  2. After a ton of time porting the dts for modern kernels, i have a working release for the Bobcat 300 29X Variant To compile https://github.com/sicXnull/armbian-build/tree/Bobcat-29x . ./compile.sh build BOARD=bobcat-29x BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes EXPERT=yes KERNEL_BTF=no KERNEL_CONFIGURE=NO KERNEL_GIT=shallow RELEASE=bookworm Link to Prebuilt Armbian-unofficial_26.02.0-trunk_Bobcat-29x_bookworm_current_6.18.4.img.xz First check to see if you have a compatible version. Flip the unit over and check the serial number. It will start with G290 or 295. This does not work on 28 or 285. How to Flash 1) Install Rockchip Flash Tools 2) Download bootloader (rk356x_spl_loader_ddr1056_v1.10.111.bin) attached here. 3) Boot device into LOADER mode. Plug USB Cable in to back of the unit, powered off. Open the device. With it powered on hold the reset button for 1 second, then immediately let off and hold the recovery button down until the PC recognizes you in LOADER mode 4) Follow the flash procedure found here. WARNING While I2C/Spidev is functional, i did not install Helium or the Lora packet forwarder for testing. Flash this image at your own risk if you still wish to use helium mining. rk356x_spl_loader_ddr1056_v1.10.111.bin
  3. Yesterday
  4. Yep Already tried that:- "chatgpt+gemini have given lots of ideas like patches, hooks, extensions but none of them work. (grrrrrr!)." Didn't work probably because the source is not an ASCII text file but a large CPIO binary. But....I am just running a make right now which looks like it might work..... don't want to jinx it....
  5. I have no complaints about the developers, it’s enough for me to just know that this is not a client-side problem and that someone is working on a solution.
  6. Hi @sicxnull @Nick A, as mentioned by @ventara X96Q vs 5.1 image of sicxnull has direct ethernet port and wireless working fine instead the Nick A 'Armbian-unofficial_25.05.0-trunk_X96q-ddr3-v5-1_bookworm_edge_6.12.11_xfce_desktop.img' has no ethernet or wifi working. I'm totally a newbie on these things, but thanks to the comunity I was able to use an mxq mini (S905X) working with Armbian and home assistant (of course i just used an image with armbian and after I load HA and tailscale. Now I would like to use the X96Q vs 5.1 for the other house. I know that the image of sicxnull works but I prefer to use Nick A. because armbian config as well most of the things are like the one on the other working tv box instead on the sicxnull image there is mate and a lot of commands or gui function are so different. I tried to understand what is different between the two images and github repository to be able to fix almost the ethernet port problem but I do not have enough acknowledge. My unix experience was with the AT&T unix system 5 and Solaris so very old OS and many years ago. Only now I'm coming back to unix world and I don't know anything about git, patch and so on. I read in a post that someone was able applying a patch but it is not clear to me how and where to apply patch, I have already installed Ubuntu in a Virtualbox and prepare everything to compile Armbian and tested that initial script start, ask me for board and other staff but after I stopped because I realized that I didn't understand what I'm doing. Probably with a standard sbc was easier. I promise that I will go ahead studying but it is hard and confused at the moment. If I can do something to help of course when I'm at home I will do it. Please, when you have free time give me some info on how to fix at least the direct ethernet port. armbianEnv.txt and boot.cmd looks same file. In both dtb folder there are same namefile.dtb include the 5.1 where armbianEnv point out but I don't know if they are same file in both distribution or are different? Wifi chip is the XR819 like I saw in other image with the v 5,1 Thanks for the great job you and the comunity are doing!
  7. Thanks Nick. In the meanwhile, would dtbo overlay, setting up CSI taken from radxa's github a733, work with kernel/u-boot of your image? Is there a way I can manually alter boot files to get this dtbo loaded? This is of course for the experiment - radxa's a733 image seems to still have a problem with ISP processor (or dtbo file affecting data formatting), as the resulting picture from the camera seems to be in a wrong color space (by the look, but I'm not an expert). I've reported the issue at https://forum.radxa.com/t/radxa-cubie-a7a-radxa-13m-214-camera/29717/7 for anyone interested.
  8. duplicate
  9. This isn't a DMA problem. There are too many inconsistencies in the audio driver. The driver needs to be fixed first.
  10. Unfortunately, after multiple tries the image provided didn't work. Here is the outputs of the commands asked to be runned with there respective tested images: dmesg | grep -iE "stmmac|sun8i|dwmac|emac|phy|mdio|motorcomm|yt8531" dmesg | grep -i "registered.*phy\|phy.*connect" ls -l /sys/bus/mdio_bus/devices/ cat /sys/bus/mdio_bus/*/phy_id 2>/dev/null find /sys/class/net -name "end0" -o -name "eth0" | head -1 | xargs -I {} cat {}/phys_switch_id 2>/dev/null ls /sys/firmware/devicetree/base/soc/ethernet*/mdio/ Armbian_community_25.11.0-trunk.437_Orangepi3-lts_trixie_current_6.12.47_minimal.img [NOT WORKING] https://pastebin.com/v4bqxkeU Armbian_community_26.2.0-trunk.100_Orangepi3-lts_trixie_current_6.12.63_minimal.img [NOT WORKING] https://pastebin.com/fG0YKepz Armbian_community_26.2.0-trunk.151_Orangepi3-lts_trixie_current_6.12.63_minimal.img [NOT WORKING] https://pastebin.com/4eEC9mMg Armbian-unofficial_26.02.0-trunk_Orangepi3-lts_trixie_current_6.12.63_minimal_phy-io-supply.img [NOT WORKING] https://pastebin.com/DnRgP4k5 Armbian-unofficial_26.02.0-trunk_Orangepi3-lts_trixie_edge_6.18.2_minimal.img [WORKING] https://pastebin.com/8qp2X9wC armbianmonitor -U Armbian_community_25.11.0-trunk.437_Orangepi3-lts_trixie_current_6.12.47_minimal.img [NOT WORKING] https://pastebin.com/iUKFu1u0 Armbian_community_26.2.0-trunk.100_Orangepi3-lts_trixie_current_6.12.63_minimal.img [NOT WORKING] https://pastebin.com/SUDx7yme Armbian_community_26.2.0-trunk.151_Orangepi3-lts_trixie_current_6.12.63_minimal.img [NOT WORKING] https://pastebin.com/QVU9q2La Armbian-unofficial_26.02.0-trunk_Orangepi3-lts_trixie_current_6.12.63_minimal_phy-io-supply.img [NOT WORKING] https://pastebin.com/qiE4u2PQ Armbian-unofficial_26.02.0-trunk_Orangepi3-lts_trixie_edge_6.18.2_minimal.img [WORKING] https://pastebin.com/2iWbYgqK For some reason, Armbian_community_25.11.0-trunk.437_Orangepi3-lts_trixie_current_6.12.47_minimal.img stopped working when it did before. I tested it 5 times, and none of those boots worked. I don't know if the times I tested it before worked because of the small chance of booting with an ethernet connection, but it stopped working after booting. Anyway, I just want to clarify the inconsistency, but Armbian-unofficial_26.02.0-trunk_Orangepi3-lts_trixie_edge_6.18.2_minimal.img is still consistently working after numerous boots. Also, while testing the images to provide the outputs, I realized something interesting, which for some reason I didn't notice before. After booting for the first time, the images downloaded from the official place, https://www.armbian.com/orangepi3-lts/, showed a message that explains that the image used is a “Developer Preview Build” and that it should not be used for production. I don't know if this is expected or is a mistake in publicizing the incorrect images, but now that I realized it, I felt that I needed to disclose it. Maybe that is the reason the Ethernet connection is not working. Armbian_community_26.2.0-trunk.151_Orangepi3-lts_trixie_current_6.12.63_minimal.img Welcome to Armbian_community! Documentation: https://docs.armbian.com | Community support: https://community.armbian.com/ IP address: Network connection timeout! Create root password: **** Repeat root password: **** Developer Preview Build This Armbian image was generated automatically for development and testing purpose. It may include unfinished features or unstable components. If you are not here to report issues or just test it, please do not use this image in production. Expect things to change - or even break - as improvements are made. Creating a new user account. Press <Ctrl-C> to abort Please provide a username (eg. your first name):_ Armbian_community_25.11.0-trunk.437_Orangepi3-lts_trixie_current_6.12.47_minimal.img Welcome to Armbian_community! Documentation: https://docs.armbian.com | Community support: https://community.armbian.com/ IP address: Network connection timeout! Create root password: **** Repeat root password: **** WARNING! You are using an automated build meant only for developers to provide construtive feedback to improve build system, OS settings or UX. If this does not apply to you, STOP NOW! Especially don't use this image for production since things might not work as expected or at all. They may break anytime with next update. Creating a new user account. Press <Ctrl-C> to abort Please provide a username (eg. your first name):_
  11. A quite easy workaround until it's resolved up-upstream is to install and enable the Cinnamenu applet and disable the "vanilla" menu applet. Right-click on the taskbar/panel, choose "Applets" and the rest is straightforward. To place the Cinnamenu in the bottom left corner, right click on the taskbar/panel and enter Edit mode to be able to move stuff around, finish Edit mode and you're all set.
  12. moved to off-topic since op is not using Armbian.
  13. Last week
  14. Also, this TVBOX contains the less known S9012P wifi chip. However on this github repository some kind of unofficial driver support is available, can this driver get the wifi chip working on Armbian ?
  15. sven-ola
    All clear for the PCIe MSI: it is something with that Intel 7260 card. Today, I got two other M.2 Wifis: MT7922 and RTL8822ce, both seem to work on current and also on edge. Thus, I consider this as a success. Here's some screen blurb. // Sven-Ola
  16. Minor update, I hardcoded usage of uboot debugging option and removed cache to force compiling uboot. But output from bootloader remained the same: U-Boot SPL 2024.01_armbian-2024.01-S866c-P7738-Ha5c2-Vcc17-Bf389-R448a (Jan 08 2026 - 10:33:14 +0000) DRAM: 512 MiB Trying to boot from MMC1 Maybe detailed logging was already enabled? But it still does not give me any hints. Especially my board does not contain any additional slots like emmc, only for micro sd card (I don't understand why bootloader tries to use mmc1) UPD: I find out question with a little bit similar problem (hang out on mmc1) but need time to understand the reason, maybe it has similar issue
  17. Thank you reply, brentr. I add some info. passmark run command param is -r 2 ,means only run memory test.By the way ,I rename "PerformanceTest_Linux_ARM64" to passmark.Which you can download from "https://www.passmark.com/products/pt_linux/download.php" or "https://www.passmark.com/downloads/PerformanceTest_Linux_ARM64.zip" The only reason ,I install xterm,is I need use resize command to resize serial console.And I install it at 4.4 kernel also. pi@Pi-s:~$ apt list --installed 7zip/stable,now 25.01+dfsg-1~deb13u1 arm64 [installed,automatic] adbd/stable,now 34.0.5-12 arm64 [installed] adduser/stable,now 3.152 all [installed,automatic] adwaita-icon-theme/stable,now 48.1-1 all [installed,automatic] alsa-utils/stable,now 1.2.14-1 arm64 [installed] android-libbase/stable,now 1:34.0.5-12 arm64 [installed,automatic] android-libboringssl/stable,now 14.0.0+r45-2 arm64 [installed,automatic] android-libcutils/stable,now 1:34.0.5-12 arm64 [installed,automatic] android-liblog/stable,now 1:34.0.5-12 arm64 [installed,automatic] apt-utils/stable,now 3.0.3 arm64 [installed] apt/stable,now 3.0.3 arm64 [installed] armbian-bsp-cli-rockpi-s-current/now 25.11.2 arm64 [installed,local] armbian-config/unknown,now 26.2.0-trunk.126.1225.000141 all [installed] armbian-firmware/now 25.11.2 all [installed,local] at-spi2-common/stable,now 2.56.2-1 all [installed,automatic] avahi-daemon/stable,now 0.8-16 arm64 [installed,automatic] avahi-utils/stable,now 0.8-16 arm64 [installed] base-files/now 25.11.2-13.8+deb13u2-trixie arm64 [installed,local] base-passwd/stable,now 3.6.7 arm64 [installed] bash-completion/stable,now 1:2.16.0-7 all [installed] bash/stable,now 5.2.37-2+b5 arm64 [installed] bc/stable,now 1.07.1-4+b1 arm64 [installed] binutils-aarch64-linux-gnu/stable,now 2.44-3 arm64 [installed,automatic] binutils-common/stable,now 2.44-3 arm64 [installed,automatic] binutils/stable,now 2.44-3 arm64 [installed,automatic] bsdextrautils/stable,now 2.41-5 arm64 [installed,automatic] bsdutils/stable,now 1:2.41-5 arm64 [installed] btop/stable,now 1.3.2-0.1 arm64 [installed] btrfs-progs/stable,now 6.14-1 arm64 [installed] build-essential/stable,now 12.12 arm64 [installed] bzip2/stable,now 1.0.8-6 arm64 [installed,automatic] ca-certificates/stable,now 20250419 all [installed] console-setup-linux/stable,now 1.242~deb13u1 all [installed,automatic] console-setup/stable,now 1.242~deb13u1 all [installed] coreutils/stable,now 9.7-3 arm64 [installed] cpio/stable,now 2.15+dfsg-2 arm64 [installed,automatic] cpp-14-aarch64-linux-gnu/stable,now 14.2.0-19 arm64 [installed,automatic] cpp-14/stable,now 14.2.0-19 arm64 [installed,automatic] cpp-aarch64-linux-gnu/stable,now 4:14.2.0-1 arm64 [installed,automatic] cpp/stable,now 4:14.2.0-1 arm64 [installed,automatic] cron-daemon-common/stable,now 3.0pl1-197 all [installed,automatic] cron/stable,now 3.0pl1-197 arm64 [installed] curl/stable,now 8.14.1-2+deb13u2 arm64 [installed] cutecom/stable,now 0.51.0-1+b3 arm64 [installed] dash/stable,now 0.5.12-12 arm64 [installed] dbus-bin/stable,now 1.16.2-2 arm64 [installed,automatic] dbus-daemon/stable,now 1.16.2-2 arm64 [installed,automatic] dbus-session-bus-common/stable,now 1.16.2-2 all [installed,automatic] dbus-system-bus-common/stable,now 1.16.2-2 all [installed,automatic] dbus-user-session/stable,now 1.16.2-2 arm64 [installed] dbus/stable,now 1.16.2-2 arm64 [installed,automatic] dconf-gsettings-backend/stable,now 0.40.0-5 arm64 [installed,automatic] dconf-service/stable,now 0.40.0-5 arm64 [installed,automatic] debconf-utils/stable,now 1.5.91 all [installed] debconf/stable,now 1.5.91 all [installed] debian-archive-keyring/stable,now 2025.1 all [installed,automatic] debianutils/stable,now 5.23.2 arm64 [installed] debsums/stable,now 3.0.2.3 all [installed] device-tree-compiler/stable,now 1.7.2-2+b1 arm64 [installed] dialog/stable,now 1.3-20250116-1 arm64 [installed] diffutils/stable,now 1:3.10-4 arm64 [installed] dmidecode/stable,now 3.6-2 arm64 [installed] dmsetup/stable,now 2:1.02.205-2 arm64 [installed,automatic] dosfstools/stable,now 4.2-1.2 arm64 [installed] dpkg-dev/stable,now 1.22.21 all [installed,automatic] dpkg/stable,now 1.22.21 arm64 [installed] dracut-install/stable,now 106-6 arm64 [installed,automatic] e2fsprogs/stable,now 1.47.2-3+b3 arm64 [installed] ethtool/stable,now 1:6.14.2-1 arm64 [installed] fake-hwclock/stable,now 0.14 all [installed] fdisk/stable,now 2.41-5 arm64 [installed] figlet/stable,now 2.2.5-3+b2 arm64 [installed] file/stable,now 1:5.46-5 arm64 [installed] findutils/stable,now 4.10.0-3 arm64 [installed] fontconfig-config/stable,now 2.15.0-2.3 arm64 [installed,automatic] fontconfig/stable,now 2.15.0-2.3 arm64 [installed,automatic] fonts-dejavu-core/stable,now 2.37-8 all [installed,automatic] fonts-dejavu-mono/stable,now 2.37-8 all [installed,automatic] fping/stable,now 5.1-1+b1 arm64 [installed,automatic] g++-14-aarch64-linux-gnu/stable,now 14.2.0-19 arm64 [installed,automatic] g++-14/stable,now 14.2.0-19 arm64 [installed,automatic] g++-aarch64-linux-gnu/stable,now 4:14.2.0-1 arm64 [installed,automatic] g++/stable,now 4:14.2.0-1 arm64 [installed,automatic] gcc-14-aarch64-linux-gnu/stable,now 14.2.0-19 arm64 [installed,automatic] gcc-14-base/stable,now 14.2.0-19 arm64 [installed] gcc-14/stable,now 14.2.0-19 arm64 [installed,automatic] gcc-aarch64-linux-gnu/stable,now 4:14.2.0-1 arm64 [installed,automatic] gcc/stable,now 4:14.2.0-1 arm64 [installed,automatic] gensio-bin/stable,now 2.8.13-7 arm64 [installed] git-man/stable,now 1:2.47.3-0+deb13u1 all [installed,automatic] git/stable,now 1:2.47.3-0+deb13u1 arm64 [installed] gpg/stable,now 2.4.7-21+b3 arm64 [installed,automatic] gpgconf/stable,now 2.4.7-21+b3 arm64 [installed,automatic] gpgv/stable,now 2.4.7-21+b3 arm64 [installed] gpiod/stable,now 2.2.1-2+deb13u1 arm64 [installed] grep/stable,now 3.11-4+b1 arm64 [installed] groff-base/stable,now 1.23.0-9 arm64 [installed,automatic] gtk-update-icon-cache/stable,now 4.18.6+ds-2 arm64 [installed,automatic] gzip/stable,now 1.13-1 arm64 [installed] hicolor-icon-theme/stable,now 0.18-2 all [installed,automatic] hostname/stable,now 3.25 arm64 [installed] htop/stable,now 3.4.1-5 arm64 [installed] iftop/stable,now 1.0~pre4-9+b2 arm64 [installed] inetutils-telnet/stable,now 2:2.6-3 arm64 [installed,automatic] inetutils-traceroute/stable,now 2:2.6-3 arm64 [installed] init-system-helpers/stable,now 1.69~deb13u1 all [installed] init/stable,now 1.69~deb13u1 arm64 [installed] initramfs-tools-bin/stable,now 0.148.3 arm64 [installed,automatic] initramfs-tools-core/stable,now 0.148.3 all [installed,automatic] initramfs-tools/stable,now 0.148.3 all [installed] iproute2/stable,now 6.15.0-1 arm64 [installed] iputils-ping/stable,now 3:20240905-3 arm64 [installed] iw/stable,now 6.9-1+b1 arm64 [installed] jq/stable,now 1.7.1-6+deb13u1 arm64 [installed] kbd/stable,now 2.7.1-2 arm64 [installed,automatic] keyboard-configuration/stable,now 1.242~deb13u1 all [installed,automatic] klibc-utils/stable,now 2.0.14-1 arm64 [installed,automatic] kmod/stable,now 34.2-2 arm64 [installed,automatic] less/stable,now 668-1 arm64 [installed] libacl1/stable,now 2.3.2-2+b1 arm64 [installed] libaio1t64/stable,now 0.3.113-8+b1 arm64 [installed,automatic] libapparmor1/stable,now 4.1.0-1 arm64 [installed,automatic] libapt-pkg7.0/stable,now 3.0.3 arm64 [installed,automatic] libasan8/stable,now 14.2.0-19 arm64 [installed,automatic] libasound2-data/stable,now 1.2.14-1 all [installed,automatic] libasound2t64/stable,now 1.2.14-1 arm64 [installed,automatic] libassuan9/stable,now 3.0.2-2 arm64 [installed,automatic] libatk-bridge2.0-0t64/stable,now 2.56.2-1 arm64 [installed,automatic] libatk1.0-0t64/stable,now 2.56.2-1 arm64 [installed,automatic] libatomic1/stable,now 14.2.0-19 arm64 [installed,automatic] libatopology2t64/stable,now 1.2.14-1 arm64 [installed,automatic] libatspi2.0-0t64/stable,now 2.56.2-1 arm64 [installed,automatic] libattr1/stable,now 1:2.5.2-3 arm64 [installed] libaudit-common/stable,now 1:4.0.2-2 all [installed] libaudit1/stable,now 1:4.0.2-2+b2 arm64 [installed] libavahi-client3/stable,now 0.8-16 arm64 [installed,automatic] libavahi-common-data/stable,now 0.8-16 arm64 [installed,automatic] libavahi-common3/stable,now 0.8-16 arm64 [installed,automatic] libavahi-core7/stable,now 0.8-16 arm64 [installed,automatic] libbinutils/stable,now 2.44-3 arm64 [installed,automatic] libblkid1/stable,now 2.41-5 arm64 [installed] libbpf1/stable,now 1:1.5.0-3 arm64 [installed,automatic] libbrotli1/stable,now 1.1.0-2+b7 arm64 [installed,automatic] libbsd0/stable,now 0.12.2-2 arm64 [installed,automatic] libbz2-1.0/stable,now 1.0.8-6 arm64 [installed] libc-bin/stable,now 2.41-12 arm64 [installed] libc-dev-bin/stable,now 2.41-12 arm64 [installed,automatic] libc-l10n/stable,now 2.41-12 all [installed,automatic] libc6-dev/stable,now 2.41-12 arm64 [installed,automatic] libc6/stable,now 2.41-12 arm64 [installed] libcaca0/stable,now 0.99.beta20-5 arm64 [installed,automatic] libcairo-gobject2/stable,now 1.18.4-1+b1 arm64 [installed,automatic] libcairo2/stable,now 1.18.4-1+b1 arm64 [installed,automatic] libcap-ng0/stable,now 0.8.5-4+b1 arm64 [installed] libcap2-bin/stable,now 1:2.75-10+b1 arm64 [installed,automatic] libcap2/stable,now 1:2.75-10+b1 arm64 [installed] libcbor0.10/stable,now 0.10.2-2 arm64 [installed,automatic] libcc1-0/stable,now 14.2.0-19 arm64 [installed,automatic] libcloudproviders0/stable,now 0.3.6-2 arm64 [installed,automatic] libcolord2/stable,now 1.4.7-3 arm64 [installed,automatic] libcom-err2/stable,now 1.47.2-3+b3 arm64 [installed,automatic] libcrypt-dev/stable,now 1:4.4.38-1 arm64 [installed,automatic] libcrypt1/stable,now 1:4.4.38-1 arm64 [installed] libctf-nobfd0/stable,now 2.44-3 arm64 [installed,automatic] libctf0/stable,now 2.44-3 arm64 [installed,automatic] libcups2t64/stable,now 2.4.10-3+deb13u2 arm64 [installed,automatic] libcurl3t64-gnutls/stable,now 8.14.1-2+deb13u2 arm64 [installed,automatic] libcurl4t64/stable,now 8.14.1-2+deb13u2 arm64 [installed,automatic] libdaemon0/stable,now 0.14-7.1+b3 arm64 [installed,automatic] libdatrie1/stable,now 0.2.13-3+b1 arm64 [installed,automatic] libdb5.3t64/stable,now 5.3.28+dfsg2-9 arm64 [installed] libdbus-1-3/stable,now 1.16.2-2 arm64 [installed,automatic] libdconf1/stable,now 0.40.0-5 arm64 [installed,automatic] libdebconfclient0/stable,now 0.280 arm64 [installed] libdeflate0/stable,now 1.23-2 arm64 [installed,automatic] libdevmapper1.02.1/stable,now 2:1.02.205-2 arm64 [installed,automatic] libdialog15/stable,now 1.3-20250116-1 arm64 [installed,automatic] libdouble-conversion3/stable,now 3.3.1-1 arm64 [installed,automatic] libdpkg-perl/stable,now 1.22.21 all [installed,automatic] libdrm-amdgpu1/stable,now 2.4.124-2 arm64 [installed,automatic] libdrm-common/stable,now 2.4.124-2 all [installed,automatic] libdrm2/stable,now 2.4.124-2 arm64 [installed,automatic] libedit2/stable,now 3.1-20250104-1 arm64 [installed,automatic] libegl-mesa0/stable,now 25.0.7-2 arm64 [installed,automatic] libegl1/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libelf1t64/stable,now 0.192-4 arm64 [installed,automatic] libepoxy0/stable,now 1.5.10-2 arm64 [installed,automatic] liberror-perl/stable,now 0.17030-1 all [installed,automatic] libestr0/stable,now 0.1.11-2 arm64 [installed,automatic] libevdev2/stable,now 1.13.4+dfsg-1 arm64 [installed,automatic] libexpat1/stable,now 2.7.1-2 arm64 [installed,automatic] libext2fs2t64/stable,now 1.47.2-3+b3 arm64 [installed,automatic] libfastjson4/stable,now 1.2304.0-2 arm64 [installed,automatic] libfdisk1/stable,now 2.41-5 arm64 [installed,automatic] libfdt1/stable,now 1.7.2-2+b1 arm64 [installed,automatic] libffi8/stable,now 3.4.8-2 arm64 [installed,automatic] libfftw3-single3/stable,now 3.3.10-2+b1 arm64 [installed,automatic] libfido2-1/stable,now 1.15.0-1+b1 arm64 [installed,automatic] libfile-fnmatch-perl/stable,now 0.02-3+b4 arm64 [installed,automatic] libfontconfig1/stable,now 2.15.0-2.3 arm64 [installed,automatic] libfreetype6/stable,now 2.13.3+dfsg-1 arm64 [installed,automatic] libfribidi0/stable,now 1.0.16-1 arm64 [installed,automatic] libgbm1/stable,now 25.0.7-2 arm64 [installed,automatic] libgcc-14-dev/stable,now 14.2.0-19 arm64 [installed,automatic] libgcc-s1/stable,now 14.2.0-19 arm64 [installed] libgcrypt20/stable,now 1.11.0-7 arm64 [installed,automatic] libgdbm-compat4t64/stable,now 1.24-2 arm64 [installed,automatic] libgdbm6t64/stable,now 1.24-2 arm64 [installed,automatic] libgdk-pixbuf-2.0-0/stable,now 2.42.12+dfsg-4 arm64 [installed,automatic] libgdk-pixbuf2.0-common/stable,now 2.42.12+dfsg-4 all [installed,automatic] libgensio6t64/stable,now 2.8.13-7 arm64 [installed,automatic] libgl1-mesa-dri/stable,now 25.0.7-2 arm64 [installed,automatic] libgl1/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libglib2.0-0t64/stable,now 2.84.4-3~deb13u1 arm64 [installed,automatic] libglvnd0/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libglx-mesa0/stable,now 25.0.7-2 arm64 [installed,automatic] libglx0/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libgmp10/stable,now 2:6.3.0+dfsg-3 arm64 [installed] libgnutls30t64/stable,now 3.8.9-3 arm64 [installed,automatic] libgomp1/stable,now 14.2.0-19 arm64 [installed,automatic] libgpg-error0/stable,now 1.51-4 arm64 [installed,automatic] libgpiod3/stable,now 2.2.1-2+deb13u1 arm64 [installed,automatic] libgpm2/stable,now 1.20.7-11+b2 arm64 [installed,automatic] libgprofng0/stable,now 2.44-3 arm64 [installed,automatic] libgraphite2-3/stable,now 1.3.14-2+b1 arm64 [installed,automatic] libgssapi-krb5-2/stable,now 1.21.3-5 arm64 [installed,automatic] libgtk-3-0t64/stable,now 3.24.49-3 arm64 [installed,automatic] libgtk-3-common/stable,now 3.24.49-3 all [installed,automatic] libgudev-1.0-0/stable,now 238-6 arm64 [installed,automatic] libharfbuzz0b/stable,now 10.2.0-1+b1 arm64 [installed,automatic] libhogweed6t64/stable,now 3.10.1-1 arm64 [installed,automatic] libhwasan0/stable,now 14.2.0-19 arm64 [installed,automatic] libice6/stable,now 2:1.1.1-1 arm64 [installed,automatic] libicu76/stable,now 76.1-4 arm64 [installed,automatic] libidn2-0/stable,now 2.3.8-2 arm64 [installed,automatic] libiniparser4/stable,now 4.2.6-1 arm64 [installed,automatic] libinput-bin/stable,now 1.28.1-1 arm64 [installed,automatic] libinput10/stable,now 1.28.1-1 arm64 [installed,automatic] libisl23/stable,now 0.27-1 arm64 [installed,automatic] libitm1/stable,now 14.2.0-19 arm64 [installed,automatic] libjansson4/stable,now 2.14-2+b3 arm64 [installed,automatic] libjbig0/stable,now 2.1-6.1+b2 arm64 [installed,automatic] libjpeg62-turbo/stable,now 1:2.1.5-4 arm64 [installed,automatic] libjq1/stable,now 1.7.1-6+deb13u1 arm64 [installed,automatic] libk5crypto3/stable,now 1.21.3-5 arm64 [installed,automatic] libkeyutils1/stable,now 1.6.3-6 arm64 [installed,automatic] libklibc/stable,now 2.0.14-1 arm64 [installed,automatic] libkmod2/stable,now 34.2-2 arm64 [installed,automatic] libkrb5-3/stable,now 1.21.3-5 arm64 [installed,automatic] libkrb5support0/stable,now 1.21.3-5 arm64 [installed,automatic] libksba8/stable,now 1.6.7-2+b1 arm64 [installed,automatic] liblastlog2-2/stable,now 2.41-5 arm64 [installed] liblcms2-2/stable,now 2.16-2 arm64 [installed,automatic] libldap2/stable,now 2.6.10+dfsg-1 arm64 [installed,automatic] liblerc4/stable,now 4.0.0+ds-5 arm64 [installed,automatic] libllvm19/stable,now 1:19.1.7-3+b1 arm64 [installed,automatic] liblocale-gettext-perl/stable,now 1.07-7+b1 arm64 [installed,automatic] liblognorm5/stable,now 2.0.6-5 arm64 [installed,automatic] liblsan0/stable,now 14.2.0-19 arm64 [installed,automatic] liblsof0/stable,now 4.99.4+dfsg-2 arm64 [installed,automatic] liblua5.4-0/stable,now 5.4.7-1+b2 arm64 [installed,automatic] libluajit-5.1-2/stable,now 2.1.0+openresty20250117-2 arm64 [installed,automatic] libluajit-5.1-common/stable,now 2.1.0+openresty20250117-2 all [installed,automa> liblz1/stable,now 1.15-3 arm64 [installed,automatic] liblz4-1/stable,now 1.10.0-4 arm64 [installed,automatic] liblzma5/stable,now 5.8.1-1 arm64 [installed] liblzo2-2/stable,now 2.10-3+b1 arm64 [installed,automatic] libmagic-mgc/stable,now 1:5.46-5 arm64 [installed,automatic] libmagic1t64/stable,now 1:5.46-5 arm64 [installed,automatic] libmariadb3/stable,now 1:11.8.3-0+deb13u1 arm64 [installed,automatic] libmd0/stable,now 1.1.0-2+b1 arm64 [installed] libmd4c0/stable,now 0.5.2-2+b1 arm64 [installed,automatic] libmnl0/stable,now 1.0.5-3 arm64 [installed,automatic] libmount1/stable,now 2.41-5 arm64 [installed] libmpc3/stable,now 1.3.1-1+b3 arm64 [installed,automatic] libmpfr6/stable,now 4.2.2-1 arm64 [installed,automatic] libmtdev1t64/stable,now 1.1.7-1 arm64 [installed,automatic] libncurses5/now 6.4-4 arm64 [installed,local] libncurses6/stable,now 6.5+20250216-2 arm64 [installed] libncursesw6/stable,now 6.5+20250216-2 arm64 [installed,automatic] libnetplan1/stable,now 1.1.2-7 arm64 [installed,automatic] libnettle8t64/stable,now 3.10.1-1 arm64 [installed,automatic] libnewt0.52/stable,now 0.52.25-1 arm64 [installed,automatic] libnghttp2-14/stable,now 1.64.0-1.1 arm64 [installed,automatic] libnghttp3-9/stable,now 1.8.0-1 arm64 [installed,automatic] libngtcp2-16/stable,now 1.11.0-1 arm64 [installed,automatic] libngtcp2-crypto-gnutls8/stable,now 1.11.0-1 arm64 [installed,automatic] libnl-3-200/stable,now 3.7.0-2 arm64 [installed,automatic] libnl-genl-3-200/stable,now 3.7.0-2 arm64 [installed,automatic] libnl-route-3-200/stable,now 3.7.0-2 arm64 [installed,automatic] libnpth0t64/stable,now 1.8-3 arm64 [installed,automatic] libnss-mdns/stable,now 0.15.1-4+b1 arm64 [installed] libonig5/stable,now 6.9.9-1+b1 arm64 [installed,automatic] libopenipmi0t64/stable,now 2.0.37-1 arm64 [installed,automatic] libp11-kit0/stable,now 0.25.5-3 arm64 [installed,automatic] libpam-modules-bin/stable,now 1.7.0-5 arm64 [installed] libpam-modules/stable,now 1.7.0-5 arm64 [installed] libpam-runtime/stable,now 1.7.0-5 all [installed] libpam-systemd/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] libpam0g/stable,now 1.7.0-5 arm64 [installed] libpango-1.0-0/stable,now 1.56.3-1 arm64 [installed,automatic] libpangocairo-1.0-0/stable,now 1.56.3-1 arm64 [installed,automatic] libpangoft2-1.0-0/stable,now 1.56.3-1 arm64 [installed,automatic] libparted2t64/stable,now 3.6-5 arm64 [installed,automatic] libpcap0.8t64/stable,now 1.10.5-2 arm64 [installed,automatic] libpci3/stable,now 1:3.13.0-2 arm64 [installed,automatic] libpcre2-16-0/stable,now 10.46-1~deb13u1 arm64 [installed,automatic] libpcre2-8-0/stable,now 10.46-1~deb13u1 arm64 [installed] libpcsclite1/stable,now 2.3.3-1 arm64 [installed,automatic] libperl5.40/stable,now 5.40.1-6 arm64 [installed,automatic] libpipeline1/stable,now 1.5.8-1 arm64 [installed,automatic] libpixman-1-0/stable,now 0.44.0-3 arm64 [installed,automatic] libpng16-16t64/stable-security,now 1.6.48-1+deb13u1 arm64 [installed,automatic] libpopt0/stable,now 1.19+dfsg-2 arm64 [installed,automatic] libpq5/stable,now 17.6-0+deb13u1 arm64 [installed,automatic] libproc2-0/stable,now 2:4.0.4-9 arm64 [installed,automatic] libprotobuf32t64/stable,now 3.21.12-11 arm64 [installed,automatic] libproxychains4/stable,now 4.17-3 arm64 [installed,automatic] libpsl5t64/stable,now 0.21.2-1.1+b1 arm64 [installed,automatic] libpython3-stdlib/stable,now 3.13.5-1 arm64 [installed,automatic] libpython3.13-minimal/stable,now 3.13.5-2 arm64 [installed,automatic] libpython3.13-stdlib/stable,now 3.13.5-2 arm64 [installed,automatic] libpython3.13/stable,now 3.13.5-2 arm64 [installed,automatic] libqt5core5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5dbus5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5gui5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5network5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5serialport5/stable,now 5.15.15-2 arm64 [installed,automatic] libqt5widgets5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libreadline8t64/stable,now 8.2-6 arm64 [installed,automatic] libreiserfscore0t64/stable,now 1:3.6.27-9 arm64 [installed,automatic] librtmp1/stable,now 2.4+20151223.gitfa8646d.1-2+b5 arm64 [installed,automatic] libsamplerate0/stable,now 0.2.2-4+b2 arm64 [installed,automatic] libsasl2-2/stable,now 2.1.28+dfsg1-9 arm64 [installed,automatic] libsasl2-modules-db/stable,now 2.1.28+dfsg1-9 arm64 [installed,automatic] libsctp1/stable,now 1.0.21+dfsg-1 arm64 [installed,automatic] libseccomp2/stable,now 2.6.0-2 arm64 [installed,automatic] libselinux1/stable,now 3.8.1-1 arm64 [installed] libsemanage-common/stable,now 3.8.1-1 all [installed,automatic] libsemanage2/stable,now 3.8.1-1 arm64 [installed,automatic] libsensors-config/stable,now 1:3.6.2-2 all [installed,automatic] libsensors5/stable,now 1:3.6.2-2 arm64 [installed,automatic] libsepol2/stable,now 3.8.1-1 arm64 [installed,automatic] libsframe1/stable,now 2.44-3 arm64 [installed,automatic] libsharpyuv0/stable,now 1.5.0-0.1 arm64 [installed,automatic] libslang2/stable,now 2.3.3-5+b2 arm64 [installed,automatic] libsm6/stable,now 2:1.2.6-1 arm64 [installed,automatic] libsmartcols1/stable,now 2.41-5 arm64 [installed] libsqlite3-0/stable,now 3.46.1-7 arm64 [installed] libss2/stable,now 1.47.2-3+b3 arm64 [installed,automatic] libssh2-1t64/stable,now 1.11.1-1 arm64 [installed,automatic] libssl3t64/stable,now 3.5.4-1~deb13u1 arm64 [installed] libstdc++-14-dev/stable,now 14.2.0-19 arm64 [installed,automatic] libstdc++6/stable,now 14.2.0-19 arm64 [installed,automatic] libsystemd-shared/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] libsystemd0/stable,now 257.9-1~deb13u1 arm64 [installed] libtasn1-6/stable,now 4.20.0-2 arm64 [installed,automatic] libtext-charwidth-perl/stable,now 0.04-11+b4 arm64 [installed,automatic] libtext-iconv-perl/stable,now 1.7-8+b4 arm64 [installed,automatic] libtext-wrapi18n-perl/stable,now 0.06-10 all [installed,automatic] libthai-data/stable,now 0.1.29-2 all [installed,automatic] libthai0/stable,now 0.1.29-2+b1 arm64 [installed,automatic] libtiff6/stable,stable-security,now 4.7.0-3+deb13u1 arm64 [installed,automatic] libtinfo5/now 6.4-4 arm64 [installed,local] libtinfo6/stable,now 6.5+20250216-2 arm64 [installed] libtirpc-common/stable,now 1.3.6+ds-1 all [installed,automatic] libtirpc3t64/stable,now 1.3.6+ds-1 arm64 [installed,automatic] libtsan2/stable,now 14.2.0-19 arm64 [installed,automatic] libubsan1/stable,now 14.2.0-19 arm64 [installed,automatic] libuchardet0/stable,now 0.0.8-1+b2 arm64 [installed,automatic] libudev1/stable,now 257.9-1~deb13u1 arm64 [installed] libunistring5/stable,now 1.3-2 arm64 [installed,automatic] libusb-1.0-0/stable,now 2:1.0.28-1 arm64 [installed,automatic] libutempter0/stable,now 1.2.1-4 arm64 [installed,automatic] libuuid1/stable,now 2.41-5 arm64 [installed] libvulkan1/stable,now 1.4.309.0-1 arm64 [installed,automatic] libwacom-common/stable,now 2.14.0-1 all [installed,automatic] libwacom9/stable,now 2.14.0-1 arm64 [installed,automatic] libwayland-client0/stable,now 1.23.1-3 arm64 [installed,automatic] libwayland-cursor0/stable,now 1.23.1-3 arm64 [installed,automatic] libwayland-egl1/stable,now 1.23.1-3 arm64 [installed,automatic] libwayland-server0/stable,now 1.23.1-3 arm64 [installed,automatic] libwebp7/stable,now 1.5.0-0.1 arm64 [installed,automatic] libwrap0/stable,now 7.6.q-36 arm64 [installed,automatic] libwtmpdb0/stable,now 0.73.0-3+deb13u1 arm64 [installed,automatic] libx11-6/stable,now 2:1.8.12-1 arm64 [installed,automatic] libx11-data/stable,now 2:1.8.12-1 all [installed,automatic] libx11-xcb1/stable,now 2:1.8.12-1 arm64 [installed,automatic] libxau6/stable,now 1:1.0.11-1 arm64 [installed,automatic] libxaw7/stable,now 2:1.0.16-1 arm64 [installed,automatic] libxcb-dri3-0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-glx0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-icccm4/stable,now 0.4.2-1 arm64 [installed,automatic] libxcb-image0/stable,now 0.4.0-2+b2 arm64 [installed,automatic] libxcb-keysyms1/stable,now 0.4.1-1 arm64 [installed,automatic] libxcb-present0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-randr0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-render-util0/stable,now 0.3.10-1 arm64 [installed,automatic] libxcb-render0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-shape0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-shm0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-sync1/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-util1/stable,now 0.4.1-1 arm64 [installed,automatic] libxcb-xfixes0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-xinerama0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-xinput0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-xkb1/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb1/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcomposite1/stable,now 1:0.4.6-1 arm64 [installed,automatic] libxcursor1/stable,now 1:1.2.3-1 arm64 [installed,automatic] libxdamage1/stable,now 1:1.1.6-1+b2 arm64 [installed,automatic] libxdmcp6/stable,now 1:1.1.5-1 arm64 [installed,automatic] libxext6/stable,now 2:1.3.4-1+b3 arm64 [installed,automatic] libxfixes3/stable,now 1:6.0.0-2+b4 arm64 [installed,automatic] libxft2/stable,now 2.3.6-1+b4 arm64 [installed,automatic] libxi6/stable,now 2:1.8.2-1 arm64 [installed,automatic] libxinerama1/stable,now 2:1.1.4-3+b4 arm64 [installed,automatic] libxkbcommon-x11-0/stable,now 1.7.0-2 arm64 [installed,automatic] libxkbcommon0/stable,now 1.7.0-2 arm64 [installed,automatic] libxml2/stable,now 2.12.7+dfsg+really2.9.14-2.1+deb13u2 arm64 [installed,automa> libxmu6/stable,now 2:1.1.3-3+b4 arm64 [installed,automatic] libxmuu1/stable,now 2:1.1.3-3+b4 arm64 [installed,automatic] libxpm4/stable,now 1:3.5.17-1+b3 arm64 [installed,automatic] libxrandr2/stable,now 2:1.5.4-1+b3 arm64 [installed,automatic] libxrender1/stable,now 1:0.9.12-1 arm64 [installed,automatic] libxshmfence1/stable,now 1.3.3-1 arm64 [installed,automatic] libxt6t64/stable,now 1:1.2.1-1.2+b2 arm64 [installed,automatic] libxtables12/stable,now 1.8.11-2 arm64 [installed,automatic] libxxf86vm1/stable,now 1:1.1.4-1+b4 arm64 [installed,automatic] libxxhash0/stable,now 0.8.3-2 arm64 [installed,automatic] libyaml-0-2/stable,now 0.2.5-2 arm64 [installed,automatic] libz3-4/stable,now 4.13.3-1 arm64 [installed,automatic] libzstd1/stable,now 1.5.7+dfsg-1 arm64 [installed] links/stable,now 2.29-2+b3 arm64 [installed] linux-base/stable,now 4.12 all [installed] linux-dtb-current-rockchip64/now 25.11.2 arm64 [installed,local] linux-image-current-rockchip64/now 25.11.2 arm64 [installed,local] linux-libc-dev/stable,now 6.12.57-1 all [installed,automatic] linux-u-boot-rockpi-s-current/now 25.11.2 arm64 [installed,local] lm-sensors/stable,now 1:3.6.2-2 arm64 [installed] lmbench/stable,now 3.0-a9+debian.1-9 arm64 [installed] locales/stable,now 2.41-12 all [installed] login.defs/stable,now 1:4.17.4-2 all [installed] login/stable,now 1:4.16.0-2+really2.41-5 arm64 [installed] logrotate/stable,now 3.22.0-1+b2 arm64 [installed] logsave/stable,now 1.47.2-3+b3 arm64 [installed,automatic] lsb-release/stable,now 12.1-1 all [installed,automatic] lshw/stable,now 02.19.git.2021.06.19.996aaad9c7-2.1 arm64 [installed] lsof/stable,now 4.99.4+dfsg-2 arm64 [installed] make/stable,now 4.4.1-2 arm64 [installed,automatic] man-db/stable,now 2.13.1-1 arm64 [installed] mariadb-common/stable,now 1:11.8.3-0+deb13u1 all [installed,automatic] mawk/stable,now 1.3.4.20250131-1 arm64 [installed] media-types/stable,now 13.0.0 all [installed,automatic] mesa-libgallium/stable,now 25.0.7-2 arm64 [installed,automatic] minicom/stable,now 2.10-1 arm64 [installed] mmc-utils/stable,now 0+git20240329.f757f413-1+b1 arm64 [installed] mount/stable,now 2.41-5 arm64 [installed] mtd-utils/stable,now 1:2.3.0-1 arm64 [installed] mysql-common/stable,now 5.8+1.1.1 all [installed,automatic] nano/stable,now 8.4-1 arm64 [installed] ncurses-base/stable,now 6.5+20250216-2 all [installed] ncurses-bin/stable,now 6.5+20250216-2 arm64 [installed] ncurses-term/stable,now 6.5+20250216-2 all [installed] netbase/stable,now 6.5 all [installed,automatic] netplan-generator/stable,now 1.1.2-7 arm64 [installed,automatic] netplan.io/stable,now 1.1.2-7 arm64 [installed] openssh-client/stable,now 1:10.0p1-7 arm64 [installed,automatic] openssh-server/stable,now 1:10.0p1-7 arm64 [installed] openssh-sftp-server/stable,now 1:10.0p1-7 arm64 [installed,automatic] openssl-provider-legacy/stable,now 3.5.4-1~deb13u1 arm64 [installed] openssl/stable,now 3.5.4-1~deb13u1 arm64 [installed,automatic] p7zip-full/stable,now 16.02+transitional.1 all [installed] parted/stable,now 3.6-5 arm64 [installed] passwd/stable,now 1:4.17.4-2 arm64 [installed] patch/stable,now 2.8-2 arm64 [installed,automatic] pci.ids/stable,now 0.0~2025.06.09-1 all [installed,automatic] perl-base/stable,now 5.40.1-6 arm64 [installed] perl-modules-5.40/stable,now 5.40.1-6 all [installed,automatic] perl/stable,now 5.40.1-6 arm64 [installed,automatic] picocom/stable,now 3.1-4+b1 arm64 [installed] powertop/stable,now 2.15-4 arm64 [installed] procps/stable,now 2:4.0.4-9 arm64 [installed,automatic] proxychains4/stable,now 4.17-3 arm64 [installed] psmisc/stable,now 23.7-2 arm64 [installed] putty-tools/stable,now 0.83-3 arm64 [installed,automatic] putty/stable,now 0.83-3 arm64 [installed] pv/stable,now 1.9.31-1 arm64 [installed,automatic] python3-cffi-backend/stable,now 1.17.1-3 arm64 [installed,automatic] python3-minimal/stable,now 3.13.5-1 arm64 [installed,automatic] python3-netplan/stable,now 1.1.2-7 arm64 [installed,automatic] python3-psutil/stable,now 7.0.0-2 arm64 [installed,automatic] python3-typing-extensions/stable,now 4.13.2-1 all [installed,automatic] python3-urwid/stable,now 2.6.16-1 arm64 [installed,automatic] python3-wcwidth/stable,now 0.2.13+dfsg1-1 all [installed,automatic] python3-yaml/stable,now 6.0.2-1+b2 arm64 [installed,automatic] python3.13-minimal/stable,now 3.13.5-2 arm64 [installed,automatic] python3.13/stable,now 3.13.5-2 arm64 [installed,automatic] python3/stable,now 3.13.5-1 arm64 [installed,automatic] readline-common/stable,now 8.2-6 all [installed,automatic] rfkill/stable,now 2.41-5 arm64 [installed] rockusb/stable,now 0.2.0-2+b2 arm64 [installed] rpcsvc-proto/stable,now 1.4.3-1+b1 arm64 [installed,automatic] rsync/stable,now 3.4.1+ds1-5 arm64 [installed] rsyslog/stable,now 8.2504.0-1 arm64 [installed] runit-helper/stable,now 2.16.4 all [installed,automatic] s-tui/stable,now 1.1.6-1.2 all [installed] sed/stable,now 4.9-2+b1 arm64 [installed] sensible-utils/stable,now 0.0.25 all [installed,automatic] ser2net/stable,now 4.6.4-1 arm64 [installed] shared-mime-info/stable,now 2.4-5+b2 arm64 [installed,automatic] sqv/stable,now 1.3.0-3 arm64 [installed,automatic] stress/stable,now 1.0.7-1+b1 arm64 [installed] sudo/stable,now 1.9.16p2-3 arm64 [installed] sysbench/stable,now 1.0.20+ds-7+b1 arm64 [installed] sysstat/stable,now 12.7.5-2+b2 arm64 [installed] systemd-resolved/stable,now 257.9-1~deb13u1 arm64 [installed] systemd-sysv/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] systemd-timesyncd/stable,now 257.9-1~deb13u1 arm64 [installed] systemd/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] sysvinit-utils/stable,now 3.14-4 arm64 [installed] tar/stable,now 1.35+dfsg-3.1 arm64 [installed] telnet/stable,now 0.17+2.6-3 all [installed] tio/stable,now 3.9-1 arm64 [installed] toilet-fonts/stable,now 0.3-3 all [installed,automatic] toilet/stable,now 0.3-3 arm64 [installed] tree/stable,now 2.2.1-1 arm64 [installed] tzdata/stable,now 2025b-4+deb13u1 all [installed] u-boot-tools/stable,now 2025.01-3 arm64 [installed] ucf/stable,now 3.0052 all [installed,automatic] udev/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] usbutils/stable,now 1:018-2 arm64 [installed] util-linux/stable,now 2.41-5 arm64 [installed] wavemon/stable,now 0.9.1-1+b1 arm64 [installed] wget/stable,now 1.25.0-2 arm64 [installed] whiptail/stable,now 0.52.25-1 arm64 [installed,automatic] wireguard-tools/stable,now 1.0.20210914-3 arm64 [installed] wireless-regdb/stable,now 2025.07.10-1 all [installed] wpasupplicant/stable,now 2:2.10-24 arm64 [installed] x11-common/stable,now 1:7.7+24+deb13u1 all [installed,automatic] xauth/stable,now 1:1.1.2-1.1 arm64 [installed] xbitmaps/stable,now 1.1.1-2.2 all [installed,automatic] xkb-data/stable,now 2.42-1 all [installed,automatic] xterm/stable,now 398-1 arm64 [installed] xz-utils/stable,now 5.8.1-1 arm64 [installed,automatic] zlib1g/stable,now 1:1.3.dfsg+really1.3.1-1+b1 arm64 [installed] pi@Pi-s:~$ pi@Pi-s:~$ lsmod Module Size Used by 8723ds 1327104 0 hci_uart 135168 0 btqca 20480 1 hci_uart btrtl 28672 1 hci_uart snd_soc_rk3308 65536 1 crct10dif_ce 12288 1 btintel 49152 1 hci_uart snd_soc_rockchip_i2s_tdm 24576 2 snd_soc_simple_card 20480 0 btbcm 20480 1 hci_uart snd_soc_simple_card_utils 24576 1 snd_soc_simple_card bluetooth 671744 6 btrtl,btqca,btintel,hci_uart,btbcm snd_soc_core 204800 4 snd_soc_rockchip_i2s_tdm,snd_soc_rk3308,snd_soc_simple_card_utils,snd_soc_simple_card snd_compress 24576 1 snd_soc_core snd_pcm_dmaengine 12288 1 snd_soc_core snd_pcm 106496 4 snd_compress,snd_soc_simple_card_utils,snd_soc_core,snd_pcm_dmaengine snd_timer 36864 1 snd_pcm snd 77824 4 snd_timer,snd_compress,snd_soc_core,snd_pcm soundcore 12288 1 snd cpufreq_dt 16384 0 cfg80211 815104 1 8723ds rfkill 24576 4 bluetooth,cfg80211 zram 36864 2 842_decompress 16384 1 zram 842_compress 20480 1 zram binfmt_misc 20480 1 usb_f_acm 16384 1 u_serial 28672 1 usb_f_acm g_serial 12288 0 libcomposite 65536 2 g_serial,usb_f_acm nfnetlink 16384 2 ip_tables 28672 0 x_tables 36864 1 ip_tables autofs4 45056 2 realtek 40960 1 dwmac_rk 28672 0 stmmac_platform 20480 1 dwmac_rk stmmac 241664 3 stmmac_platform,dwmac_rk pcs_xpcs 28672 1 stmmac pi@Pi-s:~$
  18. I use etckeeper on my ODroid-N2. he sends me changes to my /etc/once a day. And regularly I get this change: armbian-leds.conf | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-) diff --git a/armbian-leds.conf b/armbian-leds.conf index 8108230..537ea6f 100644 --- a/armbian-leds.conf +++ b/armbian-leds.conf @@ -5,5 +5,5 @@ invert=0 [/sys/class/leds/rtw88-1-1.1:1.0] trigger=phy0tpt -brightness=1 +brightness=0 What is this mess? What is it for?
  19. update armbian dts ,Give to those in need use sudo armbian-add-overlay ***.dts this dts can avaible rtl8211f on h618 /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h618"; fragment@0 { target = <&mmc1>; __overlay__ { status = "disabled"; }; }; fragment@1 { target = <&emac1>; __overlay__ { status = "disabled"; }; }; fragment@2 { target = <&pio>; __overlay__ { x98h_rgmii_pins: x98h-rgmii-pins { pins = "PI0", "PI1", "PI2", "PI3", "PI4", "PI5", "PI6", "PI7", "PI8", "PI9", "PI10", "PI11", "PI12", "PI13", "PI14", "PI15"; function = "emac0"; drive-strength = <40>; }; }; }; /* 3. 配置千兆网卡 */ fragment@3 { target = <&emac0>; __overlay__ { pinctrl-names = "default"; pinctrl-0 = <&x98h_rgmii_pins>; phy-mode = "rgmii"; phy-handle = <&rgmii_phy>; phy-io-supply = <&reg_aldo1>; allwinner,tx-delay-ps = <700>; allwinner,rx-delay-ps = <3100>; status = "okay"; mdio { rgmii_phy: ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <1>; reset-gpios = <&pio 8 16 1>; reset-assert-us = <30000>; reset-deassert-us = <150000>; }; }; }; }; };
  20. https://drive.google.com/drive/folders/1dx0TApPAEjFDz24Rm22J4jgtIbJrYYHC?usp=drive_link build log: url for test... https://github.com/armbian/build/pull/9185
  21. Hi, Just wanted to provide more info on this. When I try to load the beagle Y AI official debian image it works fine, just wondering whether the dtb is inline with the Beagle Y AI official dtb or any changes where made related to the usb host. Any help would be appreciated. Thanks!
  22. It is already an old thread, but if someone stumbles over this situation, that compile.sh breaks at update-binfmt errors, check if qemu-user-binfmt is installed on the host linux system. do: sudo apt install qemu-user and you should be fine again.
  23. Great! Thanks a lot! I will try it to se if Diablo II can run tonight!
  24. http://blog.armbian.com/content/images/2026/01/githubhighlights-2.webpThis week’s Armbian development saw significant kernel upgrades across multiple platforms, including meson64, rockchip64, and UEFI, with several branches bumped to versions 6.18 and 6.19. Notable hardware support enhancements were introduced, such as SPI controller support for Allwinner A523, new board additions like mixtile-core3588e, and improved compatibility for devices including Radxa and Youyeetoo. The build system received stability and performance improvements, featuring parallel repository generation, refined CI scripts, and fixes for repository management in concurrent environments. Kernel configuration updates enabled additional filesystems and tickless idle for mvebu devices. Several patches addressed hardware initialization, network, and desktop issues, while deprecated packages were removed for a leaner build. Overall, the changelog reflects a strong focus on expanding hardware support, refining build infrastructure, and maintaining kernel currency. add allwinner: a523: Support SPI controllers patch series. by @EvilOlaf in armbian/build#9124allow build on forky host. by @amazingfate in armbian/build#9153CI: add watchdog action script and adjust log cleaning parameter. by @igorpecovnik in armbian/build#9147Fix repository management script for parallel execution. by @igorpecovnik in armbian/build#9163fix: replace comm with grep to support uutils coreutils. by @cantalupo555 in armbian/build#9148kernel configs - enable EROFS as module, ditto overlayfs & F2FS. by @tabrisnet in armbian/build#9135kernel: mvebu: enable tickless idle. by @neheb in armbian/build#9139meson64-6.19: de-bork PCIe, again (missed a patch from 6.18). by @rpardini in armbian/build#9151meson64: bump edge to 6.19; current 6.12 -> 6.18. by @EvilOlaf in armbian/build#9069meson64: bump edge to 6.19; current 6.12 -> 6.18 (nonsquash). by @rpardini in armbian/build#9146Missing variable in board config - address JSON matrix warnings. by @igorpecovnik in armbian/build#9144mixtile-core3588e: add board with vendor and edge branches (Joshua Riek + fixes). by @rpardini in armbian/build#9119Modify radxa-e54c board config to fix leds, network and Gnome desktop init.. by @schwar3kat in armbian/build#9111radxa-cubie-a5e: maint and fixes. by @EvilOlaf in armbian/build#9152Remove libfuse2t64 from package list. by @igorpecovnik in armbian/build#9155Repo tools: add parallel repository generation support. by @igorpecovnik in armbian/build#9150Revert few Rabbit's suggestions that broke repository management. by @igorpecovnik in armbian/build#9156rockchip64-6.18: Enable HDMI1 and audio for HDMI0/1 on CM3588-NAS. by @rpardini in armbian/build#9138rockchip64: add edge kernel support for Youyeetoo YY3588. by @SuperKali in armbian/build#9137rockchip64: fix broken patch in 6.18.3, rewrite everything. by @EvilOlaf in armbian/build#9157uefi-all: bump edge to 6.19 (except loong64); legacy 6.6 -> 6.12; current/cloud 6.12 -> 6.18. by @EvilOlaf in armbian/build#9086uefi-loong64-edge: bump to 6.19. by @amazingfate in armbian/build#9149View the full article
  25. So the workaround is to set cpu freq max to 1 MHz. I still have to use a ghetto cooler 5000 when running a process that maxes out the CPU. Seems Duo running 10C+ at idle with latest kernel and Noble. I can live with that as long as I know. The default is 1.2 MHz max which runs too hot at 1.3V.
  26. Java UIO Java UIO offers robust Java interfaces optimized for Linux Userspace IO, emphasizing high performance. Engineered from scratch, it leverages contemporary kernel APIs, libraries, and cutting-edge code generation methodologies, embodying a state-of-the-art cross-platform solution. Rather than reinventing established paradigms, Java UIO harnesses existing standards, avoiding redundant development commonly observed in other IO libraries. Seamlessly supporting JDK 25 LTS, this framework integrates Project Lombok to streamline code, enhancing readability and conciseness. 🌍 The 32-bit & FFM Reality With Java 25, there is no more support for X86_32, and ARM32 has limited JDKs available. While FFM (Foreign Function & Memory API) is the future, it is not supported on X86_32 or ARM32. For now, JavaUIO moves into the future providing a high-performance path for ARM32, while fully supporting ARM64 and X86_64.
  27. I guess the image was built from a pending pull request for testing before merge. Since it has been merged now it should work. Make sure your framework clone is up to date (git pull).
  28. Oh, I understand. Camera, hardware video decoder and hardware video encoder - they all appear now as /dev/videoX devices, because new hardware videocodec accelerator driver (or standalone video decoder and video encoder drivers) became V4L2 kind of driver. Also thanks for the reference link.
