Armbianmonitor:
Dear Armbian Friends,
My temperature sensor is not detected by board.
Can somebody give me some advice what should I chceck / change / test now?
Cheers!
Lucas
I tried:
- another sample of DHT11
- changed cables to different ones
- changed
- both tested sensors were connected with 4.7k resistor between positive and data cable
- tried different system versions like bionic,  stretch and now jessie
- tried to load modules via /etc/modules-load.d/modules.conf
g_serial
w1-sunxi
w1-gpio
w1-therm
- or with /boot/armbianEnv.txt (disabling loading with modules.conf)
wverbosity=1
logo=disabled
console=serial
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
overlays=usbhost2 usbhost3 w1-gpio
param_w1_pin=PA10
param_w1_pin_int_pullup=1
rootdev=UUID=9cecf84e-027e-40ad-b711-ae5d323d9043
rootfstype=ext4
- tried to change data pin from GPIO10 (number 26) to GPIO 15 MOSI (number 19)
Below some info about my system.
sysadm@orangepizero:~$ ls /sys/bus/w1/devices/
w1_bus_master1
sysadm@orangepizero:~$ cat /sys/devices/w1_bus_master1/w1_master_slave_count
0
sysadm@orangepizero:~$ dmesg | grep wire
[    7.802453] Driver for 1-wire Dallas network protocol.
[    7.807173] gpio-10 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
sysadm@orangepizero:~$ sudo cat /sys/kernel/debug/gpio
[sudo] password for sysadm:
gpiochip0: GPIOs 0-223, parent: platform/1c20800.pinctrl, 1c20800.pinctrl:
 gpio-10  (                    |onewire@0           ) in  lo
 gpio-17  (                    |orangepi:red:status ) out lo
 gpio-20  (                    |vcc-wifi            ) out hi
 gpio-166 (                    |cd                  ) in  lo
 gpio-204 (                    |usb0_id_det         ) in  hi IRQ
gpiochip1: GPIOs 352-383, parent: platform/1f02c00.pinctrl, 1f02c00.pinctrl:
 gpio-358 (                    |vdd-cpux            ) out hi
 gpio-359 (                    |reset               ) out hi
 gpio-362 (                    |orangepi:green:pwr  ) out hi
sysadm@orangepizero:~$ uname -a
Linux orangepizero 4.19.17-sunxi #5.73 SMP Mon Jan 28 21:06:40 CET 2019 armv7l GNU/Linux
sysadm@orangepizero:~$ cat /etc/issue
Debian GNU/Linux 9
Only usable change is to change a kernel. You can do this in armbian-config -> system -> alternative kernel. Try 4.14.y and 4.20.y too see if that helps. Changing systems is pointless - they all share the same kernel.
Thank you for answer.
I have switched between kernels (installed bionic image):
4.14.70
4.14.84
4.18.8
Nothing changed. Seems that it's dead end - it's not a kernel issue.
Any other ideas?
Are you sure it is a 4K7 ? According to color bars seen on the picture, it seems to be more a 47R ...
Checked.
On 20k scale is 4.68 so it looks like 4k7.
I also tried another sample of resistor to be sure that this is not the case. No changes.
I have three samples of DHT11, one of them is equipped with diode but it seems that this model isn't compatible.
I will order DS18B20.
Can someone confirm which temperature sensor is working on Orange Pi Zero (with H2+)?
I've some DS18B20 on few of my boards, one of them is an OPiZero+H5.
EDIT : I've never tested it with plain OPiZero (H2+), I will maybe this afternoon ...
3 hours ago, lukaszertel said:
Hope it will do the job.
I've took the time to try it on one of my OPiZeros, and it works !
But I didn't took chance : like mentioned in your link, and read in some other thread read in the past, I've set /etc/default/cpufrequtils with MIN_SPEED=480000 instead of MIN_SPEED=240000 .
Maybe this is also required for your DHT11 ...
Thank you for taking your time on tests :)
My cpufreg now looks like
root@orangepizero:~# more /etc/default/cpufrequtils
# WARNING: this file will be replaced on board support package (linux-root-...) upgrade
ENABLE=true
MIN_SPEED=480000
#MIN_SPEED=240000
MAX_SPEED=1200000
#GOVERNOR=ondemand
GOVERNOR=interactive
But nothing is discovered.
I hope that new sensor will come soon!
Stay tuned ;-)
Are you sure that DHT11 is really one wire .... As far as I remember I had to use a specific program to access it. And the reliability of this sensor is so low that they went directly to the bin.
Right ! After googling at bit, it seems that DHT11, although physically looks the same as OneWire, the bitbanging protocol looks like a bit different.
Also, OneWire devices cannot be placed on the same bus as the DHT11. So, better stick with DS18B20...
I'm back :-)
Well, it's working! Almost..
When I checking temperature not evey response is proper,  some anwers are with "crc=c9 NO".
I have checked wiring and connections on board few times, changed resistor and cables.
Do you have any idea?
root@orangepizero:~# cat /sys/bus/w1/devices/28-020b92459bc7/w1_slave
ff ff ff ff ff ff ff ff ff : crc=c9 NO
00 00 00 00 00 00 00 00 00 t=-62
57 01 55 05 7f 7e 81 66 9d : crc=9d YES
57 01 55 05 7f 7e 81 66 9d t=21437
54 01 55 05 7f 7e 81 66 58 : crc=58 YES
54 01 55 05 7f 7e 81 66 58 t=21250
54 01 55 05 7f 7e 81 66 58 t=-62
53 01 55 05 7f 7e 81 66 88 : crc=88 YES
53 01 55 05 7f 7e 81 66 88 t=21187
EDIT:
Okay, I got it
echo 408000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
Default was 120000
root@orangepizero:~# more /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
120000
I found answer in this topic:
