  2. This week in Armbian development saw significant enhancements across multiple areas, including expanded board support and improved hardware compatibility. Notable additions include new images and configurations for Qidi X-6, X-7, and Ariaboard Photonicat2 mainboards, as well as refined kernel patch maintenance and updates for various platforms. The build system received important fixes, such as resolving compilation errors and device tree issues, alongside improvements in Docker utilities and offline mode detection. Several refactoring efforts streamlined backend processes and enhanced user interface elements. The team also introduced automatic fallback mechanisms for Hetzner server types, optimizing runner scaling. Overall, these updates reinforce Armbian's commitment to stability, broader hardware support, and a smoother user experience. ChangesAdd automatic fallback to smaller Hetzner server types with runner count scaling. by @igorpecovnik in armbian/actions#15Add board and board vendror image for Ariaboard Photonicat2. by @HackingGate in armbian/armbian.github.io#255Add image for Qidi X-7 Mainboard. by @Shadowrom2020 in armbian/armbian.github.io#257Add some board image. by @retro98boy in armbian/armbian.github.io#258Add support for dialog via new wrapper functions. by @igorpecovnik in armbian/configng#762Add support for qidi x-* boards. by @Shadowrom2020 in armbian/build#9564Change unit tests badge link in documentation. by @igorpecovnik in armbian/documentation#885Drop patches that landed upstream and fix two. by @igorpecovnik in armbian/build#9544edge: bump 7.0 to rc5. by @EvilOlaf in armbian/build#9580Enable BCACHE on Raspberry Pi build. by @aulanov in armbian/build#9550feat: offline mode detection with local asset cache. by @SuperKali in armbian/imager#117feat: settings refactoring, DiskArbitration device detection, and filename parser improvements. by @SuperKali in armbian/imager#114fix race condition and NULL ptr deref in PCIe threaded probe. by @AlomeProg in armbian/linux-rockchip#458fix(docker): add trixie support for upstream docker-ce to fix HomeAssistant installation. by @igorpecovnik in armbian/configng#765fix: correct dialog argument order causing box option errors. by @igorpecovnik in armbian/configng#768fix: resolve Phytium stmmac compilation errors for kernel 6.19. by @igorpecovnik in armbian/build#9545fix: settings modal reset, custom image manufacturer, and board detection setting. by @SuperKali in armbian/imager#116Image for Qidi X-6 Mainboard. by @Shadowrom2020 in armbian/armbian.github.io#256kernel patch maintenance. by @EvilOlaf in armbian/build#9562meson64-6.18: rewrite kernel config. by @EvilOlaf in armbian/build#9581mksklipad50: fix devicetree opp voltage settings. by @torte71 in armbian/build#9569OrangePi-RV2/R2S: rename board config from wip to csc. by @sven-ola in armbian/build#9560Qidi X-6: fix defconfig patch. by @Shadowrom2020 in armbian/build#9567refactor: add comprehensive Docker wrapper utilities with progress display. by @igorpecovnik in armbian/configng#769refactor: deduplicate hooks, add CSS design tokens, clean up backend. by @SuperKali in armbian/imager#115rockchip64-7.0: mekotronics-r58x-pro: analog sound: use SuperKali's new clock. by @rpardini in armbian/build#9554rockchip64: rk3588: add I2S MCLK output gate clocks for audio codec support. by @SuperKali in armbian/build#9548rockchip64: rk3588: update I2S MCLK gate patches to match upstream v3 and add u-boot clock IDs. by @SuperKali in armbian/build#9568sm8250: Fix application of Retroid Pocket 5/mini device trees. by @kay-lambdadelta in armbian/build#9572SpacemiT: Update ATFSOURCE, BOOTSOURCE and SD card support.. by @pyavitz in armbian/build#9552sunxi-6.18: remove stray commit from patch. by @EvilOlaf in armbian/build#9556sunxi: bump edge to 6.19.y, current to 6.18.y and legacy to 6.12.y. by @EvilOlaf in armbian/build#9381Update odroidxu4-current to 6.6.129. by @belegdol in armbian/build#9558Update VERSION. by @EvilOlaf in armbian/build#9553View the full article
  3. Yesterday
  4. Hello, can you please say, where i can find: Armbian_community_25.11.0-trunk.413_Aml-s9xx-box_plucky_edge_6.18.0-rc3.img thank you.
  5. Subject: X88MAX RK3328 - Cannot boot from SD/USB, need help installing Armbian Hello Armbian Community, I'm trying to install Armbian on my X88 RK3328 TV box but facing multiple issues. Need your expert help! Device Information: Model: X88MAX.p2.0.01.d4 SoC: Rockchip RK3328 Android Version: Android 9 (SDK 28) Board: Blue PCB (Hugsun design similar to T9) Storage: 4GB RAM + eMMC Buttons: Power button only (no visible reset button) What I've Tried: 1. SD Card Boot: Downloaded: Armbian_community_26.2.0-trunk.606_Rk3318-box_trixie_current_6.18.18_minimal.img.xz Downloaded: multitool_rk3318-3328.img Flashed to Netac SD card using BalenaEtcher (verified) SD card is detected in Android environment Problem: Box always boots Android, ignores SD card completely 2. USB Boot: Flashed Multitool to USB flash drive Problem: Same result - boots Android, ignores USB 3. Reset Button Method: Tried holding reset button (inside AV port) while powering on Problem: No change, still boots Android 4. Rooting Attempts: Tried KingRoot - stuck on "checking state" forever Device confirmed NOT ROOTED (Root Checker app) Problem: Cannot root to install from Android 5. Maskrom Mode: Have AndroidTool v2.38 ready Problem: PC shows "No Devices Found" when trying to enter Maskrom Current Status: ✅ SD card slot works (Android detects it) ✅ Multitool files accessible on SD card ✅ Have all necessary images downloaded ❌ Cannot boot from SD or USB ❌ Cannot root Android ❌ Cannot enter Maskrom mode My Goal: Install pure Armbian (not Android + Linux apps) for better performance and native Linux experience. Questions: Does anyone have X88 RK3328 working with Armbian? If yes, what method did you use? Is there a specific Armbian build for X88 boards? The generic Rk3318-box image doesn't boot. How to enter Maskrom mode on X88? PC shows "No Devices Found" - am I missing something? Can I convert Armbian .img to Rockchip firmware format for USB Burning Tool? Any X88-specific instructions or device tree files I should use? What I Have Ready: ✅ Armbian image (Rk3318-box minimal) ✅ Multitool image ✅ AndroidTool v2.38 ✅ USB-A to USB-A cable ✅ Willing to backup original Android first Any help or X88-specific guidance would be greatly appreciated! Thanks in advance! 🙏 Device: X88MAX.p2.0.01.d4 SoC: RK3328 (Chip Tag: 33 32 32 48, Flag: RK322H) Storage: Samsung eMMC 64GB FlashID: 45 4D 4D 43 20 Status: Successfully in LOADER mode via RKDevTool v2.86 Android: Backed up and ready Problem: - SD/USB boot ignored by bootloader - Android not rootable (KingRoot fails) - Need Armbian in Rockchip firmware format What I Have: - Device in LOADER mode ✓ - Full Android backup ✓ - RKDevTool v2.86 working ✓ - Armbian_community_26.2.0-trunk.606_Rk3318-box_trixie_current_6.18.18_minimal.img.xz What I Need: - parameter.txt for X88 RK3328 - Armbian partitions in Rockchip format - Or .update file for X88 Tag: @jock Anyone successfully flashed Armbian on X88 RK3328?
  6. Anyone using dedicated fan? Are they working? Mine won't spin.Tried swap polarity, still won't...
  7. Why you do this (on a normal modern Trixie kernel, actually even 1 year newer)? This is what I have (runs rockchip64 7.0-rc3 kernel): root@ranc:~# ls -al /sbin/iptables /etc/alternatives/iptables lrwxrwxrwx 1 root root 22 Nov 1 2023 /etc/alternatives/iptables -> /usr/sbin/iptables-nft lrwxrwxrwx 1 root root 26 Jan 16 2023 /sbin/iptables -> /etc/alternatives/iptables On other Aarch64 computer, it dates back to 2019 already, that is a standard Debian installation, always in-place upgraded since Buster or so. The Linux kernel does things natively as NetFilter, the iptables commands are mapped. Legacy is even older and I guess the old kernel API has been removed. But do research yourself if you want to know, at least 'man iptables-legacy'
  8. After the update/upgrade, all CPUs are now installed nproc 4 This didn't fix my Bluetooth (maybe it's some individual bug in my system?) but since Bluetooth works correctly in the new images for OrangePi 3 LTS, I'm marking this thread as resolved... I'll probably install the latest image soon, although it will be time-consuming. ........................... orangepi3-lts:~# dmesg | grep "CPU" [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.005157] smp: Bringing up secondary CPUs ... [ 0.007070] Detected VIPT I-cache on CPU1 [ 0.007260] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.009368] Detected VIPT I-cache on CPU2 [ 0.009541] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.011117] Detected VIPT I-cache on CPU3 [ 0.011261] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.011373] smp: Brought up 1 node, 4 CPUs [ 0.011398] CPU: All CPU(s) started at EL2 [ 0.011443] CPU features: detected: 32-bit EL0 Support [ 0.011449] CPU features: detected: 32-bit EL1 Support [ 0.011458] CPU features: detected: CRC32 instructions [ 0.011470] CPU features: detected: PMUv3 [ 0.260754] ledtrig-cpu: registered to indicate activity on CPUs [ 0.414642] sun50i_cpufreq_nvmem: Using CPU speed bin speed0 [ 0.457342] WARNING: CPU: 3 PID: 71 at drivers/iommu/iommu.c:612 __iommu_probe_device+0x1a8/0x4a0 [ 0.457375] CPU: 3 UID: 0 PID: 71 Comm: kworker/u16:4 Not tainted 6.18.19-current-sunxi64 #2 PREEMPT Ps. I don't know if I announced the CPU solution too early? Maybe there's a problem with the processor clock speed? .............. cat /etc/default/cpufrequtils ENABLE=false MIN_SPEED=480000 MAX_SPEED=1810000 GOVERNOR=performance root@orangepi3-lts:~# cpu Temperature: 40 °C CPU-0 Frequency: 1608 Mhz CPU-1 Frequency: 1608 Mhz CPU-2 Frequency: 1608 Mhz CPU-3 Frequency: 1608 Mhz root@orangepi3-lts:~# cat /etc/default/cpufrequtils ENABLE=false MIN_SPEED=480000 MAX_SPEED=1810000 GOVERNOR=performance root@orangepi3-lts:~# cat /etc/default/cpufrequtils ENABLE=false MIN_SPEED=480000 MAX_SPEED=1810000 GOVERNOR=performance root@orangepi3-lts:~# root@orangepi3-lts:~# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq 1608000 root@orangepi3-lts:~# cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor performance performance performance performance ............... shouldn't it be : 1810000 ... ?
  9. Anyone got the dedicated Fan header working correctly? It won't spin at all. Enabled the fanctrl overlay. changed pwm rate,the fan won't budge.. Tried stress the CPU but this only cause shutdown
  10. PanVK’s new framebuffer abstraction for Mali GPUs removes OpenGL-specific constraints, unlocking more flexible tiled rendering features in Vulkan. View the full article
  11. Hi, i have amlogic s805 tv box from mxq, how do i run armbian onecloud? bc none of this helped me.
  12. I installed the patch files with "Pb143" in the name on Friday, but unfortunately there was no improvement. Here are the logs: https://paste.armbian.com/dovedafali Can you tell me if I can test something with this? If so, what exactly do I need to do?
  13. logs are incomplete. dmesg is missing completely which would be the most relevant. moved to staging
  14. Why would you use an image for the Zero 3 for the 5B? You cannot simply shove an image for a random board into yours and assume it works...
  15. This is latest edge version 6.18. Should be easily reproducible on your end, effects all rock 5B+ boards and this board is a platinum supported board.
  16. Hi all, Over the past few months working on the A7Z, I’ve successfully ported a number of BSP drivers to Linux 6.18. The code is available here: https://github.com/alexcaoys/allwinner-bsp/tree/linux-6.18.y It’s currently tested on 6.18.19 and should, in theory, work with newer 6.18.y releases. I’ve tried to reuse as much upstream (mainline) drivers as possible, and have also upstreamed support for PCK600 and ET7304 used on the A7Z. Hopefully this helps accelerate ongoing mainline efforts. Feedback, issues, and PRs are very welcome. I may also look into creating branches for Linux 7.x in the future.
  17. Last week
  18. Pami, I have not personally found any LLM capable of generating working DTS files no matter what. It seems to be too niche for the LLM to understand. This DTS could potentially be a good starting ground for the pi, replacing "bcm2835" which refers to the pi zero 1, with "bcm2710" which refers to the pi zero 2. The github repository I linked is a good guide to getting the red displays working for a voron printer using panel-mipi driver, and I referenced it to create the DTS I use for the rock pi 4b. Also, try lowering the SPI speed to 20, 16, or 10 MHz, then raise it when you verify it works. I was frustrating myself for weeks thinking my DTS was broken, when it was fine the entire time, just my SPI speed was too high. robertoj: I appreciate your help, but I believe the issue I have with the red display (I have the same one as pami sent) is a combination of SPI commands being sent at the wrong interval (at the end of the clock cycle instead of in line), as well as insufficient SPI speed - where the display freezes above 24 MHz, and shows extreme visual tearing below it. At RGB666, its too much data for a measly 20MHz SPI rate, and the board does not support any other RGB modes in SPI. Since the TE pin is not exposed on the board, I cannot sync the SPI writes to the display. At least, that is my theory. I've given up on using an SPI display, and instead transitioned to an RGB Parallel display, which uses one gpio pin per color bit. Note that, at least in the display datasheet I received, the display actually does have the pins needed to drive it over DPI RGB Parallel. You can drive the board in 16, 18, or 24 bit mode over DPI RGB Parallel. These pins are not exposed on the board, but you could use an FPC breakout board to interface with these pins, and drive the display in DPI RGB parallel instead (accounting for the backlight voltage needed). The advantage of using RGB Parallel is it natively uses the GPU (RGB Parallel is the same technology as VGA) and has very fast refresh rate. For anyone here in future, any DPI hats that exist, like the adafruit kippah or othermod dpi topper, do not have the correct pinout to interface with this specific ili9486/8, but if you were to rearrange the pins on either the HATS or with an intermediary FPC PCB, then they would work plug and play.
  19. Hello, i tried "Armbian_community_26.2.0-trunk.606_Radxa-cubie-a5e_trixie_edge_6.19.8_minimal.img" and wlan didn't work, i think the device tree is broken Radxa-cubie-a5e kernel 6.19.x as a quick fix, I copy the kernel 6.18.x "sun55i-a527-cubie-a5e.dtb" file to the /boot/dtb/allwinner directory to get wlan working.
  20. maxsub
    @sven-ola there are 3 ways to boot the R2S: 1. Press the boot button before applying power. White USB port connected to a PC. Apply power. It goes into fastboot mode like an android. Theoretically this should let you flash the on-board eMMC. I can successfully put it in fastboot mode but the flashing has not worked. 2. Boot from eMMC 3. Boot from USB. The eMMC has two boot partitions that are fixed size and one large main partition. My project uses the u-boot environment but also does a few minor things. It prioritizes USB if it finds a bootable medium there. It also safely flashes the boot blocks on the eMMC and then the main blocks. It adds some safety checks before flashing. Nothing else.
  21. hi, I installed in usb the last version and boot. something wrong happen here, only left these two upgrades, I tried again with backup-img and falied to boot again
  22. moved to off-topic since not directly related to armbian.
  23. Ok after trying a speeker switcher, switching from cinnimon to the kde version, finnally I tried flashing with the offical armbian flasher, and I tried a bunch of old online solutions that looked similar. Still my headphone doesn't work. I think it is due to armbian thinking the built in sound card is the headphones. But on a positive note the weird unmounting of armbian when my chromebook sleeps or when the lid is closed does not occur on armbian kde. So far kde is more stable than cinnimon.
  24. @José Manuel Márquez Luque try these images https://github.com/NickAlilovic/build/releases/tag/20250306
  25. @Bob-the-great try these images https://github.com/NickAlilovic/build/releases/tag/20250306
  26. At a glance, unless you see your board at https://armbian.com/download, chances are that no one else has gotten that board working. Might be better to post under "Other Families" for unsupported board stuff. @Werner may move later ... Might be crashing. Might be redirecting kernel to a different UART. May be worth checking earlycon and console settings in kernel args? You can try to pass break=premount or similar arguments to pause boot and allow you to poke around and see what's going on?
  27. HI, It looks like you have an RK3518 chip from your photo, and not the 3528? Or was that a typo? In any case I also bought a box from AliExpress. It looks similar to mine with the 3518 chip. If there is a way to extract the ROM Image from my box I can maybe upload it for you somewhere?
