Alexio Posted November 28, 2018 Posted November 28, 2018 1 hour ago, vzsze said: I didn't have problems with eMMC-Installation. I booted from SD-Card and used armbian-config to install to eMMC. No need to use other flash methods. I'm using the Openmediavault+ARMbian image provided by Tkaiser. When I go to armbian-config --> System there is no 'Install - installs to SATA, eMMC, NAND or USB' option (according ARMBian documentation it should be there ). Just checked at a Odroid HC1 and a Banana pi 1, both running the "same" Openmediavault+ARMbian ROM. They also don't have the option van 'Install' option available. @Igor, @tkaiser is this option moved to a different location? Or just not present for the Openmedivault+ARMbian combo?
Igor Posted November 28, 2018 Posted November 28, 2018 7 minutes ago, Alexio said: I'm using the Openmediavault What has this to do with this topic and Armbian?
NicoD Posted November 28, 2018 Posted November 28, 2018 7 minutes ago, Igor said: What has this to do with this topic and Armbian? 14 minutes ago, Alexio said: I'm using the Openmediavault+ARMbian 14 minutes ago, Alexio said: When I go to armbian-config
Igor Posted November 28, 2018 Posted November 28, 2018 Support ends here: https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-authenticity
