Perier Posted October 1, 2018 Posted October 1, 2018 Hello community! I use in my project "Orange Pi Zero Plus (Alwinner H5 - 512mb)". When using the image downloaded from the official site (https://www.armbian.com/orange-pi-zero-plus/ - Armbian Stretch mainline kernel 4.14.y), I get a set of errors when I boot and when I use the working OS, which I'm straining. The same mistakes I get if I build the kernel and the OS myself through "build" (linux-sunxi64-next). My equipment: Memory: SanDisk Ultra microSDHC Class 10 UHS-I 48MB/s 16GB Power supply: Raspberry Pi 3b+ Power Adapter (STONTRONICS) - 5.1V @ 2.5A Boot: full log - https://pastebin.com/M9g6ipUp Loading Environment from EXT4 ... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0: 1 ** Failed (-5) dmesg: full log - https://pastebin.com/GyeUTQem [0.668711] sun4i-usb-phy 1c19400.phy: Could not request ID GPIO [0.670578] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver [0.674095] sun50i-h5-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [0.680561] NOHZ: local_softirq_pending 80 [0.703353] cacheinfo: Unable to detect cache hierarchy for CPU 0 [0.776991] core: _opp_supported_by_regulators: OPP minuV: 1120000 maxuV: 1300000, not supported by regulator [0.776999] cpu cpu0: _opp_add: OPP not supported by regulators (912000000) [0.777077] core: _opp_supported_by_regulators: OPP minuV: 1160000 maxuV: 1300000, not supported by regulator [0.777084] cpu cpu0: _opp_add: OPP not supported by regulators (960000000) [0.777134] core: _opp_supported_by_regulators: OPP minuV: 1200000 maxuV: 1300000, not supported by regulator [0.777140] cpu cpu0: _opp_add: OPP not supported by regulators (1008000000) [0.777218] core: _opp_supported_by_regulators: OPP minuV: 1240000 maxuV: 1300000, not supported by regulator [0.777224] cpu cpu0: _opp_add: OPP not supported by regulators (1056000000) [0.777274] core: _opp_supported_by_regulators: OPP minuV: 1260000 maxuV: 1300000, not supported by regulator [0.777280] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000) [0.777357] core: _opp_supported_by_regulators: OPP minuV: 1300000 maxuV: 1300000, not supported by regulator [0.777363] cpu cpu0: _opp_add: OPP is not supported by regulators (1152000000) [0.777627] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed: -22 [0.862337] mmc0: host does not support reading read-only switch, assuming write-enable [0.862561] NOHZ: local_softirq_pending 80 [1.265962] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found using dummy regulator [11.340617] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit = 600, errors = remount-ro [11.473725] 29 [11.473733] 81 [11.473738] 03 [11.473740] CC [11.473742] 00 [11.473745] 00 [11.473747] 50 [11.473749] 00 [11.473752] 00 [11.473754] 00 [11.473756] 04 [11.473758] CC [11.473760] 0A [11.473762] 0C [11.473765] 00 [11.473769] 00 [11.473770] FF [11.473772] FF [11.473775] FF ... [11.474899] FF [11.474901] FF [11.474904] FF [11.564425] g_serial gadget: Gadget Serial v2.4 It is difficult for me to estimate how much these errors are critical for stable use of the OS, since I am not an expert in this field. Ready for tight interaction to eliminate these problems, if they are. Thank you for your attention and your answers - any information on this issue will be useful.
chwe Posted October 17, 2018 Posted October 17, 2018 21 hours ago, Evgeny said: up bumping is normally the best way to get a warning... On 10/1/2018 at 11:39 AM, Evgeny said: It is difficult for me to estimate how much these errors are critical for stable use of the OS, that's why h5 is marked testing.. nobody knows.. On 10/1/2018 at 11:39 AM, Evgeny said: [0.862337] mmc0: host does not support reading read-only switch, assuming write-enable nothing to care about... that's normal.. On 10/1/2018 at 11:39 AM, Evgeny said: [0.776991] core: _opp_supported_by_regulators: OPP minuV: 1120000 maxuV: 1300000, not supported by regulator [0.776999] cpu cpu0: _opp_add: OPP not supported by regulators (912000000) [0.777077] core: _opp_supported_by_regulators: OPP minuV: 1160000 maxuV: 1300000, not supported by regulator [0.777084] cpu cpu0: _opp_add: OPP not supported by regulators (960000000) [0.777134] core: _opp_supported_by_regulators: OPP minuV: 1200000 maxuV: 1300000, not supported by regulator [0.777140] cpu cpu0: _opp_add: OPP not supported by regulators (1008000000) [0.777218] core: _opp_supported_by_regulators: OPP minuV: 1240000 maxuV: 1300000, not supported by regulator [0.777224] cpu cpu0: _opp_add: OPP not supported by regulators (1056000000) [0.777274] core: _opp_supported_by_regulators: OPP minuV: 1260000 maxuV: 1300000, not supported by regulator [0.777280] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000) [0.777357] core: _opp_supported_by_regulators: OPP minuV: 1300000 maxuV: 1300000, not supported by regulator [0.777363] cpu cpu0: _opp_add: OPP is not supported by regulators (1152000000) [0.777627] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed: -22 probably related to this one: no idea, I don't follow H5 development close enough.... and a lot of reading might give you a clue what's and how stable things are working on h5 for *random usecase*.. H5 and H6 are in development phase. @Igor I think our download-page here is 'part of the problem'. I suggest that we mark those images as wip not supported. The only kernel we provide is in experimental or at least testing phase.. The exceptions from supported are higher than WIP.. 1
Igor Posted October 18, 2018 Posted October 18, 2018 2 hours ago, chwe said: nobody knows.. Knows, but it is expensive and virtually impossible to answer all questions and explain what those specifics kernel "errors" means. Over and over again. H5/A64 section is deliberately left out from forum support section since at least support remains limited. Mostly because of A64 which is staying behind H5. 14 hours ago, chwe said: The only kernel we provide is in experimental or at least testing phase.. SUPPORTED devices are tested and they work apart from known issues and missing features. Which is true. Known issues info adds an information that there might be unknown issues. WIP goes mainly for boards based on new chips, where we are in the process of knowing things (RK3399) or where we know vital things are broken (A64) and needs longer time to fix. It's complicated. This support is as is. "we" are no obligated to answer on anything.
chwe Posted October 18, 2018 Posted October 18, 2018 If Gozard anyway has a look into the DL page, we may want the Testing flag more obvious. Something like if kernel=testing then second supporting flag color = orange. Which is then in conflict with WIP I know.. For 'us' dealing with support since long time it's obvious It may not be as obvious for a first time visitor.
Igor Posted October 18, 2018 Posted October 18, 2018 1 hour ago, chwe said: If Gozard anyway has a look Add your ideas to the list "Download UX". Then it might not get lost. https://forum.armbian.com/topic/6281-board-support-general-discussion-project-aims/?do=findComment&comment=64049 On 10/1/2018 at 11:39 AM, Evgeny said: It is difficult for me to estimate how much these errors are critical for stable use of the OS, since I am not an expert in this field. Ready for tight interaction to eliminate these problems, if they are. Safe to ignore. They are mostly not even errors. 1
5kft Posted October 18, 2018 Posted October 18, 2018 @Evgeny, +1 to everything that @chwe and @Igor have said above. Some of these messages have been cleaned up since the 4.14.y kernel (e.g., regulator errors), but none of them are significant.
