I take all comments under advisement and go thru each dtb and report back which ones boot :)
Update: No dtb boots. Now when I go back to the working card, lightdm starts in 720p. After logging in can change to 1920x1080. Maybe it is this TV, I'll check with the other TV later.
Expand
It is a feature of the start of the kernel on the N6.
Expand
I see. Next login after setting desktop to 1920x1080, I'm getting a black screen. Desktop only shows up after ctl-alt F1 then back to ctrl-alt F7
Expand
... or you need to wait , or move the mouse ....
Expand
Ok then. Now are there any improvements if I go with the media testing scripts? The current desktop performance is already satisfactory to me.
Expand
Yes, after installing the media script will be available full-screen video 4K.
Expand
After media script turns out that modesetting without accel is the best for my desktop use, which is what I started out with stock. Oh well...
ps. that's weird, with compositing no desktop icons
update: after trying and failing to get the desktop icons back, decided to start from scratch, reimage the sdcard. Think I'll stick with the non-hw assisted desktop for now.
Here are some benchmarks I ran on the TV boxes, baselined against an Intel J3355. Pinch of salt not included.
sysbench cpu --cpu-max-prime=20000 run
Events per sec
s912:    196.90
rk3328: 256.93
s905:    303.61
rk3399:    703.67
j3355:    475.65
sysbench cpu --num-threads=<max cores> --cpu-max-prime=20000 run
s912:    1896.08 /8: 237.01
rk3328:    1013.01 /4: 253.25
rk3399:    2482.69 /6: 413.78
j3355:    784.07  /2: 392.04
rk3399 without redesigning the cooling system ?
See the threads about media script 3399 3328 and there was information about how to configure them to operate the icons on the desktop.
Expand
Yes, running with no extra cooling. Unless htop is lying to me, I've only seen cpu temps in the 80's so far.
Expand
Yes I get the icons back if I turn off compositing but I've grown attached to my drop-shadows and transparency effects :)
Expand
Be sure to redo the cooling system. Your rk3399 is choking and only works on 1\3 of its capabilities. 80 degrees - this is a cutoff (when this temperature is reached, the processor turns on the trottling).
Expand
If I'm not confused, I read that you can enable the composite and it works with other settings.
Expand
I might be wrong, but as I understand it when throttling the cpu frequencies should be limited to a lower level. From the screenshot, that doesn't happen. Am I missing something?
Expand
What I see is
compositing on -> no desktop icons (there are still there but invisible. Clicking on where they should be still works)
compositing off -> icons appear normally
Expand
Implementation of protection can be different. The General principle is to avoid performance degradation, keep the system at a temperature knowingly below the point of limitation. For rk33xx I recommend not to exceed 70 degrees. It is desirable at any loads to have a temperature of not more than 20-30 degrees, relative to the environment. This ensures minimal problems with thermal expansion (metals and PCB have different thermal expansion coefficients). The smaller the temperature difference during operation and shutdown, the less problems with operation.
Something odd going on, with resolution set to 1920x1080, Thunar and a few other apps goes to 1280x720. Any ideas?
Logging out & in clears it up. I suspect the display default is set or detected at 1280x720 but I haven't managed to locate where that setting is at yet.
update: turns out its the custom dpi setting from Settings->Appearance->Fonts that is causing it. Turn it off and everything seems fine.
Expand
Settings->Display
  On 4/27/2019 at 1:49 PM, balbes150 said:
New image Armbian 5.82 and Libreelec 20190427.
Expand
After running the default image for some time, got round to looking at NEXT
NEXT no go for me coz magicsee-n6-max dtb is missing
  On 5/17/2019 at 2:25 PM, balbes150 said:
update kernel
Expand
Understood. Installed 5.86_20190517 on sdcard magicsee-n6-max. Everything works well except bluetooth :thumbup:
NEXT image, no dtb for magicsee :(
Edited by amirul
update
  On 6/13/2019 at 12:24 PM, balbes150 said:
New image Armbian 5.88 and LibreELEC for Khadas EDGE
Expand
magicsee-n6-max disco desktop :thumbup:
NEXT missing magicsee dtb, so untested
Went back to bionic, desktop looks sharper
Edited by amirul
update
Just dicovered with 5.88 desktop unable to ssh into the box. Where can I find the sshd logs?
Ok found it at /var/log/auth.log
There seems to be a series of
Jun 18 02:39:20 localhost agetty[27271]: /dev/ttyS0: not a tty
messages filling up the log
tried systemctl disable getty@ttyS0, doesn't stop it
sshd keys needed regenerating
systemctl disable serial-getty@ttyS0.service
I burnt latest 5.88 image on a sdcard and I was able to boot and log into desktop with my edge-v pro. Nor ethernet neither wifi were working, but otherwise the desktop experience seems good. I hope to have more time this week-end to investigate more.
Armbian_5.89_Rk3399-tv_Ubuntu_bionic_default_4.4.154_desktop_20190627
magicee-n6-max
-> Wifi Networks device not ready
wifi used to work
revert to
Armbian_5.88_Rk3399-tv_Ubuntu_bionic_default_4.4.154_desktop_20190612
same wifi problem. Somehow after updates, wlan was borked. I'll try to fire up the original to see whether wlan is ok
burned original 20190612 to sdcard, wlan still unavailable. Must be a hardware problem then
Expand
The new version 5.89_20190627. It fixes wired networking on EDGE-V v13 models.
magicee-n6-max
wifi used to work
revert to
Expand
Wlan works on Armbian_5.86_Rk3399-tv_Ubuntu_bionic_default_4.4.154_desktop_20190517. What has changed between the versions?
dtbs are identical
lots of lines in dmesg [WLAN_RFKILL]: wifi turn on power. -1
