# uname -a
Linux H6 4.18.13-sunxi64 #3 SMP Fri Oct 12 17:43:44 CST 2018 aarch64 GNU/Linux
1, burn the image to SD card
2, use nand-sata-install command, burn emmc
3, remove the SD card
4, reboot the board, can't boot, the error message:
U-Boot SPL 2018.09-rc1-armbian (Oct 12 2018 - 17:39:13 +0800)
DRAM: 1024 MiB
Trying to boot from MMC2
MMC Device 1 not found
spl: could not find mmc device. error: -19
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
root@H6:/mnt/emmc# fdisk -l
Disk /dev/mmcblk0: 30 GiB, 32218546176 bytes, 62926848 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x36326db0
Device         Boot Start      End  Sectors  Size Id Type
/dev/mmcblk0p1       8192 62297567 62289376 29.7G 83 Linux
Disk /dev/mmcblk2: 7.3 GiB, 7818182656 bytes, 15269888 sectors
Disklabel type: dos
Disk identifier: 0x7b2f8591
/dev/mmcblk2p1       8192 15117183 15108992  7.2G 83 Linux
mkdir /mnt/emmc
mount /dev/mmcblk2p1 /mnt/emmc
and then I try modify the /mnt/emmc/boot/boot.cmd and /mnt/emmc/boot/boot.scr files,
setenv rootdev "/dev/mmcblk0p1"       change mmcblk0p1 to mmcblk2p1
if test "${devtype}" = "mmc"; then part uuid mmc 0:1 partuuid; fi      change "mmc 0:1" to "mmc 2:1"
and I check the emmc device UUID, is correct.
root@H6:/mnt/emmc/boot# cat armbianEnv.txt
verbosity=1
console=both
overlay_prefix=sun50iw6p1-
rootdev=UUID=178e84b7-40bc-4ebc-922d-9850051c8c00
rootfstype=ext4
user_overlays=network
root@H6:/mnt/emmc/boot# blkid
/dev/mmcblk0p1: UUID="9766d929-82b6-4c2f-90e0-6f422af64df5" TYPE="ext4" PARTUUID="36326db0-01"
/dev/mmcblk2p1: UUID="178e84b7-40bc-4ebc-922d-9850051c8c00" TYPE="ext4" PARTUUID="7b2f8591-01"
/dev/zram0: LABEL="log2ram" UUID="00102ace-f4c5-4d78-af23-3a8b22b9f360" TYPE="ext4"
/dev/zram1: UUID="a4a7b532-e8d5-481b-a5ed-5616bf0ad9fa" TYPE="swap"
/dev/zram2: UUID="62a328b0-3e44-41ff-a9dd-79a49d74d9c7" TYPE="swap"
/dev/zram3: UUID="3b5ed341-f05b-4907-b965-8840f2541c82" TYPE="swap"
/dev/zram4: UUID="14517095-4a69-4210-bbd8-d53c1a34d3d7" TYPE="swap"
/dev/mmcblk0: PTUUID="36326db0" PTTYPE="dos"
/dev/mmcblk2: PTUUID="7b2f8591" PTTYPE="dos"
follow this document, can't find script.bin in system.
https://forum.armbian.com/topic/1702-orange-pi-plus-2e-where-is-16ghz-and-sd/?tab=comments#comment-13163
where is the problem, any help ?
thinks.
1 hour ago, Lin Xiaofeng said:
Document from 2016 might not be useful. Script.bin is proprietary Allwinner way of describing hardware configuration. This is EOL and is not used in mainline kernel which we use here. Here, we have https://en.wikipedia.org/wiki/Device_tree
Support for eMMC in u-boot is not enabled or does not exists at all. Check those patches to get an idea how to enable eMMC:
https://github.com/armbian/build/blob/master/patch/u-boot/u-boot-sunxi/add-nanopi-air-emmc.patch
https://github.com/armbian/build/blob/master/patch/u-boot/u-boot-sun50iw2/add-a64-olinuxino-emmc-support.patch
Than just use nand-sata-install.
You've didn't mentioned which board you are using !
Is it a PineH6 ? In this case, I think no Devs worked on creating u-boot patches for it yet ...
@martinayotte Sorry,  the device is our new product, No brand and model, use the H6 chip.
 we use the "orangepi lite2" to build the armbian image.
@Igor  today I change the patch, add MMC2, but is not work,  the error message is change,
The error message:
U-Boot SPL 2018.09-rc1-armbian (Nov 20 2018 - 18:39:10 +0800)
DRAM: 1024 MiB
MMC: no card present
spl: mmc init failed with error: -123
1. add "CONFIG_MMC_SUNXI_SLOT_EXTRA=2" to the defconfig
root@ubuntu:/armbian/cache/sources/u-boot/h6-hdmi-rebased-1/configs# cat orangepi_lite2_defconfig
CONFIG_ARM=y
CONFIG_ARCH_SUNXI=y
CONFIG_MACH_SUN50I_H6=y
CONFIG_DRAM_ODT_EN=y
CONFIG_MMC0_CD_PIN="PF6"
CONFIG_HDMI_DDC_EN="PH2"
CONFIG_DEFAULT_DEVICE_TREE="sun50i-h6-orangepi-lite2"
CONFIG_SPL=y
2. add the MMC2 to the dts
root@ubuntu:/armbian/cache/sources/u-boot/h6-hdmi-rebased-1/arch/arm/dts# cat sun50i-h6-orangepi-lite2.dts
/dts-v1/;
#include "sun50i-h6.dtsi"
#include <dt-bindings/gpio/gpio.h>
        model = "OrangePi Lite 2";
        compatible = "xunlong,orangepi-lite2", "allwinner,sun50i-h6";
        aliases {
                serial0 = &uart0;
        chosen {
                stdout-path = "serial0:115200n8";
&mmc0 {
        pinctrl-names = "default";
        pinctrl-0 = <&mmc0_pins>;
        vmmc-supply = <&reg_cldo1>;
        cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>;
        bus-width = <4>;
        status = "okay";
&mmc2 {
        pinctrl-0 = <&mmc2_pins>;
        vqmmc-supply = <&reg_bldo2>;
        non-removable;
        cap-mmc-hw-reset;
        status = "okay";
Why should your product be our problem and expense?
  • Igor locked this topic
