martinayotte Posted March 15, 2019 Posted March 15, 2019 Just to let people know that since I'm running kernel 5.0.y, I found that most of the WiFi firmware is now trying to load their NVRAM using a new file naming scheme, for example : On my OrangePi3, it try to load "brcmfmac43455-sdio.xunlong,orangepi-3.txt" instead of the normal "brcmfmac43455-sdio.txt", until I copied the file, no WiFi available. On my OPiZeroPlus2, it try to load "brcm/brcmfmac43430-sdio.xunlong,orangepi-zero-plus2.txt", but on this one it seems to fall back using the normal file and WiFi is working. On my OPiLite2, it try to load "brcm/brcmfmac43455-sdio.pine64,pine-h64.txt", revealing a mistake in the DT compatible ... ... I will fix that ! (but fall back work there too). BTW, all this seems to be with BRCM, I've not seeing that with RTL8723 ...
guidol Posted March 16, 2019 Posted March 16, 2019 some time ago @balbes150 did create images for TV-Boxes with kernel 5.0.y and there we/i got the same "problem". armbian was on my TV-Box searching for /lib/firmware/brcm/brcmfmac4330-sdio.amlogic,q201.txt
jernej Posted March 16, 2019 Posted March 16, 2019 That is not a problem but actually an improvement. NVRAM settings are usually tuned to board.
Heverton Campos Posted July 17, 2020 Posted July 17, 2020 Onde encontro esta img: Armbian_5.73_Aml-s912_Debian_stretch_next_5.0.0-rc4-next-20190130-g02495e76d-dirty.img ?
Werner Posted July 18, 2020 Posted July 18, 2020 12 hours ago, Heverton Campos said: Onde encontro esta img: Armbian_5.73_Aml-s912_Debian_stretch_next_5.0.0-rc4-next-20190130-g02495e76d-dirty.img ? Main language here is English. If you are unable to write so please use a translator at least. Nobody will care about your post otherwise.
