Technofreaks Posted January 29, 2019 Posted January 29, 2019 Hi, Compiled image for Nanopi3 , Ubuntu Xenial Server, After booting, LCD backlight switches on, but no display. Need help to fix this. No Customization or kernel config change done, used defaults. Linux nanopifire3 4.14.96-s5p6818 #2 SMP Tue Jan 29 12:56:43 UTC 2019 aarch64 aarch64 aarch64 GNU/Linux from dmesg: [ 2.532000] leds-gpio: probe of leds failed with error -16 [ 1.912000] Console: switching to colour frame buffer device 60x50 [ 1.920000] nexell,display_drm c0102800.display_drm: fb0: frame buffer device Thank You Sudhir
Igor Posted January 29, 2019 Posted January 29, 2019 22 minutes ago, Technofreaks said: LCD backlight switches on OOB is almost sure not supported, only HDMI. Peek into DTB if kernel bits are there and enable. Check/compare how this is enabled in stock images ...
Technofreaks Posted January 29, 2019 Author Posted January 29, 2019 3 hours ago, Igor said: OOB is almost sure not supported, only HDMI. Peek into DTB if kernel bits are there and enable. Check/compare how this is enabled in stock images ... I will check FriendlyArm build, how its done there.. thank you
guidol Posted January 29, 2019 Posted January 29, 2019 27 minutes ago, Technofreaks said: I will check FriendlyArm build, how its done there.. first you have to check which display-model do you use and how its connected to the Fire3: Quote http://wiki.friendlyarm.com/wiki/index.php/NanoPi_Fire3#Connect_NanoPi-Fire3_to_FriendlyARM_LCD_Modules FriendlyCore & Lubuntu Desktop Here are the LCDs that are supported under FriendlyCore and Lubuntu Desktop: S430, S700/S701, S702, HD700, HD702, HD101 and X710 all of which are LCDs with capacitive touch; W35B, H43, P43, S70D and Matrix 2.8" SPI Key TFT LCD all of which are LCDs with resistive touch
EugeneC Posted February 25, 2019 Posted February 25, 2019 Any news on support for LVDS LCD screens? I am using s430. It is awesome screen, sun readable, capacitive touch. During boot I can see logo flash in a corner. Looks like screen resolution is passed wrong or not detected properly. Thank you
eduards66 Posted May 22, 2019 Posted May 22, 2019 Is somebody has success with LVDS display s430 for nanopifire3 with armbian distribution 4.14. Any help is highly appreciated.
