1 1
eddywebs
Startup Message/Script stopped working
Hi all  I am using the Armbian 5.32 OMV image, recently the startup message stopped working after a hard reboot. Any ideas where the startup script exists (the one which displays Welcome to Armbian and all the vital stats) or how to troubleshoot such issue ?
The amrbianmonitor logs is available at >> http://sprunge.us/QLfq9F
Thank you !
Share this post
Link to post
Share on other sites
2 hours ago, Igor said:
The scripts should be in /etc/updated-mot.d ... perhaps already one reboot solve this? Otherwise check motd service status. That one is responsible for this.
You are right, when I did  sudo systemctl status motd  it returned
● motd.service
   Loaded: masked (/dev/null)
   Active: inactive (dead)
Motd fails to start upon sudo systemctl enable motd, with the following message
Synchronizing state for motd.service with sysvinit using update-rc.d...
Executing /usr/sbin/update-rc.d motd defaults
Executing /usr/sbin/update-rc.d motd enable
update-rc.d: warning: enable action will have no effect on runlevel 1
Failed to execute operation: No such file or directory
Any Ideas why it would do so ? . Subsequent restarts have not fixed the problem :(
Share this post
Link to post
I am not familiar with motd service in details - you will have to look on your own - at least we identify the source of the problem. This usually takes much more time than the actual fixing.
We only replace stock welcome message with ours but the motd service is stock Debian / Ubuntu. You have to check motd manual, reinstall package, check around for generic motd troubles. They are unrelated to Armbian as well as OMV, which drastically changes Armbian to suit their needs.
Share this post
Link to post
I suffered from the same problem and want to document the solution I found lately.
The problem doesn't seem to be related to the motd.service at all. The output looks exactly the same on a working system.
Instead I took a look at my sshd_config in /etc/ssh/ because we dealt with ssh-logins and I remembered that during a apt upgrade I had to decide if to switch to a new version of sshd_config or to stay with my old.
However, it turns out that the welcome message depends on the UsePAM parameter in sshd_config.
If it is set to 'no' you won't receive the fancy welcome message. Simply turning it to 'yes' did the trick for me and I now receive the welcome message again with every ssh-login.
Summary:
Make sure that this is in your /etc/ssh/sshd_config:
UsePAM yes
Hope this helps some other folks.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
1 1
