Hi guys,
today i wanted to access my BPi with armbian installed remote with SSH.  Terminal says: port 22: Connection refused. I'm able to ping the BPi. At least last week I was able to access the BPi with remote SSH.
When i connect it via HDMI i can see the boot process until it says loading kernel - then the screen turns all black and nothing happens anymore.
If I try to access some installed webservices, the browser says it can't connect.
What can I do?
Hi martinayotte,
thank you very much for your answer. I do have a FTDI USB dongle and  a Atmel USPasp - what can i do with this? Do you have a Youtube Link for me?
How do I test the SD card for corruption?
Thanks in advance.
[€]: Or an Arduino if you want.
Edited by BananaGonzo
USPasp is useless but FTDI USB is OK : simply attach GND/TX/RX to BananaPi and open PuTTY at 115200 board, and powerup the BPi, you should see booting log until login prompt ...
Youtube Link
I don't have any, but there are maybe some already ...
if you are able to reach login prompt, log as root and do a "fsck.ext4 /dev/mmcblk0p1"
Hi there,
ok, I'll try it today in the afternoon - thank you so much for your help! I'll give you a quick response until i reached something :-)
Bye
Hi there,
I tried to connect but all I see in the console is like shown in the following picture:
Settings are like in the Wiki:
Baud 115200
Hardwareflowcontroll off
This is what appears right at the beginning of fresh boot ?
It is almost sure that your SDCard is corrupted ...
Try another one with fresh image.
Right.
Ok, maybe.
I installed the freshest Armbian Bionic mainline kernel 4.14.y on a fresh formatted SD - same screen in the console as shown above. Is it just me?
16 hours ago, helper-dialog said:
Can't remote access BananaPi in short = crab, crabs walk sideways, you have to walk forward for it to work
What do you mean?
23 minutes ago, Igor said:
If there was some corruption or unclean first run, do this:
https://www.cyberciti.biz/faq/howto-regenerate-openssh-host-keys/
Thank you Igor - it seems that the service is not running on startup even there is an entry at /etc/init.d :-(
I even tried to set up a cronjob (@reboot).
Doesn't work :-(
This is what its look like after reboot (connected via serial):
root@bpii:~# /etc/init.d/ssh status
● ssh.service - OpenBSD Secure Shell server
   Loaded: loaded (/lib/systemd/system/ssh.service; enabled; vendor preset: enabled)
   Active: inactive (dead)
root@bpii:~#
Ok, seems that when I'm connected via serial it is in emergency mode - I have to shut it down completely (shutdown -h now) disconnect power and FTDI, and connect power again.
Now it works...:thumbup:
