Can someone help me on how we can set a uBoot splash screen (with a .bmp) instead of the running boot text?
Need this in a OPiPC, legacy (3.4.113).
Any help is welcome.
Christos
Armbian logo should be displayed in uboot by default. At lest on most recent assembly. Image is read from /boot by another patch.
Wrote on mobile
@Igor
Unfortunately, it produced an error, new build, legacy, Xenial desktop/console
[ warn ] * [l][c] remove-boot-messages-from-hdmi.patch [ failed ]
Are you sure it works or am I missing something?
It used to work a year ago ... if it breaks, you will need to dive into the u-boot source code to see why it breaks. Perhaps this can be solved in a minute, perhaps you need hours.
For Armbian, this patch is not relevant, so it is not maintained.
For those that have reached here trying to remove output text from u-boot the old patch no longer works.
The patch below works as of August 2019, however u-boot may change in the future.
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h
--- a/include/configs/sunxi-common.h
+++ b/include/configs/sunxi-common.h
@@ -461,13 +461,13 @@ extern int soft_i2c_gpio_scl;
 #ifdef CONFIG_VIDEO
 #define CONSOLE_STDOUT_SETTINGS \
-	"stdout=serial,vga\0" \
-	"stderr=serial,vga\0"
+	"stdout=serial\0" \
+	"stderr=serial\0"
 #elif CONFIG_DM_VIDEO
 #define CONFIG_SYS_WHITE_ON_BLACK
-	"stdout=serial,vidconsole\0" \
-	"stderr=serial,vidconsole\0"
+	"stderr=serial\0"
 #else
 	"stdout=serial\0" \
As of now following patch works for disabling uboot text
@@ -453,12 +453,12 @@
 #ifdef CONFIG_VIDEO
+	"stderr=serial\0"
+	"stderr=serial\0"
 #else
 	"stdout=serial\0" \
