CR_B Posted September 25, 2018 Posted September 25, 2018 Hello, I use armbian latest version on a Orange Pi Zero (256Mb) to send data from usb to network. I use Ser2net for this to stream data from a rflink device. To test I use a Metrix bench power supply, so i think power is ok. If I reboot the device with usb plugged the boot fail, so i have to boot without usb plugged and then plug usb and restart ser2net daemon to make it work. I think boot is searching for usb device, is it possible to disable this ? Next the board crash every 2 or 3 days, network stop responding and soc heatsink goes hot. I restart the device and it's good for 2 or 3 days, and crash... If it help armbianmonitor -u gives : http://ix.io/1nxB If anyone has an idea ?
Igor Posted September 26, 2018 Posted September 26, 2018 9 hours ago, CR_B said: If anyone has an idea ? Try blacklisting wireless (xradio) and set lower max CPU frequency (/etc/default/cpufrequtils). Some revisions of this board have overheating issues ... which are a possible cause for troubles. Quote If I reboot the device with usb plugged the boot fail, so i have to boot without usb plugged and then plug usb and restart ser2net daemon to make it work. Where does it hang?
CR_B Posted September 30, 2018 Author Posted September 30, 2018 I've lowered frequency to 800Mhz (don't need so much power). Can i find where usb hang without screen ?
chwe Posted October 1, 2018 Posted October 1, 2018 13 hours ago, CR_B said: Can i find where usb hang without screen ?
CR_B Posted October 1, 2018 Author Posted October 1, 2018 Thanks chwe, I doesn't know but that useful. That's going to help me to save lot's of time. Is there a guide to disable xradio ?
martinayotte Posted October 1, 2018 Posted October 1, 2018 3 minutes ago, CR_B said: s there a guide to disable xradio ? There are many ways, but the simpliest is to rename kernel driver so it won't be loaded ... Do this search to find out where it is : find /lib/modules/ -name "xradio_wlan.ko" Then rename it as xradio_wlan.ko-ORIG and reboot ...
CR_B Posted October 1, 2018 Author Posted October 1, 2018 Thanks martinayotte, So I've reflashed my sdcard (fs was corrupted after to many reboot i think) I've disable xradio, lowered cpufreq to 600Mhz, installed ser2net and armbian monitor. Boot was succesfull with usb, soc temp is at 29°C (if sensor is accurate ) I just have to wait some days
CR_B Posted October 10, 2018 Author Posted October 10, 2018 The card has crashed yesterday at 17h50 (19h50 for me) I've checked the log :http://ix.io/1oS9 It seems that the card il rebooting the morning at the same hour, the 9 and 10 October. Armbian monitor give me a peek temp of the soc at 37°C so I dont think this is the problem (the attached file) I have a serial to usb to check the card without network, that was crash, I have to disconnect it from the card and the computer in order to make it work again. I've order I new sdcard to check if this is the problem.
