barish Posted February 7, 2019 Share Posted February 7, 2019 I did the following upgrades this morning libcurl3:armhf (7.52.1-5+deb9u8, 7.52.1-5+deb9u9), libgd3:armhf (2.2.4-2+deb9u3, 2.2.4-2+deb9u4), armbian-config:armhf (5.72, 5.74), linux-headers-next-sunxi:armhf (5.70, 5.73), linux-image-next-sunxi:armhf (5.70, 5.73), curl:armhf (7.52.1-5+deb9u8, 7.52.1-5+deb9u9), libcurl3-gnutls:armhf (7.52.1-5+deb9u8, 7.52.1-5+deb9u9), linux-dtb-next-sunxi:armhf (5.70, 5.73), base-files:armhf (9.9+deb9u6, 9.9+deb9u7) and found my I2C bus not working anymore. I did a scan on the 4 buses (Olinuxino Micro A20) and found a device on i2c-1 instead of i2c-0, changed my settings and all worked again, so I guess one of the updates must have changed the labeling of the busses? Is this by accident or on purpuse? Link to comment Share on other sites More sharing options...
Igor Posted February 7, 2019 Share Posted February 7, 2019 2 minutes ago, barish said: Is this by accident or on purpuse? Most likely settings were changed upstream since I don't recall seeing anyone around Armbian fiddling around this. 1 Link to comment Share on other sites More sharing options...
martinayotte Posted February 7, 2019 Share Posted February 7, 2019 13 minutes ago, barish said: found a device on i2c-1 instead of i2c-0 If you do a "i2cdetect -l", you will probably see that i2c-0 is dedicated to "sun4i_hdmi_i2c adapter", which maybe wasn't present before ... 2 Link to comment Share on other sites More sharing options...
barish Posted February 8, 2019 Author Share Posted February 8, 2019 19 hours ago, martinayotte said: If you do a "i2cdetect -l", you will probably see that i2c-0 is dedicated to "sun4i_hdmi_i2c adapter", which maybe wasn't present before ... This is indeed the case. Thanks for this information, the change must have crept in lately. If I had the energy I could find out which of the i2c adapters on the Olinuxino were labeled as "hdmi", but right now, since I don't need to know, I won't... Link to comment Share on other sites More sharing options...
