lukaszertel Posted February 9, 2019 Share Posted February 9, 2019 Armbianmonitor: http://ix.io/1ADh Dear Armbian Friends, My temperature sensor is not detected by board. Can somebody give me some advice what should I chceck / change / test now? Cheers! Lucas I tried: - another sample of DHT11 - changed cables to different ones - changed - both tested sensors were connected with 4.7k resistor between positive and data cable - tried different system versions like bionic, stretch and now jessie - tried to load modules via /etc/modules-load.d/modules.conf g_serial w1-sunxi w1-gpio w1-therm - or with /boot/armbianEnv.txt (disabling loading with modules.conf) wverbosity=1 logo=disabled console=serial disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 overlays=usbhost2 usbhost3 w1-gpio param_w1_pin=PA10 param_w1_pin_int_pullup=1 rootdev=UUID=9cecf84e-027e-40ad-b711-ae5d323d9043 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u - tried to change data pin from GPIO10 (number 26) to GPIO 15 MOSI (number 19) Below some info about my system. sysadm@orangepizero:~$ ls /sys/bus/w1/devices/ w1_bus_master1 sysadm@orangepizero:~$ cat /sys/devices/w1_bus_master1/w1_master_slave_count 0 sysadm@orangepizero:~$ dmesg | grep wire [ 7.802453] Driver for 1-wire Dallas network protocol. [ 7.807173] gpio-10 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file sysadm@orangepizero:~$ sudo cat /sys/kernel/debug/gpio [sudo] password for sysadm: gpiochip0: GPIOs 0-223, parent: platform/1c20800.pinctrl, 1c20800.pinctrl: gpio-10 ( |onewire@0 ) in lo gpio-17 ( |orangepi:red:status ) out lo gpio-20 ( |vcc-wifi ) out hi gpio-166 ( |cd ) in lo gpio-204 ( |usb0_id_det ) in hi IRQ gpiochip1: GPIOs 352-383, parent: platform/1f02c00.pinctrl, 1f02c00.pinctrl: gpio-358 ( |vdd-cpux ) out hi gpio-359 ( |reset ) out hi gpio-362 ( |orangepi:green:pwr ) out hi sysadm@orangepizero:~$ uname -a Linux orangepizero 4.19.17-sunxi #5.73 SMP Mon Jan 28 21:06:40 CET 2019 armv7l GNU/Linux sysadm@orangepizero:~$ cat /etc/issue Debian GNU/Linux 9 Link to comment Share on other sites More sharing options...
Igor Posted February 10, 2019 Share Posted February 10, 2019 9 hours ago, lukaszertel said: tried different system versions like bionic, stretch and now jessie Only usable change is to change a kernel. You can do this in armbian-config -> system -> alternative kernel. Try 4.14.y and 4.20.y too see if that helps. Changing systems is pointless - they all share the same kernel. Link to comment Share on other sites More sharing options...
lukaszertel Posted February 10, 2019 Author Share Posted February 10, 2019 Thank you for answer. I have switched between kernels (installed bionic image): 4.14.70 4.14.84 4.18.8 Nothing changed. Seems that it's dead end - it's not a kernel issue. Any other ideas? Link to comment Share on other sites More sharing options...
martinayotte Posted February 10, 2019 Share Posted February 10, 2019 17 hours ago, lukaszertel said: with 4.7k resistor between positive Are you sure it is a 4K7 ? According to color bars seen on the picture, it seems to be more a 47R ... Link to comment Share on other sites More sharing options...
lukaszertel Posted February 10, 2019 Author Share Posted February 10, 2019 Checked. On 20k scale is 4.68 so it looks like 4k7. I also tried another sample of resistor to be sure that this is not the case. No changes. Link to comment Share on other sites More sharing options...
martinayotte Posted February 10, 2019 Share Posted February 10, 2019 No idea ! Maybe the DHT11 itself could be defective. Did you tried some other devices, such DS18B20 ? Link to comment Share on other sites More sharing options...
lukaszertel Posted February 10, 2019 Author Share Posted February 10, 2019 I have three samples of DHT11, one of them is equipped with diode but it seems that this model isn't compatible. I will order DS18B20. Can someone confirm which temperature sensor is working on Orange Pi Zero (with H2+)? Link to comment Share on other sites More sharing options...
martinayotte Posted February 10, 2019 Share Posted February 10, 2019 20 minutes ago, lukaszertel said: which temperature sensor is working on Orange Pi Zero (with H2+)? I've some DS18B20 on few of my boards, one of them is an OPiZero+H5. EDIT : I've never tested it with plain OPiZero (H2+), I will maybe this afternoon ... Link to comment Share on other sites More sharing options...
lukaszertel Posted February 10, 2019 Author Share Posted February 10, 2019 A moment ago I have ordered DS18B20. Hope it will do the job. When you mention about this model I found that this guy also used it. https://www.norwegiancreations.com/2017/06/do-it-yourself-snmp-temperature-monitoring-system/ When DS18B20 arrive I will write if it helps. Cheers! Link to comment Share on other sites More sharing options...
martinayotte Posted February 10, 2019 Share Posted February 10, 2019 3 hours ago, lukaszertel said: Hope it will do the job. I've took the time to try it on one of my OPiZeros, and it works ! But I didn't took chance : like mentioned in your link, and read in some other thread read in the past, I've set /etc/default/cpufrequtils with MIN_SPEED=480000 instead of MIN_SPEED=240000 . Maybe this is also required for your DHT11 ... Link to comment Share on other sites More sharing options...
lukaszertel Posted February 10, 2019 Author Share Posted February 10, 2019 Thank you for taking your time on tests My cpufreg now looks like root@orangepizero:~# more /etc/default/cpufrequtils # WARNING: this file will be replaced on board support package (linux-root-...) upgrade ENABLE=true MIN_SPEED=480000 #MIN_SPEED=240000 MAX_SPEED=1200000 #GOVERNOR=ondemand GOVERNOR=interactive But nothing is discovered. I hope that new sensor will come soon! Stay tuned ;-) Link to comment Share on other sites More sharing options...
vlad59 Posted February 11, 2019 Share Posted February 11, 2019 Are you sure that DHT11 is really one wire .... As far as I remember I had to use a specific program to access it. And the reliability of this sensor is so low that they went directly to the bin. Link to comment Share on other sites More sharing options...
martinayotte Posted February 11, 2019 Share Posted February 11, 2019 Right ! After googling at bit, it seems that DHT11, although physically looks the same as OneWire, the bitbanging protocol looks like a bit different. Also, OneWire devices cannot be placed on the same bus as the DHT11. So, better stick with DS18B20... Link to comment Share on other sites More sharing options...
lukaszertel Posted February 12, 2019 Author Share Posted February 12, 2019 New sensor (DS18B20) is in delivery, I expect tomorrow I should get it. Cheers! Link to comment Share on other sites More sharing options...
vlad59 Posted February 12, 2019 Share Posted February 12, 2019 You'll see, you won't regret it comparing to DHT11 Link to comment Share on other sites More sharing options...
lukaszertel Posted February 14, 2019 Author Share Posted February 14, 2019 I'm back :-) Well, it's working! Almost.. When I checking temperature not evey response is proper, some anwers are with "crc=c9 NO". I have checked wiring and connections on board few times, changed resistor and cables. Do you have any idea? root@orangepizero:~# cat /sys/bus/w1/devices/28-020b92459bc7/w1_slave ff ff ff ff ff ff ff ff ff : crc=c9 NO 00 00 00 00 00 00 00 00 00 t=-62 root@orangepizero:~# cat /sys/bus/w1/devices/28-020b92459bc7/w1_slave 57 01 55 05 7f 7e 81 66 9d : crc=9d YES 57 01 55 05 7f 7e 81 66 9d t=21437 root@orangepizero:~# cat /sys/bus/w1/devices/28-020b92459bc7/w1_slave 54 01 55 05 7f 7e 81 66 58 : crc=58 YES 54 01 55 05 7f 7e 81 66 58 t=21250 root@orangepizero:~# cat /sys/bus/w1/devices/28-020b92459bc7/w1_slave ff ff ff ff ff ff ff ff ff : crc=c9 NO 54 01 55 05 7f 7e 81 66 58 t=-62 root@orangepizero:~# cat /sys/bus/w1/devices/28-020b92459bc7/w1_slave ff ff ff ff ff ff ff ff ff : crc=c9 NO 54 01 55 05 7f 7e 81 66 58 t=-62 root@orangepizero:~# cat /sys/bus/w1/devices/28-020b92459bc7/w1_slave 53 01 55 05 7f 7e 81 66 88 : crc=88 YES 53 01 55 05 7f 7e 81 66 88 t=21187 ============================ EDIT: Okay, I got it echo 408000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq Default was 120000 root@orangepizero:~# more /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq 120000 I found answer in this topic: Link to comment Share on other sites More sharing options...
