martinayotte Posted March 13, 2019 Share Posted March 13, 2019 I've done a discovery : when using current Armbian overlays in 5.0.y thru dynamic loading (aka : /sys/kernel/config/devices-tree/overlays) , although working, it produced the following warning in "dmesg" : WARNING: memory leak will occur if overlay removed Example, loading i2c overlays produce : [ 80.494728] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /aliases/i2c0 [ 80.494745] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /aliases/i2c1 [ 80.494752] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /aliases/i2c2 [ 80.494789] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c@1c2ac00/status [ 80.494798] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c@1c2b000/clock-frequency [ 80.494805] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c@1c2b000/status [ 80.494813] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/i2c@1c2b400/status Googling reveal those links, it is all about overlays refactoring : https://lkml.org/lkml/2018/10/5/146 https://elinux.org/images/8/86/Overlay_frank.pdf So, we will have to upgrade those overlays when we get a change ... Link to comment Share on other sites More sharing options...
lanefu Posted March 13, 2019 Share Posted March 13, 2019 Hmmm so temporarily not dynamic Link to comment Share on other sites More sharing options...
lanefu Posted March 13, 2019 Share Posted March 13, 2019 @martinayotte Have you started pushing the 5.x stuff up to master yet or would you be willing to work out of a branch from sunxi kernel 5 until its stable? Might make it easier to divide and conquer on the different surprises Link to comment Share on other sites More sharing options...
Werner Posted March 14, 2019 Share Posted March 14, 2019 4.20 has been archvied https://github.com/armbian/build/releases/tag/sunxi-4.20 so I assume 5.0 can be pushed directly to master. And if it breaks does not matter as it is dev. Link to comment Share on other sites More sharing options...
martinayotte Posted March 14, 2019 Author Share Posted March 14, 2019 I've done several local builds with success, although some patches are still failing, they don't prevent doing a build. I will push preliminary stuff soon ... 1 Link to comment Share on other sites More sharing options...
lanefu Posted March 14, 2019 Share Posted March 14, 2019 12 hours ago, Werner said: 4.20 has been archvied https://github.com/armbian/build/releases/tag/sunxi-4.20 so I assume 5.0 can be pushed directly to master. And if it breaks does not matter as it is dev. Fair enough. I know the branch conversation has happened more than once on the forum, and generally the added complexity hasnt been appealing. I suppose viewing armbian as a rolling release and embracing next as "mainline stable" supports the model? Link to comment Share on other sites More sharing options...
martinayotte Posted March 14, 2019 Author Share Posted March 14, 2019 9 hours ago, martinayotte said: I will push preliminary stuff soon ... I've committed the initial stuff ! Now, I will pursue the patch cleaning ... Let me know if you are unable to build 5.0.y on some Allwinner boards ... 1 Link to comment Share on other sites More sharing options...
lanefu Posted March 15, 2019 Share Posted March 15, 2019 1 hour ago, martinayotte said: I've committed the initial stuff ! Now, I will pursue the patch cleaning ... Let me know if you are unable to build 5.0.y on some Allwinner boards ... Crashed on DTS patches for H6 OpiOnePlus Spoiler h/arm64/boot/dts/allwinner/overlay/sun50i-a64-spi-jedec-nor.dts:12.13-17.6: Warning (spi_bus_reg): /fragment@0/__overlay__/spiflash: SPI bus unit address format error, expected "0" arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-spi-jedec-nor.dts:26.13-31.6: Warning (spi_bus_reg): /fragment@1/__overlay__/spiflash: SPI bus unit address format error, expected "0" DTC arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-one-plus.dtb HOSTCC scripts/selinux/mdp/mdp DTC arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-lite2.dtb DTC arch/arm64/boot/dts/allwinner/sun50i-a64-nanopi-a64.dtb DTCO arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-spi-spidev.dtbo arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi:1006.16-1055.4: ERROR (duplicate_node_names): /thermal-zones: Duplicate node name arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi:324.22-333.5: ERROR (duplicate_node_names): /soc/efuse@3006000: Duplicate node name arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi:882.20-892.5: ERROR (duplicate_node_names): /soc/ths@5070400: Duplicate node name ERROR: Input tree has errors, aborting (use -f to force output) DTCO arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-uart1.dtbo scripts/Makefile.lib:304: recipe for target 'arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-one-plus.dtb' failed make[2]: *** [arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-one-plus.dtb] Error 2 make[2]: *** Waiting for unfinished jobs.... DTCO arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-uart2.dtbo DTCO arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-uart3.dtbo arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-spi-spidev.dts:20.11-25.6: Warning (spi_bus_reg): /fragment@1/__overlay__/spidev: SPI bus unit address format error, expected "0" arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-spi-spidev.dts:34.11-39.6: Warning (spi_bus_reg): /fragment@2/__overlay__/spidev: SPI bus unit address format error, expected "0" arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi:1006.16-1055.4: ERROR (duplicate_node_names): /thermal-zones: Duplicate node name arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi:324.22-333.5: ERROR (duplicate_node_names): /soc/efuse@3006000: Duplicate node name arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi:882.20-892.5: ERROR (duplicate_node_names): /soc/ths@5070400: Duplicate node name DTCO arch/arm64/boot/dts/allwinner/overlay/sun50i-a64-uart4.dtbo ERROR: Input tree has errors, aborting (use -f to force output) scripts/Makefile.lib:304: recipe for target 'arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-lite2.dtb' failed make[2]: *** [arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-lite2.dtb] Error 2 HOSTCC scripts/pnmtologo ill try some other boards. Link to comment Share on other sites More sharing options...
lanefu Posted March 15, 2019 Share Posted March 15, 2019 Similar failure with H5 OpiPC2. Seems to be building for H3 OpiLite okay. Link to comment Share on other sites More sharing options...
martinayotte Posted March 15, 2019 Author Share Posted March 15, 2019 1 hour ago, lanefu said: Similar failure with H5 OpiPC2 I've commit few more things, maybe you can try it again ... Link to comment Share on other sites More sharing options...
lanefu Posted March 15, 2019 Share Posted March 15, 2019 23 minutes ago, martinayotte said: I've commit few more things, maybe you can try it again ... Looking much better.. currently building h6 Opioneplus Link to comment Share on other sites More sharing options...
martinayotte Posted March 15, 2019 Author Share Posted March 15, 2019 2 minutes ago, lanefu said: Looking much better.. currently building h6 Opioneplus Great ! Happy 5.0.y ! Link to comment Share on other sites More sharing options...
lanefu Posted March 15, 2019 Share Posted March 15, 2019 34 minutes ago, martinayotte said: Great ! Happy 5.0.y ! totally! Spoiler lane@orangepioneplus:~$ sudo armbianmonitor -z [sudo] password for lane: Preparing benchmark. Be patient please... 7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,4 CPUs LE) LE CPU Freq: 626 1793 1798 1798 1798 1798 1798 1798 1798 RAM size: 991 MB, # CPU hardware threads: 4 RAM usage: 882 MB, # Benchmark threads: 4 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 2759 341 787 2685 | 71940 398 1541 6138 23: 2708 351 787 2760 | 66875 398 1454 5786 24: 2573 358 773 2767 | 64136 396 1421 5630 25: 1668 274 694 1905 | 61379 394 1387 5463 ---------------------------------- | ------------------------------ Avr: 331 760 2529 | 397 1451 5754 Tot: 364 1105 4142 Monitoring output recorded while running the benchmark: Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 03:39:01: 1800MHz 0.03 17% 1% 11% 0% 3% 0% 49.7°C 0/7 03:39:06: 480MHz 0.02 0% 0% 0% 0% 0% 0% 49.9°C 0/7 03:39:11: 1800MHz 0.02 1% 0% 0% 0% 0% 0% 49.7°C 0/7 03:39:16: 1800MHz 0.42 59% 1% 57% 0% 0% 0% 69.3°C 0/7 03:39:21: 1320MHz 0.71 95% 0% 94% 0% 0% 0% 75.9°C 2/7 03:39:26: 1800MHz 0.97 87% 1% 85% 0% 0% 0% 74.0°C 0/7 03:39:32: 1800MHz 1.21 96% 0% 95% 0% 0% 0% 75.8°C 0/7 03:39:37: 1800MHz 1.44 80% 1% 78% 0% 0% 0% 74.2°C 0/7 03:39:42: 1320MHz 1.72 92% 1% 90% 0% 0% 0% 68.7°C 0/7 03:39:48: 1800MHz 1.91 95% 1% 94% 0% 0% 0% 71.1°C 2/7 03:39:54: 1800MHz 2.07 77% 1% 75% 0% 0% 0% 68.9°C 0/7 03:39:59: 1800MHz 2.23 86% 1% 84% 0% 0% 0% 75.5°C 2/7 03:40:04: 1800MHz 2.65 91% 1% 89% 0% 0% 0% 69.6°C 0/7 03:40:09: 1320MHz 2.76 96% 1% 94% 0% 0% 0% 77.0°C 2/7 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 03:40:27: 1800MHz 3.86 88% 27% 37% 0% 23% 0% 73.8°C 0/7 03:40:33: 1800MHz 3.71 76% 6% 69% 0% 0% 0% 73.4°C 0/7 1 Link to comment Share on other sites More sharing options...
lanefu Posted March 15, 2019 Share Posted March 15, 2019 Uhh so i installed mate desktop...and other than stuck with a 1024x768 modeline... the display driver is crazy fast! 1 Link to comment Share on other sites More sharing options...
Werner Posted March 15, 2019 Share Posted March 15, 2019 Awesome. I'll give the OPi1+ a shot on dev as well soon. Link to comment Share on other sites More sharing options...
guidol Posted March 15, 2019 Share Posted March 15, 2019 NanoPi Neo2 (non-LTS) also running here with Kernel 5.0.1 i2c0-overlay doesnt show a memory-leak in dmesgUTF8-charset doesnt seem to work right (lines around the menu) while using de-utf8 [EDIT] also doesnt work on one of my Neo2 with 4.20.7-sunxi64, but one does show it right. and I copied the putty-session-settings...so putty shouldnt be the problem Link to comment Share on other sites More sharing options...
martinayotte Posted March 15, 2019 Author Share Posted March 15, 2019 14 minutes ago, guidol said: i2c0-overlay doesnt show a memory-leak in dmesg The memory-leak issue is not when overlays are loaded by U-boot, but only when loaded dynamically using Overlay-FS, aka via /sys/kernel/config/device-tree/overlays/ from userspace, for example : mkdir /sys/kernel/config/device-tree/overlays/myoverlay cat myoverlay.dtbo > /sys/kernel/config/device-tree/overlays/myoverlay/dtbo cat /sys/kernel/config/device-tree/overlays/myoverlay/status Link to comment Share on other sites More sharing options...
guidol Posted March 15, 2019 Share Posted March 15, 2019 5 minutes ago, martinayotte said: The memory-leak issue is not when overlays are loaded by U-boot, but only when loaded dynamically using Overlay-FS, aka via /sys/kernel/config/device-tree/overlays/ from userspace, OK, I was thinking about the (dynamic) i2c0 overlay from armbian-config --> /boot/armbianEnv.txt Spoiler root@npi-neo2-24(192.168.6.24):/boot# more armbianEnv.txt verbosity=1 console=serial overlay_prefix=sun50i-h5 overlays=analog-codec i2c0 usbhost1 usbhost2 rootdev=UUID=d58b2d2f-75c0-411e-b9b9-f5343f6bf276 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Link to comment Share on other sites More sharing options...
martinayotte Posted March 15, 2019 Author Share Posted March 15, 2019 2 minutes ago, guidol said: overlays=analog-codec i2c0 usbhost1 usbhost2 Right ! Those are Ok ! That one of the reason there is no hurry to fix memory-leak issue, since I'm probably the only one who is using "dynamic" userspace method ... 1 Link to comment Share on other sites More sharing options...
