KrzyPacu replied to Jean-Francois Lessard's topic in Amlogic meson
Is it enough to remove these entries from the dts file and recompile it to dtb? 3535-3540 openvfd { compatible = "open,vfd"; dev_name = "openvfd"; status = "okay"; phandle = <0x143>; }; 4031 openvfd = "/openvfd"; meson-sm1-x96-air-gbit.dts -
Armbian_25.2.2_Rock-5-itx_noble_vendor_6.1.99_gnome_desktop.img.xz I first tried this, as it was the first version offered at the top of the page. No matter what I tried, sound would *not* work. Not speakers, not HDMI, nada, zip. I then started trying earlier versions further down the page. Armbian_25.2.2_Rock-5-itx_bookworm_vendor_6.1.99_cinnamon-backported-mesa_desktop.img.xz And this one, sound *did* work, at least through the speaker jack anyway, but I suspect HDMI would too. I'm really suspecting something kernel related is going here (that "Rockchip BSP" note right above it makes me suspect that). In any case, I'd like to use the kernel where sound is working and put a gnome shell in front of it. Which I take means digging into the build system for armbian? I can figure that out on my own but before I get started on that, what I'm looking for from the forumistas, is an indication of which specific kernel I need to use to make sure sound works. What do I need to make sure to specify so I get the behavior of that second install that worked? And Cinnamon may be better or something, but gnome is what I'm used to.
FYI. HDMI out is broken on those board at the moment. Try to access the board remotely. We don't have people to maintain those old boards.
looks like a kernel oops does the unit run properly afterwards?
Thank you for that information. From a cursory look, it seems as if that is only binary images, no source (violating GPL). -
I will try to make that easier and more automatic with APA, eventually.
laibsch replied to Shakai2's topic in Allwinner sunxi
Thank you for letting us know as it allows an interested party to more easily bisect the regression. -
download all files attenmented . sudo cp *.dtbo /boot/dtb/allwinner/overlay open /boot/armbianEnv.txt , add this line: overlays=spi-spidev spidev1_1 and reboot, you should find and use /dev/spidev1.1 sun50i-h616-spidev1_0.dtbo sun50i-h616-spidev1_0.dtso sun50i-h616-spidev1_1.dtbo sun50i-h616-spidev1_1.dtso
rock pi 4 plus v1.73 It's not booting, help!
SteeMan replied to Nickolas M. Rebouças's topic in Rockchip
Moved to Community supported forum as this isn't a standard support board. -
OrangePi 4A Bluetooth Mouse Keyboard connectivity issue Solved The solution to the problem when mouse pairs / connects with BT but doesnt work Prebuilt kernel files are available https://github.com/defencedog/orangepi4A/blob/main/Bluetooth%20Mouse%20Not%20Working%20Solved.md
True. Also on most computers we have eth0 Not just eth Devices naming is a cosmetic thing from the outside / user perspection, while it has consistency issue from the inside and currently breaks initial (default netplan) configuration. Our job is not to tell user how to configure his network, but that network devices gets up at first boot. Now they do. Job done.
Hi Loeriver, Where is the other end of your USB serial dongle connected to? Can you check there if the dongle had disappeard from the USB bus and re-appeared around the same time? In my "professional" life we have had workstations mysteriously reboot whenever we would power cycle the device hosting the USB to serial device. Even though you say it's not related, if this is still mysterious, best to check under each stone... Groetjes,
From the picture - I can only guess that kernel package was somehow not upgraded properly as kernel image files are missing. Perhaps they were removed by accident or there was some disk / file system troubles involved. @Chris007 Try hints from here: https://docs.armbian.com/User-Guide_Troubleshooting/
Werner replied to Nguyễn Tất Hùng's topic in Amlogic CPU Boxes
Okay, then you have to adjust the source to mitigate the issue. Also log excerpts are often useless. My random guess is that uboot is some old outdated version depending on python2 which has been deprecated years ago. -
Last month in Nice, active media developers came together for the annual Linux Media Summit to exchange insights and tackle ongoing challenges in the media subsystem. Here’s a brief summary of the key discussions and upcoming areas of focus. View the full article
Odroid C4 is using HC4 dtb and odroidhc4 packages
spleeth replied to spleeth's topic in Amlogic meson
To anyone this may help, removing hc4 related packages and replacing them with c4 packages did the job. Only to discover that, for whatever reason, I actually had an HC4 board and convince myself that it was a C4 ... Anyway, the reverse process also worked as expected and my board is now running 25.051.1 happily, except for the samsung SSD not recognized at boot, and requires to be hot plugged just after the linux kernel starts in order to be seen by the system, as it is described in other threads. - Last week
As far as I know openvfd needs to be re-worked to support 6.12.y and up. EDIT: I stand corrected. I found a working patch at unifreq. It needs to be patched against the source-tree. 0001-drv-auxdisplay-Add-openvfd-driver.patch
@junji. Can you explain me how you proceed to boot this OS image Armbian-unofficial_25.05.0-trunk_X96q-lpddr3-v1-3_bookworm_edge_6.12.11_xfce_desktop.img.xz ?
For a few weeks I've been using the latest official release from May 26, 2025, running just fine from my NVME drive. But then I turned it on and at the screen where you get the Amrbian grey/red logo in the middle of the screen and the spinning circle, it went no further. The spinning circle would either stop rotating or disappear after a minute or so. I can SSH into the device. But when I use remote desktop from a Windows PC, the full and functioning desktop is there. It's just not on my TV screen any more. I've done the usual HDMI cable testing and powering off the TV completely, but no change. The fact that the desktop is accessible remotely does indicate that it must be loading in some fashion. Took a log here: https://paste.next.armbian.com/qococumoga
Kernel 6.12.20 Banana Pi M2 zero USB doesn't work
laibsch replied to Bernd's topic in Allwinner sunxi
Thank you for letting us know, much appreciated. Have you tried to reach out to Michael Hawkins, the maintainer? -
Hi again, one quick question -- I previously made the mistake of running apt upgrade of the system packages and had installed armbian-configNG over the included armbian-config, so I basically nuked the SD card and reinstalled the image to roll back to the old config. This likely has been covered, but is there a way to reinstall armbian-config or is this a known issue and "DON'T UPGRADE" ? Cheers!
It's a progress! This or similar problem was seen / reported on H3 too.
