Liontek1985 Posted January 4, 2019 Posted January 4, 2019 Hello guys i have bought a Tritium H3 and iam search a option to setting the cpu/gpu/ddr clock for armbian give it a script.bin (like orange pi) for this board to configure or an other option? please help me best regards fredy
Tido Posted January 4, 2019 Posted January 4, 2019 Hi Fredi, sure, here you go: https://docs.armbian.com/User-Guide_Getting-Started/
Liontek1985 Posted January 18, 2019 Author Posted January 18, 2019 Hello and thx for answer i have readed and now my Board run on Armbian Jessie (Retrorangepi 4.2) the problem what iam have the board run only on 408MHz in idle and on fire.... i have check the system settings, here is more than 408 allowed... i have tested with user_overlays in armbianEnv.txt without result sun8i-h3-libretech-all-h3-cc.dts in /boot/overlay-user/ directory armbianEnv.txt Reveal hidden contents verbosity=1 logo=disabled console=both disp_mode=1920x1080p60 user_overlays=sun8i-h3-libretech-all-h3-cc rootdev=UUID=8f6a4987-3f69-4921-9b6f-7470dbd1b5a2 rootfstype=ext4 the "sun8i-h3-libretech-all-h3-cc.dtb/dts" file has a speed table up to 1368Mhz Reveal hidden contents opp_table0 { compatible = "operating-points-v2"; opp-shared; phandle = <0x29>; opp@120000000 { opp-hz = <0x0 0x7270e00>; opp-microvolt = <0xfde80 0xfde80 0x13d620>; clock-latency-ns = <0x3b9b0>; }; opp@240000000 { opp-hz = <0x0 0xe4e1c00>; opp-microvolt = <0xfde80 0xfde80 0x13d620>; clock-latency-ns = <0x3b9b0>; }; opp@480000000 { opp-hz = <0x0 0x1c9c3800>; opp-microvolt = <0xfde80 0xfde80 0x13d620>; clock-latency-ns = <0x3b9b0>; }; opp@648000000 { opp-hz = <0x0 0x269fb200>; opp-microvolt = <0xfde80 0xfde80 0x13d620>; clock-latency-ns = <0x3b9b0>; }; opp@816000000 { opp-hz = <0x0 0x30a32c00>; opp-microvolt = <0x10c8e0 0x10c8e0 0x13d620>; clock-latency-ns = <0x3b9b0>; }; opp@960000000 { opp-hz = <0x0 0x39387000>; opp-microvolt = <0x124f80 0x124f80 0x13d620>; clock-latency-ns = <0x3b9b0>; }; opp@1008000000 { opp-hz = <0x0 0x3c14dc00>; opp-microvolt = <0x124f80 0x124f80 0x13d620>; clock-latency-ns = <0x3b9b0>; }; opp@1056000000 { opp-hz = <0x0 0x3ef14800>; opp-microvolt = <0x142440 0x142440 0x142440>; clock-latency-ns = <0x3b9b0>; }; opp@1104000000 { opp-hz = <0x0 0x41cdb400>; opp-microvolt = <0x142440 0x142440 0x142440>; clock-latency-ns = <0x3b9b0>; }; opp@1152000000 { opp-hz = <0x0 0x44aa2000>; opp-microvolt = <0x142440 0x142440 0x142440>; clock-latency-ns = <0x3b9b0>; }; opp@1200000000 { opp-hz = <0x0 0x47868c00>; opp-microvolt = <0x142440 0x142440 0x142440>; clock-latency-ns = <0x3b9b0>; }; opp@1224000000 { opp-hz = <0x0 0x48f4c200>; opp-microvolt = <0x147260 0x147260 0x147260>; clock-latency-ns = <0x3b9b0>; }; opp@1248000000 { opp-hz = <0x0 0x4a62f800>; opp-microvolt = <0x147260 0x147260 0x147260>; clock-latency-ns = <0x3b9b0>; }; opp@1296000000 { opp-hz = <0x0 0x4d3f6400>; opp-microvolt = <0x147260 0x147260 0x147260>; clock-latency-ns = <0x3b9b0>; }; opp@1344000000 { opp-hz = <0x0 0x501bd000>; opp-microvolt = <0x155cc0 0x155cc0 0x155cc0>; clock-latency-ns = <0x3b9b0>; }; opp@1368000000 { opp-hz = <0x0 0x518a0600>; opp-microvolt = <0x155cc0 0x155cc0 0x155cc0>; clock-latency-ns = <0x3b9b0>; }; }; can anyone help me to fix the problem please best regards fredy
Igor Posted January 18, 2019 Posted January 18, 2019 On 1/18/2019 at 6:33 PM, Liontek1985 said: i have readed and now my Board run on Armbian Jessie (Retrorangepi 4.2) Expand We don't support 3rd party builds. https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-authenticity nor this board: https://www.armbian.com/tritium-h3/ Moving to community section.
Liontek1985 Posted January 18, 2019 Author Posted January 18, 2019 very helpful... i dont need official support, i need help from user to user that's what makes a good community
Igor Posted January 18, 2019 Posted January 18, 2019 On 1/18/2019 at 6:47 PM, Liontek1985 said: very helpful Expand We don't have capacity to deal with "you" in this number. Simple as that. On 1/18/2019 at 6:47 PM, Liontek1985 said: good community Expand Use correct part of the forums - community forums.
Liontek1985 Posted January 21, 2019 Author Posted January 21, 2019 Hello Guys can anyone help me please to integrate the "sun8i-h3-libretech-all-h3-cc.dtb/dts" on Retrorangepi 4.2 (legacy) or to fix the problem? i have tested with many options in script.bin/fex, I used as a base the orangepipc bin/fex without result
TonyMac32 Posted January 23, 2019 Posted January 23, 2019 I'm afraid I have never run a kernel older than 4.14 on this board. I don't know that fex files exist for this board, and that explains the heat and speed issues... I also don't know how to create the appropriate files, again, I haven't messed with old kernels.
Liontek1985 Posted January 23, 2019 Author Posted January 23, 2019 thx for your answere i have readed that i need a fex file for legacy kernel me spend many time to find out the right settings in fex and now i have a workes fex file with all features! On my board i have on ram and soc good heatsinks with Thermal Grease (CM IC Essential E1) and a pi-fan with the new fex run it @ 40-45°c on fire the cpu speed issue is fixed, now change the board the speed form 408Mhz up to 1200Mhz, tested with many PSP, PSX and Dreamcast games without issues or hang ups the performance is like a orange pi pc himself is the nerd
