FRANK333 Posted January 31, 2019 Posted January 31, 2019 After the automatic update to kernel 4.19.17 the CPU temperature is wrong and much higher, also in dmesg there are these errors Spoiler dmesg | grep thermal [ 6.428747] thermal thermal_zone1: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-22 [ 6.841480] thermal thermal_zone0: failed to read out thermal zone (-110) [ 6.841546] OF: /thermal-zones/cpu-thermal: arguments longer than property [ 6.841560] thermal thermal_zone2: failed to read out thermal zone (-110) [ 7.877181] thermal thermal_zone0: failed to read out thermal zone (-110) [ 8.050346] thermal thermal_zone2: failed to read out thermal zone (-110) OPzero+ has a heatsink and a fan, and the use of the cpu is always very low here the graphs. The temperature of the external sensor is correct. I ask if anyone has the same problem as me and how it could be solved. Spoiler 1
sfx2000 Posted February 1, 2019 Posted February 1, 2019 Temps seem to be fine - another AW H5 target - NanoPI Neo2... Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 19:30:20: 480MHz 0.06 1% 0% 0% 0% 0% 0% 33.0°C 0/6 19:30:26: 816MHz 0.05 3% 1% 1% 0% 0% 0% 33.0°C 0/6 19:30:31: 480MHz 0.05 1% 0% 0% 0% 0% 0% 33.1°C 0/6 19:30:36: 480MHz 0.04 0% 0% 0% 0% 0% 0% 33.1°C 0/6 19:30:41: 480MHz 0.04 0% 0% 0% 0% 0% 0% 33.1°C 0/6 19:30:46: 480MHz 0.04 0% 0% 0% 0% 0% 0% 33.2°C 0/6 19:30:51: 480MHz 0.03 0% 0% 0% 0% 0% 0% 33.1°C 0/6 19:30:56: 480MHz 0.03 0% 0% 0% 0% 0% 0% 32.8°C 0/6 19:31:03: 816MHz 0.03 18% 0% 18% 0% 0% 0% 35.3°C 0/6 19:31:10: 816MHz 0.71 100% 0% 99% 0% 0% 0% 38.0°C 0/6 19:31:18: 816MHz 0.98 100% 0% 99% 0% 0% 0% 38.9°C 0/6 19:31:24: 480MHz 1.19 32% 0% 32% 0% 0% 0% 35.8°C 0/6 19:31:29: 480MHz 1.10 0% 0% 0% 0% 0% 0% 34.7°C 0/6 19:31:34: 480MHz 1.01 0% 0% 0% 0% 0% 0% 33.9°C 0/6 The dmesg errors - not exclusive to the OPiZero H5 sfx@nano2:~$ dmesg | grep thermal [ 5.003851] thermal thermal_zone1: binding zone cpu-thermal with cdev therma-cpufreq-0 failed:-22 [ 5.106441] thermal thermal_zone0: failed to read out thermal zone (-110) [ 5.106486] OF: /thermal-zones/cpu-thermal: arguments longer than property [ 5.106498] thermal thermal_zone2: failed to read out thermal zone (-110) [ 6.114052] thermal thermal_zone0: failed to read out thermal zone (-110) [ 6.315273] thermal thermal_zone2: failed to read out thermal zone (-110) Busy with other things at the moment - if you're smart with MIPS32 Big Endian, would be interested to chat further...
FRANK333 Posted February 1, 2019 Author Posted February 1, 2019 15 hours ago, sfx2000 said: Temps seem to be fine - another AW H5 target - NanoPI Neo2... so the values I read here might be right: Spoiler could be a bug in the rpimonitor program? now really, I do not know what temperature is the right temperature for the cpu, even knowing that the outside temperature is about 10 degrees.
FRANK333 Posted March 4, 2019 Author Posted March 4, 2019 someone, can report here the temperatures it detects from its orange pi and what kind of cooling it has (heatsink, fan, etc.). I still do not understand the problem of rpimonitor and armbianmonitor (I would like to understand what is the correct temperature of the CPU) Spoiler armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 16:29:23: 1008MHz 0.72 5% 1% 1% 0% 1% 0% 15.7°C 0/6 16:29:30: 1008MHz 0.66 3% 1% 1% 0% 0% 0% 15.7°C 0/6 16:29:36: 1008MHz 0.69 3% 1% 1% 0% 0% 0% 15.7°C 0/6 16:29:42: 240MHz 0.71 4% 1% 1% 0% 0% 0% 15.7°C 0/6 16:29:48: 1008MHz 0.68 3% 1% 1% 0% 0% 0% 15.7°C 0/6 16:29:54: 1008MHz 0.70 4% 1% 1% 0% 1% 0% 15.7°C 0/6 16:30:00: 1008MHz 0.65 4% 1% 1% 0% 0% 0% 15.7°C 0/6 16:30:06: 240MHz 0.67 4% 1% 1% 0% 0% 0% 15.7°C 0/6 16:30:12: 240MHz 0.62 3% 1% 0% 0% 1% 0% 15.7°C 0/6 16:30:18: 1008MHz 0.52 3% 1% 1% 0% 0% 0% 15.7°C 0/6 16:30:24: 1008MHz 0.48 3% 0% 1% 0% 0% 0% 15.7°C 0/6 16:30:29: 1008MHz 0.68 3% 1% 0% 0% 0% 0% 15.7°C 0/6 16:30:35: 1008MHz 0.63 3% 1% 1% 0% 0% 0% 15.7°C 0/6 16:30:41: 1008MHz 0.58 7% 3% 2% 0% 0% 0% 15.7°C 0/6 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 16:30:47: 120MHz 0.49 3% 1% 1% 0% 0% 0% 15.7°C 0/6 16:30:53: 1008MHz 0.53 4% 1% 1% 0% 0% 0% 15.7°C 0/6 16:30:59: 1008MHz 0.57 3% 1% 1% 0% 0% 0% 15.7°C 0/6 16:31:05: 1008MHz 0.52 3% 1% 1% 0% 0% 0% 15.7°C 0/6 16:31:11: 1008MHz 0.48 3% 1% 1% 0% 0% 0% 15.7°C 0/6 16:31:17: 1008MHz 0.44 3% 1% 1% 0% 1% 0% 15.7°C 0/6 16:31:23: 1008MHz 0.53 4% 1% 1% 0% 0% 0% 15.7°C 0/6 16:31:29: 1008MHz 0.65 5% 0% 1% 0% 3% 0% 15.7°C 0/6 16:31:35: 240MHz 0.59 4% 1% 1% 0% 0% 0% 15.7°C 0/6 16:31:41: 240MHz 0.55 3% 1% 1% 0% 0% 0% 15.7°C 0/6 16:31:47: 240MHz 0.50 4% 1% 1% 0% 0% 0% 15.7°C 0/6 16:31:53: 1008MHz 0.50 3% 1% 1% 0% 0% 0% 15.7°C 0/6 16:31:59: 240MHz 0.46 4% 1% 1% 0% 0% 0% 15.7°C 0/6 16:32:04: 1008MHz 0.42 4% 1% 1% 0% 1% 0% 15.7°C 0/6 Spoiler root@server:~# cat /sys/class/thermal/thermal_zone0/temp 29750 root@server:~# cat /sys/devices/virtual/thermal/thermal_zone0/temp 28798 root@server:~# cat /etc/armbianmonitor/datasources/soctemp 15937
FRANK333 Posted March 12, 2019 Author Posted March 12, 2019 after the automatic update to: Linux 4.19.20-sunxi64 aarch64 #5.75 SMP I have these problems: armbianmonitor -u no longer creates the link. the cpu temperature corresponds to that of the external sensor the /etc/default/cpufrequtils file has changed and the cpu frequency has decreased to 120 mhz Is there anyone who has the pizeroplus (h5) and who can check if it has similar values? Spoiler cat /etc/default/cpufrequtils # WARNING: this file will be replaced on board support package (linux-root-...) upgrade ENABLE=true MIN_SPEED=120000 MAX_SPEED=1200000 GOVERNOR=ondemand root@server:~# cat /sys/class/thermal/thermal_zone0/temp 28798 root@server:~# armbianmonitor -u System diagnosis information will now be uploaded to Please post the URL in the forum where you've been asked for. root@server:~# dmesg | grep thermal [ 6.426669] thermal thermal_zone1: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-22 [ 6.617395] thermal thermal_zone0: failed to read out thermal zone (-110) [ 6.617445] OF: /thermal-zones/cpu-thermal: arguments longer than property [ 6.617457] thermal thermal_zone2: failed to read out thermal zone (-110) [ 7.649161] thermal thermal_zone0: failed to read out thermal zone (-110) [ 7.826193] thermal thermal_zone2: failed to read out thermal zone (-110) root@server:~# armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 08:44:22: 1008MHz 0.28 4% 1% 2% 0% 1% 0% 16.5°C 0/6 08:44:28: 120MHz 0.25 3% 0% 0% 0% 1% 0% 16.4°C 0/6 08:44:34: 1008MHz 0.23 3% 1% 1% 0% 0% 0% 16.5°C 0/6 08:44:42: 120MHz 0.21 2% 1% 1% 0% 0% 0% 16.5°C 0/6 08:44:48: 240MHz 0.25 5% 1% 1% 0% 1% 0% 16.4°C 0/6 08:44:54: 120MHz 0.23 3% 1% 1% 0% 0% 0% 16.5°C 0/6 08:45:00: 1008MHz 0.22 7% 3% 2% 0% 0% 0% 16.4°C 0/6 08:45:05: 1008MHz 0.20 3% 1% 1% 0% 1% 0% 16.4°C 0/6 08:45:12: 120MHz 0.18 3% 1% 1% 0% 0% 0% 16.5°C 0/6 08:45:17: 240MHz 0.15 4% 1% 2% 0% 0% 0% 16.5°C 0/6 08:45:23: 1008MHz 0.14 2% 1% 0% 0% 0% 0% 16.5°C 0/6^C root@server:~# cat /etc/armbianmonitor/datasources/soctemp 16500 root@server:~# cat /sys/devices/virtual/thermal/thermal_zone0/temp 29750 root@server:~# cat /sys/class/thermal/thermal_zone0/temp 28917
guidol Posted March 12, 2019 Posted March 12, 2019 ARMBIAN 5.77 user-built Debian GNU/Linux 9 (stretch) 4.20.12-sunxi64 Linux orangepizeroplus 4.20.12-sunxi64 #5.77 SMP Tue Mar 12 11:53:35 +03 2019 aarch64 GNU/Linux Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 09:31:30: 1008MHz 0.14 3% 0% 1% 0% 1% 0% 42.0°C 0/6 09:31:36: 120MHz 0.13 0% 0% 0% 0% 0% 0% 42.7°C 0/6 09:31:41: 240MHz 0.12 1% 0% 0% 0% 0% 0% 43.2°C 0/6 09:31:46: 120MHz 0.11 1% 0% 0% 0% 0% 0% 42.5°C 0/6 09:31:51: 120MHz 0.10 1% 1% 0% 0% 0% 0% 42.4°C 0/6 09:31:57: 120MHz 0.09 1% 0% 0% 0% 0% 0% 43.9°C 0/6 09:32:02: 120MHz 0.08 1% 1% 0% 0% 0% 0% 44.1°C 0/6 09:32:07: 120MHz 0.08 1% 0% 0% 0% 0% 0% 43.4°C 0/6 09:32:12: 120MHz 0.07 2% 1% 0% 0% 0% 0% 42.6°C 0/6 cat /etc/armbianmonitor/datasources/soctemp 40579 cat /sys/devices/virtual/thermal/thermal_zone0/temp 40103 cat /sys/class/thermal/thermal_zone0/temp 42364 cat /etc/default/cpufrequtils# WARNING: this file will be replaced on board support package (linux-root-...) upgrade ENABLE=true MIN_SPEED=120000 MAX_SPEED=1200000 GOVERNOR=ondemand dmesg | grep thermal [ 5.837119] thermal thermal_zone1: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-22 [ 6.114843] thermal thermal_zone0: failed to read out thermal zone (-110) [ 6.114896] OF: /thermal-zones/cpu-thermal: arguments longer than property [ 6.114908] thermal thermal_zone2: failed to read out thermal zone (-110) [ 7.137593] thermal thermal_zone0: failed to read out thermal zone (-110) [ 7.323645] thermal thermal_zone2: failed to read out thermal zone (-110) armbianmonitor -u System diagnosis information will now be uploaded to http://ix.io/1DhQ Please post the URL in the forum where you've been asked for. heat is because the OPi ZeroPlus H5 is in a original OPi small black Cube-Case with a small heatsink inside.
FRANK333 Posted March 12, 2019 Author Posted March 12, 2019 thanks guidol, now I'm almost sure that it depends on some software problem. One odd thing is that I can not reactivate armbianmonitor -u .
