0
vlad59
Failed to connect to dl.armbian.com port 443: Connection refused
I just made a brand new VM to build armbian this morning so after installing Bionic / checking out the sources, I started `compile.sh` for the first time and I got theses warning / errors (15 minutes ago) :
E: Version '1.2.0' for 'aptly' was not found
[ o.k. ] Syncing clock [ host ]
[ .... ] Downloading [ gcc-linaro-arm-linux-gnueabihf-4.8-2014.04_linux ]
-=O=-                                           #     #    #    #
curl: (7) Failed to connect to dl.armbian.com port 443: Connection refused
[ .... ] Verifying
grep: gcc-linaro-arm-linux-gnueabihf-4.8-2014.04_linux.tar.xz.asc: No such file or directory
md5sum: gcc-linaro-arm-linux-gnueabihf-4.8-2014.04_linux.tar.xz.asc: No such file or directory
I just restarted it and it seems to work better (the downloading seems to be working). So no real problem there, just wanted to notify in case it may be important.
Share this post
Link to post
Share on other sites
4 hours ago, sfx2000 said:
On ubuntu 18.04, there was a push for update on aptly...
Build script rolled it back.
Correct, latest version is broken. Perhaps this is fixed now ... it shall be tested.
Share this post
Link to post
0
