Tinker Board S, Armbian 5.75, 4.19.20
I've spent a week now full-time trying to make this busted thing work.  The closest I've come is setting everything for roaming.
/etc/network/interfaces.d/wlan0
iface wlan0 inet manual
        wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
        wpa-driver wext
iface mercury inet dhcp
iface home inet static
        address 10.2.1.22
        netmask 255.255.255.0
        network 10.2.1.0
        gateway 10.2.1.1
        #post-up
#Schnittstelle automatisch aktivieren
auto wlan0
# Will automatically select the best network based on the order of network blocks,
# network security level (WPA/WPA2 is preferred), and signal strength.
ctrl_interface=/run/wpa_supplicant
ap_scan=2       # Go directly to the hidden SSID
network={
        ssid="mercury"
        id_str="mercury"
        psk={ ... }
network={
        ssid="sirius24"
        id_str="home"
        scan_ssid=1
        proto=RSN
        key_mgmt=WPA-PSK
        pairwise=CCMP
        group=TKIP CCMP
        psk="{ ... }"
        #psk={ ... }
# dmesg
[Tue Feb 12 14:49:18 2019] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[Tue Feb 12 14:49:18 2019] cfg80211: failed to load regulatory.db
... even though I've put regulatory.db, regulatory.db.5, and regulatory.db.p7s into /lib/firmware.
  Reveal hidden contents
Edited by Tido
added spoiler.. shorted quote - please add a spoiler nexttime yourself, thx
Expand
armbianmonitor -u   tells the reader all the details about your Installation, like Kernel-Version and much more
"Anyone Gotten Wifi to Work?"
Perhaps the proper question is:  Has anyone else had difficulty with wifi?  No, not as of last time I built it.  I will test the current image again just to see, we've had wifi working on Tinker mainline images for over a year.
I tried first the armbian-setup, but it has no provision for WPA2 so it can't connect.  WPA2 is the hard part.  Also, being in Washington and after setting my timezone to L.A., I try to change my repository from Estonia, but my only other choices are China and Bulgaria.
Then I tried NetworkManager, but apparently it's GUI only and there doesn't seem to be an app for LXQt.
Then I stopped/disabled NM and installed ConnMan.  I couldn't make that work and I can't remember why, I believe it was because it would not allow me to set a static IP, which is necessary.
So I was left with trying to do it manually, which I've now failed with.
I'm installing the Armbian image into eMMC, and then updating with the Armbian cli/ascii system, and then installing LXQt.
I was aware of armbianmonitor -u, but:
# armbianmonitor -u
Network/firewall problem detected. Not able to upload debug info.
Please fix this or use "-U" instead and upload whole output manually
System diagnosis information will now be uploaded to gzip: /var/log/armbian-hardware-monitor.log.1.gz: No such file or directory
curl: (6) Could not resolve host: ix.io
Please post the URL in the forum where you've been asked for.
(For some reason the forum software would not allow me to put the above two into the same code block)
I'm coming in on eth0 which does not have gateway set, as wlan0 is supposed to be doing that.  I can no longer bring up wlan0 with the current manual config, as above.
I can't imagine why this is so difficult.
Expand
It happens that Tinkerboard is lying on the table. I only have WPA2 network and (stock) Armbian works fine: http://ix.io/1Bj0 (with nmtui-connect)
Expand
Yup your system is running, looks like about 10 times armbianmonitor got run.  But it doesn't say anything about wifi setup.
I can't get into LXQt using X2Go due to an auth failure which only happens in X2Go, no matter with SSH key automatic, manual, or password.  With command-line no problem.  SSH is set to accept either, but X2Go won't have it.  This TB is headless.
Expand
It's stock Armbian desktop and connection was made by using Network manager. It is the same by using desktop or via CLI.
Expand
Let's move this topic elsewhere since it has nothing to do with Tinkerboard.
  On 2/17/2019 at 6:15 PM, Quantum said:
No idea what forums are available here.  Going to https://forum.armbian.com/forum/ I get, "The page you requested does not exist".  My only other option is Active Threads, and I feature there already.
Expand
You posted it into correct forum. Initially. But since this is most likely not related to this specific board, it gets moved elsewhere.
I now remember discovering nmtui in the past two weeks and trying that too.
I can add and set up the wifi interface just fine.  But when I go to Activate it...
it's not there.
Stop/restart nmtui and the interface is still in Add...
but only eth0 is in Activate.
Maybe this Armbian is impractical/impossible.  Why does everyone say that nmtui works for wifi when it doesn't?  Or is it that it doesn't work on the current release?
Expand
If you messed up network settings and/or use different tools at the same time, it might cause troubles. Start from a clean image and use nmtui tool. It must work that way. If you want to use some other way, you are on your own.
Expand
When I tested this to verify it was not an issue, I burnt a fresh SD card, booted, went to command line, started nmtui, found my WPA2 wifi  (Why use less?), put in the necessary bits, activated it, done.  So, impractical?  I think not.  Please, your frustration is noted, but this has nothing to do with Armbian.
Most current Armbian Armbian_5.75_Tinkerboard_Debian_stretch_next_4.19.20, sha256sum verified.
Plug USB cable between TB and laptop, and /dev/sdb appears in dmesg.
# dd if=Armbian_5.75_Tinkerboard_Debian_stretch_next_4.19.20.img of=/dev/sdb bs=4M status=progress
Take to testbed, plug into eth0 and USB power, it boots to command-line with no fluctuation of red light or power-sag messaged. (3A wall wart)
Boots.  Set wlan0 up like the attached, save, but it is NOT in Activate.  Reboot and wlan0 has no static IP and in nmtui it is NOT in activate.
I am confident now that this is because I have a TB S.  And none of the rest of you has an S.  So Armbian is busted with the TB S.
Can I help with a lshw?  I'd love to, but after the clean install and nmtui, eth0 gets the right IP but is incommunicado.  That is enough.
Expand
Not really. We have own tool which tells more: armbianmonitor -u
It looks like a bug in the driver. When fixed IPs are set, it doesn't work (while it works with first USB based wifi that I have found on the table) ... welcome to the dungeons of single board computers :)
We are usually very happy if those shitty chip/drivers(s) connect and works without too much hassle.
