I've done a discovery : when using current Armbian overlays in 5.0.y thru dynamic loading (aka : /sys/kernel/config/devices-tree/overlays) , although working, it produced the following warning in "dmesg" :
WARNING: memory leak will occur if overlay removed
Example, loading i2c overlays produce :
[   80.494728] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /aliases/i2c0
[   80.494745] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /aliases/i2c1
[   80.494752] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /aliases/i2c2
[   80.494789] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c@1c2ac00/status
[   80.494798] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c@1c2b000/clock-frequency
[   80.494805] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c@1c2b000/status
[   80.494813] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c@1c2b400/status
Googling reveal those links, it is all about overlays refactoring :
https://lkml.org/lkml/2018/10/5/146
https://elinux.org/images/8/86/Overlay_frank.pdf
So, we will have to upgrade those overlays when we get a change ... :unsure:
@martinayotte
Have you started pushing the 5.x stuff up to master yet or would you be willing to work out of a branch from sunxi kernel 5 until its stable?
Might make it easier to divide and conquer on the different surprises
I've done several local builds with success, although some patches are still failing, they don't prevent doing a build.
I will push preliminary stuff soon ...
12 hours ago, Werner said:
4.20 has been archvied https://github.com/armbian/build/releases/tag/sunxi-4.20 so I assume 5.0 can be pushed directly to master. And if it breaks does not matter as it is dev.
Fair enough.  I know the branch conversation has happened more than once on the forum, and generally the added complexity hasnt been appealing.
I suppose viewing armbian as a rolling release and embracing next as "mainline stable" supports the model?
I've committed the initial stuff ! :rolleyes:
Now, I will pursue the patch cleaning ...
Let me know if you are unable to build 5.0.y on some Allwinner boards ...
Crashed on DTS patches for H6 OpiOnePlus
h/arm64/boot/dts/allwinner/overlay/sun50i-a64-spi-jedec-nor.dts:12.13-17.6: Warning (spi_bus_reg): /fragment@0/__overlay__/spiflash: SPI bus unit address format error, expected "0"
arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-spi-jedec-nor.dts:26.13-31.6: Warning (spi_bus_reg): /fragment@1/__overlay__/spiflash: SPI bus unit address format error, expected "0"
  DTC     arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-one-plus.dtb
  HOSTCC  scripts/selinux/mdp/mdp
  DTC     arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-lite2.dtb
  DTC     arch/arm64/boot/dts/allwinner/sun50i-a64-nanopi-a64.dtb
  DTCO    arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-spi-spidev.dtbo
arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi:1006.16-1055.4: ERROR (duplicate_node_names): /thermal-zones: Duplicate node name
arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi:324.22-333.5: ERROR (duplicate_node_names): /soc/efuse@3006000: Duplicate node name
arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi:882.20-892.5: ERROR (duplicate_node_names): /soc/ths@5070400: Duplicate node name
ERROR: Input tree has errors, aborting (use -f to force output)
  DTCO    arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-uart1.dtbo
scripts/Makefile.lib:304: recipe for target 'arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-one-plus.dtb' failed
make[2]: *** [arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-one-plus.dtb] Error 2
make[2]: *** Waiting for unfinished jobs....
  DTCO    arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-uart2.dtbo
  DTCO    arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-uart3.dtbo
arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-spi-spidev.dts:20.11-25.6: Warning (spi_bus_reg): /fragment@1/__overlay__/spidev: SPI bus unit address format error, expected "0"
arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-spi-spidev.dts:34.11-39.6: Warning (spi_bus_reg): /fragment@2/__overlay__/spidev: SPI bus unit address format error, expected "0"
  DTCO    arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-uart4.dtbo
scripts/Makefile.lib:304: recipe for target 'arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-lite2.dtb' failed
make[2]: *** [arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-lite2.dtb] Error 2
  HOSTCC  scripts/pnmtologo
ill try some other boards.
Similar failure with H5 OpiPC2.   Seems to be building for H3 OpiLite okay.
23 minutes ago, martinayotte said:
I've commit few more things, maybe you can try it again ...
Looking much better.. currently building h6 Opioneplus
34 minutes ago, martinayotte said:
Great ! Happy 5.0.y ! :D
totally!
lane@orangepioneplus:~$ sudo armbianmonitor -z
[sudo] password for lane:
Preparing benchmark. Be patient please...
7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21
p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,4 CPUs LE)
LE
CPU Freq:   626  1793  1798  1798  1798  1798  1798  1798  1798
RAM size:     991 MB,  # CPU hardware threads:   4
RAM usage:    882 MB,  # Benchmark threads:      4
                       Compressing  |                  Decompressing
Dict     Speed Usage    R/U Rating  |      Speed Usage    R/U Rating
         KiB/s     %   MIPS   MIPS  |      KiB/s     %   MIPS   MIPS
22:       2759   341    787   2685  |      71940   398   1541   6138
23:       2708   351    787   2760  |      66875   398   1454   5786
24:       2573   358    773   2767  |      64136   396   1421   5630
25:       1668   274    694   1905  |      61379   394   1387   5463
Avr:             331    760   2529  |              397   1451   5754
Tot:             364   1105   4142
Monitoring output recorded while running the benchmark:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
03:39:01: 1800MHz  0.03  17%   1%  11%   0%   3%   0% 49.7°C  0/7
03:39:06:  480MHz  0.02   0%   0%   0%   0%   0%   0% 49.9°C  0/7
03:39:11: 1800MHz  0.02   1%   0%   0%   0%   0%   0% 49.7°C  0/7
03:39:16: 1800MHz  0.42  59%   1%  57%   0%   0%   0% 69.3°C  0/7
03:39:21: 1320MHz  0.71  95%   0%  94%   0%   0%   0% 75.9°C  2/7
03:39:26: 1800MHz  0.97  87%   1%  85%   0%   0%   0% 74.0°C  0/7
03:39:32: 1800MHz  1.21  96%   0%  95%   0%   0%   0% 75.8°C  0/7
03:39:37: 1800MHz  1.44  80%   1%  78%   0%   0%   0% 74.2°C  0/7
03:39:42: 1320MHz  1.72  92%   1%  90%   0%   0%   0% 68.7°C  0/7
03:39:48: 1800MHz  1.91  95%   1%  94%   0%   0%   0% 71.1°C  2/7
03:39:54: 1800MHz  2.07  77%   1%  75%   0%   0%   0% 68.9°C  0/7
03:39:59: 1800MHz  2.23  86%   1%  84%   0%   0%   0% 75.5°C  2/7
03:40:04: 1800MHz  2.65  91%   1%  89%   0%   0%   0% 69.6°C  0/7
03:40:09: 1320MHz  2.76  96%   1%  94%   0%   0%   0% 77.0°C  2/7
03:40:27: 1800MHz  3.86  88%  27%  37%   0%  23%   0% 73.8°C  0/7
03:40:33: 1800MHz  3.71  76%   6%  69%   0%   0%   0% 73.4°C  0/7
Uhh so i installed mate desktop...and other than stuck with a 1024x768 modeline... the display driver is crazy fast!
NanoPi Neo2 (non-LTS) also running here with Kernel 5.0.1
i2c0-overlay doesnt show a memory-leak in dmesg
UTF8-charset doesnt seem to work right (lines around the menu) while using de-utf8
[EDIT] also doesnt work on one of my Neo2 with 4.20.7-sunxi64, but one does show it right.
and I copied the putty-session-settings...so putty shouldnt be the problem :(
The memory-leak issue is not when overlays are loaded by U-boot, but only when loaded dynamically using Overlay-FS, aka via /sys/kernel/config/device-tree/overlays/ from userspace, for example :
mkdir /sys/kernel/config/device-tree/overlays/myoverlay
cat myoverlay.dtbo > /sys/kernel/config/device-tree/overlays/myoverlay/dtbo
cat /sys/kernel/config/device-tree/overlays/myoverlay/status
OK, I was thinking about the (dynamic) i2c0 overlay from armbian-config --> /boot/armbianEnv.txt
root@npi-neo2-24(192.168.6.24):/boot# more armbianEnv.txt
verbosity=1
console=serial
overlay_prefix=sun50i-h5
overlays=analog-codec i2c0 usbhost1 usbhost2
rootdev=UUID=d58b2d2f-75c0-411e-b9b9-f5343f6bf276
rootfstype=ext4
Right ! Those are Ok !
That one of the reason there is no hurry to fix memory-leak issue, since I'm probably the only one who is using "dynamic" userspace method ... :lol:
