$ xz -t Armbian_25.2.1_Khadas-edge2_noble_vendor_6.1.99_gnome_desktop.oowow.img.xz $ echo $? 0 Check your download. Probably corrupted.
@remlei last time I checked, the usb gadget overlay was working fine and the UCD device was correctly spawning up. Some things work with rk322x (mass storage), some others don't (UAC1, UAC2), so your mileage may vary. Verify you have usb-otg-peripheral in /boot/armbianEnv.txt in the overlays= line
Hi, Very good news. Could you please give output of following commands cat /proc/cpuinfo cat /proc/interrupts Thanks in advance
Debian is "cleaner" and more true to the gnome desktop. Also, Ubuntu uses snaps, which is removed in Armbian and replaced with Debian packages, like Chromium. It's like a mix of two distros. But, I'll be happy with one working distro
wireless-regdb is already installed and apt returns E: Unable to locate package crda for crda. Thanks for trying to help
Some chips that support 1.5Mbaud and more: - FT232R - CH340G - CP2104
GPU blacklisted the panfrost module Has it been resolved? Thank you - Yesterday
Ethernet stop working after delay on Orange Pi PC+ with SSD
lamenace replied to lamenace's topic in Allwinner sunxi
It's the link up/down problem. Never seen this under bullseye but it happens on bookworm -
after some research i have (finally) found the original archives form balbes. they can also been burn to the internal eemc. with some work you can run bookworm with kernel 3.10.99 (dont ask why) from the internal storage... https://archive.org/details/amlogic-s805-linux tks for 0jw4tts witch uploaded those files to archive.og !!!
Guys, does anyone know how to enable the TV Box's wifi with the ik316 process? I downloaded armbian, the only thing missing is wifi. Data transmission works with a network cable, only the wifi is having problems. The iso I downloaded was Armbian-unofficial_25.05.0-trunk_X96q-lpddr3_bookworm_edge_6.12.11_xfce_desktop.img.xz
Be aware that the answer might depend on the filesystem you are using on your board Be aware that a resize operation can easily destroy your data or at least make it inaccessible have a look at shrink-backup for "reverse"
Armbian doesnt seem to see sata harddrives.
prahal replied to DontMindMe's topic in Radxa Rock 5 ITX
@Popolon indeed this issue rot for a long time. I cleaned up my backlog to have more time for armbian. Also I still have quite a few processes to learn about armbian board maintenance still to this day. But you confirm that with mainline 6.12 all is fine ? But, indeed no HDMI out and no audio. I still have a patch for mainline 6.12 in the pipe about a race condition between SATA chip and nvme as far as I remind. I will prioritize data vendor kernel debugging if this mainline patch is not required (and indeed mainline still lacks any multimedia capability, this might be a showstopper for most users) even though I am close to complete testing and send PR for this one. As of now I have confirmed that this mainline patch set does not help vendor as the vendor branch has a hack that workaround the issue that mainline faces about this SATA/nvme race. -
100mbps is enough for all my projects. if not, there are some usb3 gigabit adapters
Rock 5C server vs gnome
sakittelsen replied to sakittelsen's topic in Software, Applications, Userspace
Looks like the server images uses systemd for network control, but desktop images use network manager. I believe this should build the server images with network manager: ./compile.sh NETWORKING_STACK="network-manager" -
armbian-config unable to install anything
Igor replied to akaix's topic in Software, Applications, Userspace
Network bridge is added within armbian-config Docker install ... Perhaps open a ticket https://github.com/armbian/configng so this is eventually done properly. -
@ZjemCiKolege than you! Now wireless is activated by the overlay. @c0rnelius wifi ok but I'm still missing bluetooth (pb with the controller). See dmseg attached. dmseg-H-wifi-bt.txt
Ubuntu 22 gnome desktop compilation encounters' Configuring Locales' exception
Werner replied to lay's topic in Khadas EDGE2
Issues with the build framework, building Armbian to say, should be reported in the framework repository. https://github.com/armbian/build/ Make sure you include full logs. Use the curl command at the very and of the process or use SHARE_LOG=yes as build switch. Otherwise report might be rejected. -
How to reset the armbian system and restore the initial configuration operation??
lay replied to lay's topic in Khadas EDGE2
Thank you, I will study it. -
Install non-vendor image (kernel 6.12+)
prahal replied to Jurgen.Schober's topic in Radxa Rock 5 ITX
Mainline audio is not working. Vendor audio is working but not activated by default yet -
Sorry took so long: workaround is to set the two mixer controls via cli: amixer -c 4 sset 'Left Headphone Mixer Left DAC' on amixer -c 4 sset 'Right Headphone Mixer Right DAC' on they are off on armbian and on the initial image I was testing with which you properly sorted out was Radxa default Debian image. Edit: note you can increase the sound output by increasing "Headphone Mixer", via amixer or interactively via "alsamixer -c 4". Edit 2: note that this only works for the vendor kernel. I don't get audio out with the mainline one (replace -c 4 by -c 0 there as there is only one audio device available with mainline)
This is for rock 5b. The U-boot requirements is for rock 5b only as it seems to be due to rock 5b being powered via this usb-c port (and talks about the USB-PD negociation needing to happen in u-boot). So this patch to rock 5b dts will not fix rock-5-itx support. Edit: Mind I have not checked yet if the rock-5-itx dts already has this code or not.
How do I change the default desktop environment on Debian 12 startup from cinnamon to xfce4? I have installed xfce4 and it's related "goodies", added a .Xclients file containing "startxfc4" in both root and ~/ folder locations. But the unit sometimes boots back into cinnamon. I do not see anything under armbian-config to control the desktop environment or to switch between cli/gui. I recall such options under orangepi-config (at least the cli/gui switching).
After years of thinking, wishing and tinkering - Armbian automated WiFi performance benchmark system: https://docs.armbian.com/WifiPerformance/ From latest WiFi 7 down to (in)famous xradio XR819.
