@Tomi Skies It could be your gpio settings. You need to extract your original android dts. https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/4/#comment-187672
Hi, thanks a lot for pointing me in the right direction. Indeed so far I am booting from the SD card. I have erased eMMC with multitool via SSH, as multitool as well is not visible via HDMI. Used the newer images as suggested, same situation: everything works via SSH cmd line, no output on HDMI. Log contains mainly errors as the ones posted above.
Thanks for the answer, @amazingfate! I guess there might be e bug in the driver. Once I have more time (if I have) I will issue a bug report to the kernel devs and will try ti test and send required info. Regards, Tano
I have completed a build for the turing-rk1 SBC with an aim toward getting a functioning graphical console, and possibly installing desktop packages later. I built an image without issue that picked up kernel 6.17.2. git commit: 09160da3b9c1231cf20837e8c857f7e605130449 main branch Command used: ./compile.sh RELEASE=trixie CARD=turing-rk1 BRANCH=edge Image created: Armbian-unofficial_25.11.0-trunk_Turing-rk1_trixie_edge_6.17.2.img When booted, I get an error from dmesg about VOP drivers and HDMI video does not turn on. Is this normal for this board or am I doing something wrong? [ 0.965616] rckchip-drm display-subsystem: [drm:rockchip_drm_platform_probe] *ERROR* No available vop found for display-subsystem. The git commit that introduced this board in Armbian does appear to include GPU support, though I'm not really sure if that means the HDMI output should be working. https://github.com/armbian/build/commit/d564431dc2e2a16dff8d21391603702b43de06b1#diff-1d2956e936e3a376577f803ce53091b41ed47e906602165217f78912496eac63 Maybe I need to build w/ kernel 6.11.x to enable GPU support with these patches? Can someone clarify?
Maybe not? root@rp-satellite-01:~# for X in 0 1;do echo "mmcblk${X}: $(cat /sys/block/mmcblk${X}/device/type)";done mmcblk0: SD mmcblk1: SD root@rp-satellite-01:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sdb 8:16 1 238.3G 0 disk └─sdb1 8:17 1 238.3G 0 part /media/usb mmcblk1 179:0 0 59.6G 0 disk └─mmcblk1p1 179:1 0 59G 0 part /var/log.hdd / mmcblk0 179:32 0 3.6G 0 disk └─mmcblk0p1 179:33 0 3.5G 0 part zram0 252:0 0 233.1M 0 disk [SWAP] zram1 252:1 0 50M 0 disk /var/log zram2 252:2 0 0B 0 disk root@rp-satellite-01:~#
Collabora is proud to sponsor this year's annual GStreamer conference, taking place in London, UK. Join us as we showcase the latest with machine learning analytics, WirePlumber, and more. View the full article
Orange Pi 5 Pro - extend SPI4 to 5 chipselect
Rafael Junio replied to Rafael Junio's topic in Rockchip
I was able to extend, thanks everyone for the support. I attached my final dts, I also changed from spi4 to spi1, because I double check the pinount and spi4 is not mapped. In the original pinout armbian spi1 = orange pi 5 pro spi4. rk3588s-spi1-5cs-spidev.dts -
Thanks for your sharing! While I was trying to perform the upgrade for a Pine64, I happily notice that the latest release of armbian-config actually have an option for the distro upgrade. By following the wizard, Debian was upgrade to trixie.
Try an apt full-upgrade. The libraspberrypi packages have been deprecated recently (e.g. June/July) and recent RPI packages shouldn't depend on them, including raspi-firmware.
How to help Armbian about the new Orange pi sbc, orange pi 6 plus?
Werner replied to olivetree's topic in New boards
Hi, difficult task since there is no support for the whole chip family in the framework yet, but first steps are here:https://github.com/armbian/build/pull/8364 I suggest to start by getting familiar with the framework and how the mentioned pending pr it put together. moved -
Hello! I have an RPi5 8GB board that I bought off of AliExpress, along with a Waveshare PoE M.2 HAT+ ( https://www.waveshare.com/poe-m.2-hat-plus-b.htm ) Initially I tried to use the Noble XFCE image, by following the recommended installation procedure via rpi-imager via a USB drive, hoping to install the system to a Toshiba (Kioxia) NVMe drive. The RPI5 was connected to a CrowView Note. What I saw was that the firmware loaded up the necessary files from the USB drive (then later the micro-SD card), and the initramfs loaded up too, then systemd started up, and probably when the screen usually goes blank for a short time (probably switching to KMS), here, the signal completely drops, and apparently nothing happens. (The messages scroll too fast, and then disappear, and I can't make out anything from the screen content.) I tried looking on the network to see whether the RPi5 comes up at all, but no. Since then, I tried to eliminate elements from my setup to see whether that makes any difference: I removed the Waveshare HAT Swtiched to using a micro-SD card instead of the USB thumb drive Tried to boot it without the CrowView Note Tried using the Noble Server image to eliminate any possible problems with the graphical UI but none of these helped. I now have the bare RPi5 with an active heatsink, and it's still not booting properly. What should I try? Should I try to get serial console working so that I at least see the boot messages? Is there an activity LED on the RPI5 where I could at least configure a heartbeat so that I could check whether the OS is alive at all? Since the OS can't be installed, I can't really submit much diagnostic information.
@going Yes, git is a pain in ass. I think it's better to teach everyone the git commands. Maybe someone will learn from my instructions and contribute to the mainline Linux kernel and Armbian. Transpeed 8k618-t Tv box will always be supported because I learned how to use git commands and submit patches. I hope others will do the same. A lot of the patches are mainlined for h618. I don't think it will be too long before Armbian only needs a Transpeed 8k618 board config to build an image. But of course there's different variations of the same box. I hope this thread helps them because I won't be here forever.
The way the Debian .iso installer does it: sudo apt-get -o APT::Install-Recommends="true" install task-lxqt-desktop That will install a fully functional desktop with a minimal set of applications. If you set Install-Recommends to false, or any other way of installing it (i.e. lxqt), in my experience, the result may not be quite functional.
@remlei I'did uploading this imagem, is minimal, i hope help you! https://drive.google.com/file/d/1esroAyxq2D2kJ5XPB2_pofQ473B-h1_S/view
Dont write that "fbi works correctly", when it is not. The display remains white, and the kernel doesn't show any errors. * Re-check your wiring * Disconnect the touch part of the LCD pins * Try reversing the polarity: dc-gpios = <&pio 2 6 1>; << change the 1 to 0 reset-gpios = <&pio 2 9 1>; << change the 1 to 0 If the CPU is successful sending the reset signal, the data/command, the chip select and any bytes through SPI, at least the LCD should turn black.
Robert Steinman replied to Hqnicolas's topic in Rockchip CPU Boxes
@Hqnicolas Thanks for your response and apologies being so slow to reply busy IRL and then I forgot I used Google to sign up to this site.... yeah... Okay thanks - I thought it would just be a changing of timing so to speak on x86. In this case if I plan to develop for something I also go for the lowest variant of it, ofc, at this time both were Android. Rather code closer to the "metal" than bringing a whole web browser in to say "hello world" The images came from a link on this thread; either yourself or another member. Yeah I noticed a certain lag on the ethernet with 1GBit connection -- it has all the resources available yet it pings hard and downloads fluctuate. My plans for this Armbian is WiFi Repeater (router is broadcom and no Open- or DD-WRT alternative) to relay the signal. I don't want mesh, I don't need a TPLink account. The box will provide some services to Orange/Raspberry Pi systems. Right. I'm against AI So last thing I'd do. A link was provided but as I said expired. I'm sure there's differences in SDCard holders so didn't want to order two of the wrong type! Ah obrigado! I think your link may have solved it. I'll look in to it a bit in the future. Amazing how an Firestick turned me to Chinese TV boxes which are quite capable once you get rid of the Spyware. What I will say is, I think these boxes may have poor solder joints on the WiFi sub board, was hoping it was a misconfiguration my 8G model no longer recognizes the Wifi board, when I get the SD card holders I'll reflow it ad see. dmesg, lsusb, lspci know nothing of it. my 2G box the WiFi is fine. Regards -
I know this is older, but you need fping6 as well. See inside my install script for Zabbix server https://github.com/sgjava/install-zabbix/blob/589abd9527b1dbd505776a4c80afe8e515aef878/scripts/install.sh#L210
I simply don't need or want a desktop or anything with icons. I do use a few things on occasion that have toolbars like libre office or krita, gimp, ink scape, and kicad. But otherwise I have no use for all that mess of desktop window management and mousing. Xfce is ok for a half day of installing stuff. But otherwise I have no use for that stuff.
due to network limitations, how to compile Ubuntu 22.04 Gnome OS image in offline mode, build.sh need to download many debs,can I download them in advance,then install them locally. I have already downloaded kernel and uboot.
need help regarding wifi, i tried different server img and found no working wifi, should i just install armbian full or keep searching,,,,,plus is latest recommended or older versions......my device is 1gb ram with 8 rom, it may sound cheap, but i got this piece for free just tryin to repurpose it rather than getting a pi, i need it only for klipper, i got no lan ports left(lan ports are filled with different uses), only wifi, or should i just give up
Thank you so much for your help and explaining how it should work! I tried all the cores that you ordered - it only worked on this: #unnamed -a Linux orangepi5-plus 6.16.4-edge-rockchip64 #1 SMP PREEMPT Thu Aug 28 14:34:51 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux I put it like this: @apt install linux-image-edge-rockchip64 linux-headers-edge-rockchip64 The old cores were not suitable because the wifi card 0002:21:00.0 Network controller: MEDIATEK Corp. Device 7925 refuses to run on cores less than 6.12.X I bow low to you! cat /boot/armbianEnv.txt verbosity=1 bootlogo=true console=both overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588-orangepi-5-plus.dtb rootdev=UUID=e08e0355-09a7-41ad-a6db-fa17566a7f12 rootfstype=ext4 extraargs=cma=1G usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u With the extraargs=cma=1G parameter, videos in the browser somehow load faster.
Not planned but should be possible. A good start would be to copy the mentioend 2f and extract the device tree from official image and add it to vendor kernel source. If you're lucky that's all what's needed to get it to work.
moved to offtopic. not using Armbian. If you need support with that image, ask at the place where you downloaded from.
Anybody running a 100% wayland system?
robertoj replied to robertoj's topic in Software, Applications, Userspace
I got my issue resolved with labwc+greetd+nwg-hello See this link https://github.com/nwg-piotr/nwg-hello/issues/43 Please check it and post any corrections if needed Getting rpi-greeter (no python) and wf-panel-pi (combines panel and launcher in compact form) would be ideal, but not resolved yet. If anyone is interested in getting rpi-greeter working, this is my partial progress, and I still cannot make it start under lightdm, without any X11: sudo apt install lightdm accountsservice polkitd These might be needed. I installed them the day after I installed greetd and ngw-hello. Note: I am working from a minimal debian trixie image appmenu-gtk-module-common libaccountsservice-dev gir1.2-accountsservice-1.0 liblightdm-gobject-dev liblightdm-gobject-1-0 libgtk-3-dev gnome-common nasm ~$ mkdir rpi-greeter ; cd rpi-greeter wget https://github.com/raspberrypi-ui/pi-greeter/archive/refs/heads/master.zip unzip master.zip ; cd rpi-greeter-master autogen.sh ./configure make sudo make install Change /etc/lightdm/lightdm.conf with: greeter-session=pi-greeter-labwc Test with: $ sudo lightdm --test-mode --debug or $ sudo systemctl start lightdm $ journalctl -b -u lightdm.service The error is: Oct 13 22:01:49 orangepizero3 lightdm[845]: Error updating user /org/freedesktop/Accounts/User1000: GDBus.Error:org.freedesktop.Accounts.Error.PermissionDenied: Not authorized: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.PolicyKit1 was not provided by any .service files DEBUG: Could not run plymouth --ping: Failed to execute child process ?plymouth? (No such file or directory) I think I am very close to getting rpi-greeter working. What could be missing? I see that in a raspberry pi, the folder /etc/xdg/labwc-greeter/ exists, with 3 files inside, but in armbian, it doesn't exist. Should it be created by sudo make install? sudo nano /var/log/lightdm/lightdm.log: Nothing weird. Only: [+0.07s] DEBUG: Session pid=6392: Running command /usr/bin/labwc -C /etc/xdg/labwc-greeter/ (and this folder /etc/xdg/labwc-greeter/ does not exist) In raspberry: /etc/xdg/labwc-greeter/ contains autostart, rc.xml and environment sudo nano /var/log/lightdm/seat0-greeter.log: ** (process:6392): WARNING **: 00:23:07.745: Failed to open CK session: GDBus.Error:org.freedesktop.DBus.E> 00:00:00.000 [ERROR] [../src/main.c:202] XDG_RUNTIME_DIR is unset The etc/xdg/labwc-greeter/autostart, etc files come from a package named raspberrypi-ui-mods (raspberry$ dpkg -S /etc/xdg/labwc-greeter/autostart) What part of https://github.com/raspberrypi-ui/raspberrypi-ui-mods would get my lightdm+labwc+rpigreeter working? Copying the /etc/xdg/labwc-greeter/ folder with the 3 files, with the same permissions, allow the pi-greeter to display (it is very plain), but after entering the password, the text mode display shows for 2 seconds, then the labwc black background and cursor shows for 1/4 second, then returns to the login screen. Found this error in the log: /etc/xdg/labwc-greeter//autostart: 2: /usr/bin/kanshi: not found Final part of solution: lightdm should contain: user-session=LXDE-pi-labwc Create file /usr/share/wayland-sessions/ LXDE-pi-labwc.desktop: [Desktop Entry] Type=Application Name=Labwc Desktop on Wayland Exec=/usr/bin/labwc rpi-greeter does not allow selection of other sessions: only labwc
