U-boot does not detect USB to SATA converter
JonSmith
Hi all,
I have a Tronsmart Vega S95 Telos box that I am running armbian 5.76 using an SD card. This works fine, however I would like to boot from a USB to SATA converter instead. It is using a JMicron jms578 which works once Linux has booted however attempting to probe USB devices it prints an error. Is there any way I can make my drive work?
I am using the stock Amlogic U-boot, version information also printed below.
gxb_p200_v1#usb reset
board_usb_stop cfg: 0
(Re)start USB...
USB0:   dwc_usb driver version: 2.94 6-June-2012
USB (0) peri reg base: c0000000
USB (0) use clock source: XTAL input, div: 1
USB (0) base addr: 0xc9000000
Force id mode: Host
dwc_otg: Highspeed device found !
scanning bus 0 for devices... dwc_otg: submit_control_msg: control data phase error (ret = -1)
usb_new_device: Cannot read configuration, skipping device 152d:0578
1 USB Device(s) found
gxb_p200_v1#version
U-Boot 2015.01-ge90bf25-dirty (Nov 27 2015 - 11:21:11)
aarch64-none-elf-gcc (crosstool-NG linaro-1.13.1-4.8-2013.11 - Linaro GCC 2013.10) 4.8.3 20131111 (prerelease)
GNU ld (crosstool-N
Link to comment
Share on other sites
That is correct yes, once the system boots into Armbian the disk is accessible without issue.
I've also managed to enable the built-in SATA port by writing the GPIO registers from u-boot, which is also detected correctly in u-boot (that's a JMicron 2329). I'll make a follow-up post about that.
Link to comment
  • Werner locked this topic
