jxdqwer Posted November 5, 2018 Posted November 5, 2018 Nanopi Neo4 armbian5.65 Mac address is no fixed。 Every times setup my Neo4 the MAC address is diffenence。 Who can help me. forgive my pool English. Thanks
Igor Posted November 5, 2018 Posted November 5, 2018 On 11/5/2018 at 2:54 AM, jxdqwer said: Nanopi Neo4 armbian5.65 Expand You forget on most important data. Which kernel do you use? armbianmonitor -u And remember that this image is not declared stable yet since (such) minor issues weren't fully resolved yet.
guidol Posted November 5, 2018 Posted November 5, 2018 On 11/5/2018 at 2:54 AM, jxdqwer said: Nanopi Neo4 armbian5.65 Mac address is no fixed。 Every times setup my Neo4 the MAC address is diffenence。 Who can help me. forgive my pool English. Thanks Expand if you didnt use the Network-Manager for configuring your eth0, but the /etc/network/interfaces the you could use the following idea to set a MAC-Address:http://www.youritronics.com/how-to-set-the-mac-address-from-etcnetworkinterfaces-in-debian/ look for the linehwaddress ether 00:01:04:1b:2C:1F #This file describes the network interfaces available on your system # and how to activate them. For more information, see interfaces(5). # The loopback network interface auto lo iface lo inet loopback # The primary network interface auto eth0 iface eth0 inet static address 1.1.1.2 netmask 255.255.255.0 network 1.1.1.255 broadcast 1.1.1.255 gateway 1.1.1.1 dns-nameservers 1.1.1.1 dns-search .com hwaddress ether 00:01:04:1b:2C:1F
jxdqwer Posted November 12, 2018 Author Posted November 12, 2018 On 11/5/2018 at 6:08 PM, guidol said: if you didnt use the Network-Manager for configuring your eth0, but the /etc/network/interfaces the you could use the following idea to set a MAC-Address:http://www.youritronics.com/how-to-set-the-mac-address-from-etcnetworkinterfaces-in-debian/ look for the linehwaddress ether 00:01:04:1b:2C:1F #This file describes the network interfaces available on your system # and how to activate them. For more information, see interfaces(5). # The loopback network interface auto lo iface lo inet loopback # The primary network interface auto eth0 iface eth0 inet static address 1.1.1.2 netmask 255.255.255.0 network 1.1.1.255 broadcast 1.1.1.255 gateway 1.1.1.1 dns-nameservers 1.1.1.1 dns-search .com hwaddress ether 00:01:04:1b:2C:1F Expand Thank you.It's useful, auto eth0 iface eth0 inet dhcp hwaddress ether xx:xx:xx:xx:xx:xx
Igor Posted November 12, 2018 Posted November 12, 2018 For Network manager way, check this:https://github.com/armbian/build/blob/master/packages/bsp/common/usr/lib/armbian/armbian-common#L38-L50 1
littlema Posted January 10, 2019 Posted January 10, 2019 On 11/12/2018 at 6:41 AM, Igor said: For Network manager way, check this:https://github.com/armbian/build/blob/master/packages/bsp/common/usr/lib/armbian/armbian-common#L38-L50 Expand I meet the same problem,but your link is only the code in github. Can you tell me how to enable it to keep my mac addr and use network manager.Because I use ipv6. And I set /etc/network/interface,but ipv6 didn't work,I don't know why
jxdqwer Posted January 14, 2019 Author Posted January 14, 2019 On 11/12/2018 at 6:41 AM, Igor said: For Network manager way, check this:https://github.com/armbian/build/blob/master/packages/bsp/common/usr/lib/armbian/armbian-common#L38-L50 Expand [ 5.690456] vendor storage:20160801 ret = -1 [ 5.702108] Adding 117712k swap on /dev/zram4. Priority:5 extents:1 across:117712k SS [ 5.748492] zram0: detected capacity change from 0 to 52428800 [ 5.855128] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard [ 7.509822] nr_pdflush_threads exported in /proc is scheduled for removal [ 7.852571] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 7.853012] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: rk_vendor_read eth mac address failed (-1) [ 7.853052] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: generate random eth mac address: 5a:b7:f0:5b:53:d4 [ 7.853058] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: rk_vendor_write eth mac address failed (-1) [ 7.853066] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: mac address: 5a:b7:f0:5b:53:d4 [ 7.853071] eth0: device MAC address 5a:b7:f0:5b:53:d4 [ 7.867585] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 7.867692] dhd_open: Enter ffffffc03e8ff000 [ 7.867698] Dongle Host Driver, version 1.579.77.41.2 (r) [ 7.867702] wl_android_wifi_on in 1 I think this is the root cause "[ 7.853012] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: rk_vendor_read eth mac address failed (-1)" log for you. how to fix it? a.txt
Igor Posted January 14, 2019 Posted January 14, 2019 On 1/10/2019 at 11:29 AM, littlema said: but your link is only the code in github Expand This way it is possible to set MAC address with NetworkManager and that's all I know/can help about this. You can also use nmtui-edit and set MAC spoofing via "GUI" tools. Read NetworkManager manuals if you run into troubles. This has nothing to do with Armbian. On 1/10/2019 at 11:29 AM, littlema said: And I set /etc/network/interface Expand This way you override NM settings. Again, check generic Debian/Ubuntu manual for setting this up. And I am not sure if its always possible to set MAC this way.
