not start. echo -e "[connection]\nwifi.powersave = 3" > /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf this will leave a -e on begining of the file before [connection]. Thank you. Fided among this cleanup https://github.com/armbian/build/commit/fd235d6c3467fb5ab735a638db84481927c299d6
data Posted October 2, 2018 Posted October 2, 2018 Keep in mind that 3 means enabled, 2 is disabled. Use "[connection]\nwifi.powersave = 2" 1
