Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + Box64 arm64 v0.4.1 ed9827920 (https://ryanfortner.github.io/box64-debs/) + wine-11.3-staging-tkg-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/11.3) + vkd3d-1.19 (wine's built-in) ~60fps@1024x576 (medium settings) Hades 2 -
Missing keys when running apt-update
technik007_cz replied to Luna the Deer's topic in Libre Renegade
Hi, I redownloaded the key and replaced it, and it works! - Yesterday
Clarification on GPL 2.0 License Applicability
tparys replied to Clark McCauley's topic in Off-topic
GPL requires source code be offered for any software distributed. Changes to the build system probably aren't covered, but a modified DTB probably is. The final image also has the Linux kernel and other GPL components, so that definitely is. Bottom line is that GPL is supposed to be permissive. DTS is easily gotten from DTB. And you're probably good as long as you're not being a jerk about it. If that bothers you, you could also make a overlay (dtbo) and just patch the DTB on boot. You'd avoid the custom image and also make it more clear that your DTB is tweaked. -
Has anyone had any luck with the Radxa Cubie a5e and Armbian?
Meestor_X replied to Meestor_X's topic in Allwinner sunxi
While attempting, using AI, to see if there were DTS changes that could help this (spoiler: there aren't), it came up with some DTB changes that it claims need to be made for the board's stability. Maybe someone who understands these things can see if they got it right? Also, does the new allwinner update for armbian help/fix any of the cubie's USB/Power issues? https://github.com/armbian/build/pull/9381 a5e-armbian-DTS.patch -
I finally managed to boot in Maskrom mode by shorting the clock pin (red circle on the picture) to ground, then loading the loader (rk3528_spl_loader_v1.07.104.bin) and u-boot with rkdeveloptool.
Is the NanoPC-T6 Plus compatible with the NanoPC T6 LTS image ?
magic_sam replied to magic_sam's topic in NanoPC T6 LTS
Dear @Werner , I have just created an issue on Github to keep track of this discussion: https://github.com/armbian/build/issues/9446 Is it safe to try possibly unsupported images on the NanoPC-T6 Plus ? It's a relatively expensive piece of kit and I'd rather not take any chances (new LPDDR5 RAM: possibly new memory timings, etc.) Best regards, Samuel -
Timezone for Iceland
Igor replied to Björn Eiríksson's topic in Framework and userspace feature requests
... problem is elsewhere. This is running: sudo dpkg-reconfigure tzdata in CLI (Armbian Noble), choosing region Atlantic, then: -
bedna, see - i tried your way on a raspi 3B+ with the last minimal armbian and it worked like your case like a charm - on my Win11 with putty. If you look a bit back to my post with the attached "ssh_debian.txt" - that is what I get when I use a debian as ssh client! ssh client and the odroid ssh server cannot agree on how to connect UNLESS I dumb it down as seen in the command line - and then "1234" is not accepted.. So - armbian "odroid XU4" does not behave like "raspi"!
So I need to know what I have to do to get MIDI messages into my music app that I'm working on. I developed a cli synth app on Manjaro using SDL3 and Jack. Jack I used to connect to MIDI aka 'MIDI-Bridge' or MIDI Through and an external program to produce MIDI messages sent to MIDI Through. I am currently trying to do the same on the actual device I wish to use which is the OrangePi 4 LTS I have spare with just bare bones Armbian Server, no desktop. I have audio working through Pipewire. I am used to Jack just being available because Pipewire intercepts and handles the calls behind the scenes. I noticed that on Armbian I think I have to use the 'pw-jack' program or jack-play goes into an eternal and uninterruptible error loop (I have to kill it through another terminal). Note: I am developing this program in Zig. Am I doing all of this the wrong way? Is there some system process I have to start? Or something I haven't installed?
@Ryzer pcduino definitely works fine with dwc2. I cannot get OTG to work without it. I am not qulified to make any comments on whether this makes sense or is a coincidence, but if I don't load the module, it's doesn't work. For some reason, the mass storage gadget is still a little unstable in Windows (sometimes the File Explorer window shuts down for no reason), but on a Linux laptop, it is rock stable. It has also been running for two days in my car and doesn't seem to miss a beat there either (Linux host).
I'm putting together a build for a 3D printer, rk3308b-s board that has no ethernet, just a Fn-link wifi chip that is a knock-off of an rtl8192fs. I pulled the OEM dts and it describes the chip as an rtl8192cs. I'm pretty sure this is an out of kernel driver and my searches indicate I put source in userpatches. What do I need to add in the board/*.csc file to build to an image with the kernel module(s)? I do have a ralink ra2400, a mt7201 and some supported realtek dongles and If connected, I could git the code build and moprobe the module to test. Ideally, I would like to incorporate the driver via dkms in a armbian build. Can someone point me to the process?
Basically it has 1 gb ROM 8gb ram h3 chip and I HAVE put many img files on SD card NONE of them boot and as soon as I take the SD card out it boots into android perfectly fine... I'm lost on words and what to do I have also tried FEL mode on linux but the request times out with error -7 power supply is 5v 2a which is fine for this so not that and I'm using a 256gb a1 rated SD card. This is from a generic Chinese tv box called meecom and it has ADX-H-V1.0 written on it. I also changed the dtb files a lot but it still gave no display or sign that it was booted into armbian idk what to do help ( btw I repasted it that's why it has no thermal putty on it)
I haven't got my head around what the differences are with -copy options. I'm able to use drm-copy but it produces a small stutter when watching 1080p hevc content whereas drm is very smooth. As previously mentioned, drm-copy does allow mpv to display videos with problematic file widths instead of just a black screen. I don't understand it all enough to know why that is.
I think building a new image is probably beyond me at the moment. I uninstalled the existing headers, rebooted and installed the updated headers and rebooted. The issue persists. I'm just going to give up on it. I don't really need to LCD display to work. I just wanted confirmation I wasn't missing something stupid. Thanks.
Orange Pi Zero 3 WiFi Issues (unisoc_wifi Driver)
ValdikSS replied to Thomas Waterfall's topic in Allwinner sunxi
I found a workaround: disabling BSS transition management from AP to STA seems to work. There won't be roaming on AP's request obviously. wpa_cli set disable_btm 1 or in Debian's interfaces configuration file: iface wlan0 inet dhcp wpa-ssid YourSSIDJere wpa-psk blablabla post-up wpa_cli set disable_btm 1 Regular roaming (device-initiated) still works fine. -
how about armbian 26.2.1 but still using vendor kernel? did we still have this problem?
xsetiadi replied to jondowd's topic in Orange Pi 5
how do you solve this man? im also have this issue using v25.11.2 for Orange Pi 5 running Armbian Linux 6.1.115-vendor-rk35xx im using official power adapter. so i guess nothing wrong with my power. can we fix this without reinstalling the entire os? i have several running container and services. -
Deoptim replied to Deoptim's topic in Rockchip CPU Boxes
Here are the modified latest official Armbian-supported images for Radxa Zero 3W/3E. Everything works for me, including hardware-accelerated YouTube playback in Chromium (however, with a caveat): Armbian_26.2.1_hk1-rbox-r3_trixie_vendor_6.1.115_minimal.img.xz Armbian_26.2.1_hk1-rbox-r3_noble_vendor_6.1.115_gnome_desktop.img.xz MD5: 28654e87a39ac3e0b2bec4ce4211f5ca *Armbian_26.2.1_hk1-rbox-r3_noble_vendor_6.1.115_gnome_desktop.img.xz ce74829c43c6d27b02bdf314580c4dc4 *Armbian_26.2.1_hk1-rbox-r3_trixie_vendor_6.1.115_minimal.img.xz What you MUST do after installing Armbian: Freeze auto-updates for the bootloader and DTB (kernel updates are OK, except for these two packages since we use a different bootloader, not for Radxa Zero 3): sudo apt-mark hold linux-u-boot-radxa-zero3-vendor linux-dtb-vendor-rk35xx Install dependencies for hardware-accelerated playback Youtube in Chromium: sudo apt update sudo apt install chromium-codecs-ffmpeg-extra ffmpeg In Chromium, install the enhanced-h264ify extension. Then, in the extension's options, leave only AV1 disabled (i.e., enable VP8 and VP9). Screenshots: Instructions on how to modify any Armbian image yourself: Source: 4PDA -
Armbian Debian suggestion
Fabricio Martínez Tamayo replied to Fabricio Martínez Tamayo's topic in Off-topic
I always use minimal CLI and deploy k3s. Might be the request amounts are too many or who knows. But the service hangs and stops working. Just my 2 cents. -
Maybe this comment and thread have a hint for you https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/#findComment-229274 I don't own a waveshare LCD... but I would also like to know if its possible to make it work with Armbian
I'm on the current Debian Trixie build Armbian 26.2.1 Minimal / IOT, and Wifi is not working. What are the current suggestions to get it back up on BigTreeTech CB1?
Looks like the same adjustment that was made for EDGE needs to be done so for CURRENT.
marfalk replied to marfalk's topic in Amlogic CPU Boxes
Sorry for my late reply (been very busy in the last couple of days). No, reboot does not work either: same freeze. Anyway it's a software issue and that's unfortunate for Armbian, because shut down and reboot for my device work flawlessly with CoreElec. I hope in a future improvement. -
Thanks for the advice.
