GrandPeter Posted October 23, 2018 Posted October 23, 2018 Dear All! I dont find Armbian for orangepi mini Where can I download the distribution for Orange pi mini? The latest working version? Help me
Igor Posted October 23, 2018 Posted October 23, 2018 https://www.armbian.com/download/?tx_maker=xunlong Scroll a little, CTRL F and put "mini" in. https://www.armbian.com/orange-pi-mini apt update and upgrade gets you to the latest version.
GrandPeter Posted October 27, 2018 Author Posted October 27, 2018 Hi! I downloaded the image. OS booted but does not recognize usb devices (keyboard and built-in wifi). :'(
guidol Posted October 27, 2018 Posted October 27, 2018 20 minutes ago, GrandPeter said: Hi! I downloaded the image. OS booted but does not recognize usb devices (keyboard and built-in wifi). :'( does "dmesg -w" show anything when you add a usb device? or try to enable "some" usb ports inside armbian-config -> system -> hardware and reboot (maybe it isnt enabled by default?)
GrandPeter Posted October 27, 2018 Author Posted October 27, 2018 4 hours ago, guidol said: does "dmesg -w" show anything when you add a usb device? or try to enable "some" usb ports inside armbian-config -> system -> hardware and reboot (maybe it isnt enabled by default?) dmesg -w - not showing anything when I'm add a usb device. when you connect the mouse does not light the laser
Igor Posted October 27, 2018 Posted October 27, 2018 4 hours ago, guidol said: armbian-config -> system -> hardware Have some troubles which need to be addressed. https://github.com/armbian/config/issues/33
t3l3m4k0 Posted October 27, 2018 Posted October 27, 2018 @GranPeter you must edit /boot/armbianEnv.txt and append fdtfile=sun7i-a20-orangepi-mini.dtb reboot and all hardware works. I think it load for default device tree for babana 1
GrandPeter Posted October 27, 2018 Author Posted October 27, 2018 1 hour ago, t3l3m4k0 said: @GranPeter you must edit /boot/armbianEnv.txt and append fdtfile=sun7i-a20-orangepi-mini.dtb reboot and all hardware works. I think it load for default device tree for babana Thanks it helped
