I have 85 tinkers running with armbian 5.41 xenial next 4.14.23.  Normally I run a script that apt upgrades them all but I run a small batch of them first as a test.  Today I ran apt update/upgrade on three of them and they are all bricked.  No output to the screen.  Can't ping them.  Any ideas?
Expand
We need to see serial console logs.
  On 9/25/2018 at 3:57 PM, freak said:
TTL is ok on those pins?
Expand
Yes, but you don't need to do anything. I already found the cause of the problem. Just do a power cycle.
I did try to replicate and start with some ancient build (older than yours, 5.33) than making an upgrade. It stalled at reboot ... cutting power and powering back resolved the problem and board is alive.
Those are my logs: http://ix.io/1nwv
Serial console log:
  Reveal hidden contents
Now you need to get logs. From our perspective, everything works. Have you perhaps update to Bionic?
  On 9/25/2018 at 4:15 PM, freak said:
Power cycling isn't solving it.
Expand
well then set up serial console.. and provide some bootlog.
I noticed that reboot after update of my tinker from 5.5x (don't remember exactly) to 5.60 took a way longer than normal. Maybe I should stick a serial console to it to get a clue why.. But if I remember correctly I didn't had to power-cycle it..
I don't have the usb/ttl adapter but I'll order one.  In the meantime I don't mind upgrading to bionic.  Can I do it from the command line from the build that I'm at?
Expand
It's an amazing tool for the value :) It can save you a lot of time and money.
Expand
That was more as a rhetorical question. Upgrade to Bionic might cause troubles but if you start with a clean image, you should be fine. That upgrade is out of our power to help you in case of troubles.
  On 9/25/2018 at 5:27 PM, freak said:
Is whatever what was wrong fixed so I can run apt upgrade with bricking the rest of the units?
Expand
No!
We didn't find nor fix any problems. You have to get a serial console and show us what do you see when you power the bricked device. Perhaps the problem is in your configuration which is not our problem. I have no idea without seeing logs.
or... you SSH into a working SBC and use it's spare UART pins to ttl into the non-working SBC... :lol:
Likely to be one of the most silly things I've ever did with an SBC.. But hey, it works... :lol: (at least @martinayotte will like it. :ph34r: :P )
  On 9/25/2018 at 3:49 PM, Igor said:
Pins:
Expand
do we have UART2 and UART3? at least on mine (4.14) we use UART3...  @TonyMac32? Or was it back then when we used UART2? Can't remember anymore.. :P
...and I can re-image the affected boards to fix them.  But for the working ones I'd like to upgrade to bionic if I can do that via the command line.
Expand
This picture was taken on a working UART with kernel 4.14.y
Expand
Do (ask google), but in case of troubles don't cry :) You have been warned.
I'm at work so I can't check, but we should match the vendor, which is the UART at the bottom of the gpio header.
REMEMBER 3.3V I/O
Expand
Expand
mine too.. :P See photo and that's UART3:
Expand
even reboot works with ssh (notebook) --> ttl (OPi0) --> tinkerboard
:lol:
  On 9/25/2018 at 5:44 PM, freak said:
Why "do-release-upgrade -d"?  Isn't there a stable release?
Expand
Google's first hit: https://linuxconfig.org/how-to-upgrade-to-ubuntu-18-04-lts-bionic-beaver
Even Canonical recommends running distribution upgrade (old stable -> stable) from a serial console ... which you don't have. Anyway, we are getting off topic and out of free support for which you need to supply UART data. Now @chwe supplied alternative and working option.
Update:   This may have something to do with the resolution.  These a mostly connected to 1920x1200 HP monitors often with hdmi to dvi cables (sometimes hdmi both ends) but quite often they only run at 1920x1080.  But they work.  This "bricked" unit boots fine when connected to a acer G215H 1920x1080 monitor via hdmi/dvi.  Connected to an HP z27N via straight hdmi it will not boot.
Expand
I was waiting for this. A prove that there is nothing wrong with our work. Thank you!
Armbian does not provide support for 3rd party hardware, which are the root of this problem -> a few people can't provide FREE support for all kind of electronic junk on this planet in their spare time. I hope you do understand this?
Without logs, problems are not even officially recognized. That's why I repeat myself like a parrot. Only logs might tell if we can solve the problem quickly or we will just file it.
Expand
But to be fair... all 85 of my boards were working fine till I ran apt upgrade.
Expand
we don't willingly break hardware support just to upset someone... :lol: If it happens it's likely out of our control.. (e.g. kernel) and it's simply not possible to first: avoid all those possible scenarios of third party hardware and second provide you some help without even knowing what's going wrong.
Expand
means bricked here upgraded power-cycled and then rebooted or with a freshly installed armbian?
Expand
from the changelog:
v5.41 / 10.2.2018
fixed LED driver on Helios4
bugfix update on sunxi/sunxi64 kernel. Updated to 4.14.18
kernel update for MVEBU next (4.14.18 and default 4.4.115) for Clearfog and Helios4. Upstream fixes,AUFS and Realtek 881yAU drivers update
that's 8 months without doing any updates? Have fun to figure out when and which changes ended in 'doesn't work anymore'.  IMO simply not possible.  But
git@tinkerboard:~$ find /dev | grep ttyS
/dev/ttyS3
/dev/ttyS2
/dev/ttyS1
/dev/ttyS0
serial access is possible...
You can even build circles.. :lol:
SSH --> (opi) ttl --> (tinker) ttl --> opi :lol:
with 85 tinkers, there should be one spare to debug one which is 'bricked' due to upgrade... Just connect UART1 to another boards UART3 (that's the one you want to debug) install picocom on the first one and then:
picocom -b 115200 -r -l /dev/ttyS1
  On 9/25/2018 at 6:37 PM, martinayotte said:
:D
Expand
Expand
well.. obviously not true anymore.. :D
