Helios-64 Fails to boot since upgrading to Bookworm
Carlos Hartmann replied to Carlos Hartmann's topic in Rockchip
baudrate: indeed at 1500000 The serial actually did not work before. Back when I first installed the Helios I used a C-A cable. Now I gave it a try with one and it improved the behavior: instead of appearing and disappearing, the usbserial device is now constant. The issue is just that nothing is shown via `screen`. I think I'll try by inserting a HDD because of what you said. I remember the USB-C cable issue. To be sure, I had removed a sliver of plastic using a cutter just like I did a couple years ago. No issues with clarity, I know about that quirk of the Helios. But yeah, this was not the issue now as I only worked with "modified" USB-C connectors. I unmounted the "disk" (SD card) before working with it. That should be safe as nothing tried mounting it afterward. Was the whole thing written: The `dd` command finished and balena Etcher even confirmed that the Flash was complete. So I think this is also a yes. conv=fsync: No I did not do this. Repeating the whole procedure with this and then after reinserting, I'll get a sha256sum of the contents… It worked, the resulting sha256sum is identical. Just trying to boot the machine again… Same behavior, sadly. HDD not yet inserted btw, will do that tomorrow. - Today
Great, so I used the config file provided in the previous post that I quoted, with a small change: I replaced "LINUXFAMILY" with "BOARDFAMILY". Am I to place patches to the kernel and u-boot inside userpatches? When in the build process should I do that? U-boot does work currently, and the original problem when I try to boot is that after "Starting Kernel..." I have nothing visible over HDMI or on the on board display (Or no way to check that I know of if anything is working). What I understand currently is that since U-boot works, I need to first provide a dts file that makes the display work, and then configure armbian build script to use that dts file, is that the way to go? On linux-sunxi mailing list I was told that the display on this works with the simple panel driver using the "starry kr070pe2t" entry. At this point I am not sure what the immediate next step should be. Thank you! -
I have having the same issue as discussed here & it also provided solution for it https://github.com/IceWhaleTech/CasaOS/issues/1136 I have added cgroup_enable=cpuset cgroup_enable=memory cgroup_memory=1 to armbianEnv.txt The dmesg logs indicate that these arguments are failing [ 15.630904] Kernel command line: root=UUID=eb6a27ef-3932-431f-92fd-e61fea75356c rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=f3aeb909-d11b-ec42-a52c-4507e474335c usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u,0x1058:0x25a2:u cma=256M cgroup_enable=cpuset cgroup_enable=memory cgroup_memory=1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory [ 15.631910] Unknown kernel command line parameters "splash=verbose ubootpart=f3aeb909-d11b-ec42-a52c-4507e474335c cgroup_enable=memory cgroup_memory=1", will be passed to user space. . . . [ 18.261976] Run /init as init process [ 18.262019] with arguments: [ 18.262028] /init [ 18.262034] with environment: [ 18.262039] HOME=/ [ 18.262044] TERM=linux [ 18.262049] splash=verbose [ 18.262054] ubootpart=f3aeb909-d11b-ec42-a52c-4507e474335c [ 18.262060] cgroup_enable=memory [ 18.262065] cgroup_memory=1 [ 18.263469] mmcblk1: p1 p2 The bug still haunts me, any ideas how should I approach this problem
I have questions about 1 building a full image that supports the Orange Pi 5 Pro. From my understanding of building the kernel - the supported modules for the chipset need to be built for the specific SBC card. I can easily access the correct kernel I would like. What I am lacking is an understanding of what source images to install on my build platform for the modules and what the the configuration settings specific to the SBC. Can someone clue me in? I haven't built a kernel in 20 years. I can try to make a case for Armbian to support the OPI 5 Pro or Max. But this isn't the right forum for that, I prefer the Pro or Max over the Plus as I do not need all those HDMI ports. My goal is to build two kernels - one on SMB Pre-emptive and one RT PREEMPTIVE - specifically for the Orange Pi 5 PRO and two images with all the I/O functional. Evidently the Armbian official builds are for the Orange Pi 5B and the Plus. I haven't exhaustively gone through all of the community supported offerings.
DKMS is 'quite complicated' , in an attempt to understand all that 'cryptic' stuff, I went googling around https://wiki.archlinux.org/title/Dynamic_Kernel_Module_Support https://www.linuxjournal.com/article/6896 https://github.com/dell/dkms https://wiki.gentoo.org/wiki/DKMS https://www.collabora.com/news-and-blog/blog/2021/05/05/quick-hack-patching-kernel-module-using-dkms/ https://www.baeldung.com/linux/dynamic-kernel-module-support https://nilrt-docs.ni.com/opkg/dkms_opkg.html ^ surprisingly I found this guide/tutorial from national instruments 'quite intuitive' and I dug further into how to make a kernel module, well at least a 'hello world' https://tldp.org/LDP/lkmpg/2.6/html/ https://tldp.org/LDP/lkmpg/2.6/lkmpg.pdf The Linux Kernel Module Programming Guide Peter Jay Salzman Michael Burian Ori Pomerantz Copyright © 2001 Peter Jay Salzman --- ok I actually tried building that 'hello world' kernel module and *it works*, for practically 'ancient' 2001 instructions. so it turns out that to compile a kernel module, you do not need to build it in the kernel source tree itself and that is *without* DKMS, read that last 2 tldp guides: The Linux Kernel Module Programming Guide you can try building and inserting the 'hello world' module into your kernel, no DKMS, whatever, after you build your module ! in short is it not necessary to build a kernel module within the kernel source tree itself, but that there are some procedures as spelled out in that 2 tldp docs. (but fast forward to today, this same instruction may not work if you are using secure boot, then a lot more complicated things like module signing gets involved, review that dkms link from dell) ------- now back to DKMS , where does that fit in? so it turns out that DKMS is a utility / tool / system / automation tool, to help you *rebuild the kernel module* - out of linux kernel source tree (i.e. as like the hello world module above), *without building the kernel from source itself* ! but that you need to ***rebuild the kernel module from source***(e.g. using DKMS), then all the other links above are guides that may be relevant ---- now add more complications / complexities, normally what you wanted is a *driver* , not simply a kernel module the driver often has several parts - the kernel module itself (this is the 'easy' part, you need to build it - from source), and that does not mean having to build the kernel itself from source, but you need to build the *kernel *** module *** *. after you build the kernel module successfully, say, then there are more blows and pitfall these days wifi and many network hardware requires *firmware files* , these *firmware files* can consist of 'bin' (firmware binary) and configuration (some of them text files) some of these firmware stuff lives in /lib/firmware. then that you need your kernel module, you can deem that the 'driver core' that interface the OS and interface those firmware. those firmware do not necessary run on the (host) cpu (i.e. your pc) but instead in the wifi chip itself. this is the part that is *highly opaque*, there are so many wifi chips that are *undocumented*, the firmware is *undocumented* and if you do not have any source for your kernel module which interface the firmware to the os, you are out-of-luck. ----- to summarise - normally, one cannot hope to take a binary kernel module install it in your current kernel and hope it 'just works'. if that works, a lot of things such as module versions and various constraints imposed by the kernel matches that in the kernel module itself, i.e. that module is compiled specifically for that specific kernel itself ! DKMS do not solve this, DKMS only *helps you rebuild the (kernel) module *** from source *** *, (and install it optionally). the idea is this, you have the *source* to your out of kernel source *kernel modules*, when you upgrade the kernel, e.g. such as an apt-upgrade etc, DKMS can be triggered to *rebuild the kernel module from source* (and install it) in the new kernel (binary) tree e.g. copy that into /lib/modules/{kernel version}/xxx --- if the kernel module is part of the kernel source tree itself, it actually do not need DKMS. But that if the errors occurs after building that *kernel module* (i.e. driver) , then congrats - you found a 'bug' in the *kernel module (driver)*, and that is true even if it is out of kernel source as a DKMS build. i.e. the driver sources need to be patched to work in the new kernel.
my current timezone is PST (suppose to be PH starndard time) configured via raspi-config, im guessing it is confusing itself with PST (Pacific standard time US). it really messing with my TZ. For my part the only workaround is to set it manually before i can upgrade the system $ TZ=':UTC'; export TZ
CRDA is deprecated, not needed since Linux 4.15, hence the package removed with Debian Bookworm. Problem is the default regulatory database on Debian works with Debian kernel only, not with Armbian kernel. But wireless-regdb provides the upstream database as well, so you only need to switch: sudo update-alternatives --set regulatory.db /lib/firmware/regulatory.db-upstream
You could try to create chromium.conf yourself. Here's what I have here: cat /etc/armbian/chromium.conf # Default settings for chromium-browser. This file is sourced by /bin/sh from # /usr/bin/chromium-browser # Options to pass to chromium-browser CHROMIUM_FLAGS="--disable-smooth-scrolling \ --disable-low-res-tiling \ --enable-low-end-device-mode \ --num-raster-threads=$(grep -c processor /proc/cpuinfo) \ --profiler-timing=0 \ --disable-composited-antialiasing \ --disk-cache-dir=/tmp/${USER}-cache \ --disk-cache-size=$(findmnt --target /tmp -n -o AVAIL -b | awk '{printf ("%0.0f",$1*0.3); }') \ --no-sandbox \ --test-type"
ricardo_brz replied to ずっと一人's topic in Orange Pi 5 Plus
Armbian already is! uname -a Linux orangepi5-plus 6.15.0-edge-rockchip64 #1 SMP PREEMPT Sun May 25 23:09:23 UTC 2025 aarch64 GNU/Linux Itś on edge, but it's working fine here, apart from the analog audio... -
Created another standalone version of script for this ... https://gist.github.com/avatar21/e0deca347665bd620d0ea3f9f299028e I believe we need to compile our own armbian/ Kernel 6.13 (or above? because as @elvis claimed user driver is only 1/2 of the equation) before running this script ya? all copy/ flatten to a temp/fake root folder (where I understand the chroot sdcard means, build to a fakeroot not patching existing OS) and repackage as an img file ya? Or better still, can someone compile the whole thing? start from burning image ...
mvpwar replied to Hqnicolas's topic in Rockchip CPU Boxes
Thanks for your help, and I found the official image not support NPU, only Joshua-Riek image support? @Hqnicolas root@h96-tvbox-3566:~# ls /dev/dri/ by-path card0 card1 renderD128 -
During the first few boots on my Orange Pi Zero 3 1GB, RAM size seemed to be detected correctly. Yesterday I saw RAM size being reported as 2GB, also after a reboot. As soon as the fixed U-Boot is available to install I am happy to provide test results or other test procedures when needed!
Glade to see you back @sicxnull. Thanks for the shoutout! Tried my best while you were gone. I don’t own one of these boxes. But I guess it doesn’t matter which one I get because theirs so many variations of the same box.
I try your prebuild image, and no luck with wifi/Bluetooth. My tv box new revision and have YC8800D wifi chip. Can i do something to get work WiFi?
Rockchip devices generally cannot be bricked. Short the maskrom pin i showed you and reflash. You can build the image from source or from here https://github.com/armbian/community/releases
I have T95Z Plus w/ H618 and my TV box new revision. It has another wifi chip YC8800D. tried to run this build https://github.com/LYU4662/t95zplus-h618-build It work fine but no wifi and Bluetooth. Looks like it made already with 8800 driver, but system does recognize any wireless interfaces. Also try to run community build Armbian-unofficial_25.05.0-trunk_Vontar-h618_bookworm_edge_6.12.11_server Its running good, but still no wifi and Bluetooth. In android /vendor/lib/modules found attached modules. Can i use them to get work wifi? aic8800_bsp.ko aic8800_btlpm.ko aic8800_fdrv.ko
Trouble getting hardware decoding to work on Rock 5 ITX
Werner replied to bucknaked's topic in Radxa Rock 5 ITX
Try looking for hints here: https://jellyfin.org/docs/general/post-install/transcoding/hardware-acceleration/rockchip/ They use mali blobs for hw en-/decoding. -
I2C not working on Orange Pi Zero2
Yordan Yanakiev replied to Yordan Yanakiev's topic in Allwinner sunxi
seems like the config should be distinguishing by models, not by .. idk even what it is. let say config->OrangePi2->hardware->peripherals->i2c->i2's enumerate. -
All the kernel panic options that you have shown here occur on v6.12.23. It all happens randomly. I suspect that this may be due to the presence of broken (faulty) blocks on the memory device. It's easy to check this.If you connect the SD card via an adapter to a Linux computer: sudo fsck.ext4 /dev/sdX1
Almero Ramadhan Insan wibowo replied to jock's topic in Rockchip CPU Boxes
does anyone know how to get maskrom and uart on this rk3228a board from mxq pro 4k 5G since pushing the little button shows up as armlogic devices on device manager but the actual chip is rockchip and sorry for bad quality images - Last week
For production, boxes are much more interesting than boards. We just need to deal with a honest manufacturer. The last dtb from @mmie4jbcu worked very well for me in a x88 pro 20.
Build Image with Debian 12 VM on QubesOS
joejoe44 replied to joejoe44's topic in Advanced users - Development
That solves it thank you very much for your time! If I want to change between boards like Rockpro64, Raspberry Pi4, etc. is there anything that needs to be considered as far as "reset" to a fresh state. For the guide I am writing I would like to make sure there is no lingering configuration that could cause problems when switching between builds for different boards. -
How to enable sound on a server version of Armbian
Hooutoo replied to ubhelbr's topic in Orange Pi 5 Plus
All things being equal....... steve@fedora43:~$ uname -a Linux fedora43 6.16.0-0.rc0.250528gfeacb1774bd5.5.fc43.aarch64 #1 SMP PREEMPT_DYNAMIC Wed May 28 19:45:02 UTC 2025 aarch64 GNU/Linux kernel-6.16.0-0.rc0.250529g90b83efa6701.6.fc43. created by jforbes 6 hours ago for Fedora 43 .
