  2. Here's what I get when booting with the cubieboard dts: [ 1.728145] sun4i-drm display-engine: bound 1e00000.display-frontend (ops 0xc0a991d0) [ 1.728324] sun4i-drm display-engine: bound 1e20000.display-frontend (ops 0xc0a991d0) [ 1.728769] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0a98948) [ 1.729127] sun4i-drm display-engine: bound 1e40000.display-backend (ops 0xc0a98948) [ 1.729663] sun4i-drm display-engine: No panel or bridge found... RGB output disabled [ 1.729694] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a96e08) [ 1.730170] sun4i-drm display-engine: No panel or bridge found... RGB output disabled [ 1.730197] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xc0a96e08) [ 1.731739] sun4i-drm display-engine: bound 1c16000.hdmi (ops 0xc0a99bb4) [ 1.732958] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 [ 1.733040] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes [ 1.740576] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes [ 20.185738] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 20.660147] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 20.680927] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 29.081755] [drm] Initialized lima 1.2.0 20200215 for 1c40000.gpu on minor 1 And here's what I get when I boot with the topwise a721 dts: [ 3.444277] sun4i-drm display-engine: bound 1e00000.display-frontend (ops 0xc0a991d0) [ 3.444440] sun4i-drm display-engine: bound 1e20000.display-frontend (ops 0xc0a991d0) [ 3.444985] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0a98948) [ 3.445348] sun4i-drm display-engine: bound 1e40000.display-backend (ops 0xc0a98948) [ 3.446154] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a96e08) [ 3.446799] sun4i-drm display-engine: No panel or bridge found... RGB output disabled [ 3.446830] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xc0a96e08) [ 3.473706] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 [ 3.555810] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device [ 7.940078] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 8.543295] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 8.553328] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 15.005964] [drm] Initialized lima 1.2.0 20200215 for 1c40000.gpu on minor 1 Thanks, Shivam
  4. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  5. If you need hdmi support use vendor or edge kernel. 6.12 was released with a bare minimum of support for rk3588 so nonworking hdmi is kind a expected.
  6. I added a patch that activates the gpu. https://lore.kernel.org/linux-sunxi/20250706025625.2707073-1-iuncuim@gmail.com A ready to install kernel is available for manjaro. But it's worth realizing that without output it will be useless at the moment.
  7. v4l2loopback-dkms 0.12.7-2 fails to build make.log: DKMS make.log for v4l2loopback-0.12.7 for kernel 6.12.32-current-rockchip64 (aarch64) Sat Jul 5 09:16:17 PM CDT 2025 Building v4l2-loopback driver... make -C /lib/modules/6.12.32-current-rockchip64/build M=/var/lib/dkms/v4l2loopback/0.12.7/build modules make[1]: Entering directory '/usr/src/linux-headers-6.12.32-current-rockchip64' CC [M] /var/lib/dkms/v4l2loopback/0.12.7/build/v4l2loopback.o /var/lib/dkms/v4l2loopback/0.12.7/build/v4l2loopback.c: In function ‘vidioc_querycap’: /var/lib/dkms/v4l2loopback/0.12.7/build/v4l2loopback.c:717:9: error: implicit declaration of function ‘strlcpy’; did you mean ‘strncpy’? [-Werror=implicit-function-declaration] 717 | strlcpy(cap->driver, "v4l2 loopback", sizeof(cap->driver)); | ^~~~~~~ | strncpy cc1: some warnings being treated as errors make[3]: *** [scripts/Makefile.build:229: /var/lib/dkms/v4l2loopback/0.12.7/build/v4l2loopback.o] Error 1 make[2]: *** [/usr/src/linux-headers-6.12.32-current-rockchip64/Makefile:1945: /var/lib/dkms/v4l2loopback/0.12.7/build] Error 2 make[1]: *** [Makefile:224: __sub-make] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-6.12.32-current-rockchip64' make: *** [Makefile:43: v4l2loopback.ko] Error 2 Edit: I had the wrong make.log contents. The old one was after I tried to fix it and failing. The actual build error is missing strlcpy().
  8. I've gone round in circles with this one and it seems that there might not be a solution, so will set it up again on the NVME drive. Thanks for all the help offered.
  9. Yesterday
  10. Pull Request submitted: https://github.com/armbian/build/pull/8360
  11. I hadn't done an upgrade but a fresh install; (v25.5.1 for Raspberry Pi 3 Model B running Armbian Linux 6.12.28-current-bcm2711) Realised that I had the same problem, only channel 2 was present; though I only realised something was missing when I'd tried RaspberryOS on a Pi Zero with the same i2c device. Adding to the /boot/config.txt didn't of itself solve the issue; adding the i2c1 to the armbian-config overlays also didn't see. However I did find the `/boot/firmware/config.txt` that has a lot more settings, and seems to be where armbian-config edits Note the `dtparam-i2c_arm=on` line... which was commented out. Adding that back and it works... (well after figuring out I needed to level shift the i2c device but that's another story) # For more options and information see # http://rptl.io/configtxt # Some settings may impact device functionality. See link above for details # Uncomment some or all of these to enable the optional hardware interfaces dtparam=i2c_arm=on #dtparam=i2s=on #dtparam=spi=on # .. dtoverlay=dwc2 i2c0 i2c1 i2c-gpio vc4-kms-v3d
  12. Remote backup maybe only as data ... e.g. restic / rsync programs In my opinion it is best to make a backup of the SD card in linux connect miniSD card and make a backup in terminal: fdisk -l if your SD card is: sda / sda1.... then choose sda ! and then make a backup: dd if=/dev/sda of=/path_to_backup.img status=progress Restoring the image to the SD card with the same size: dd bs=4M if=/path_to_copy.img of=/dev/sdb status=progress If you want to burn the image to a smaller capacity SD card because, for example, the system is only 30% occupied, use the program:PiShrink https://github.com/Drewsif/PiShrink it works great for me for Armbian 🙂 sudo pishrink.sh /path_to_backup.img / /new_backup-Pishrink.img
  13. I use the Station M2 image with dtb joined. Adapt fdtfile entry in /boot/armbianEnv.txt as needed. rk3566-box-demo_x96x6_24-custom.dtb
  14. I get it: DDR Version V1.10 20190926 In ID:0xFFF 330MHz LPDDR3 Bus Width=32 Col=10 Bank=8 Row=15 CS=2 Die Bus-Width=32 Size=2048MB mach:14 rd addr 0xC0000000 = 0xFFED ERR
  15. please show the output of "apt policy zfs-dkms" but essentially, this looks the same as your other rodeo/struggle with this board and dkms. As mentioned there, you are much better off with btrfs instead of zfs on your SBC.
  16. @ScoreABSM Sorry I had to revert that PR. It seemed to initially work, but in the end it started hitting fails more than it functioned. https://github.com/armbian/build/pull/8344 I'm still on the case.
  17. Last week
  18. I confirm that this repository ffmpeg works for me: * Orange Pi Zero 3 * self built image with Debian Trixie and Xfce desktop * Linux Edge 6.15.0 * Login in Xfce X11 mode * follow all the instructions in original post * mpv plays most mp4s VERY SMOOTHLY * some resolutions will crash mpv with "Segmentation Fault" and cause a kernel crash shortly after Then, to make it work with an ili9488 LCD, I needed to change these: * install LCD DTS, firmware, remove plymouth (see my ili9488 thread) * I can't make X11 work with my LCD driver and panel-mipi-dbi-spi recently... (still investigating why it worked before) * but I can make it work with labwc and sway * install seatd (authorization library), labwc (I only have experience with labwc) and foot (wayland terminal) * Choose labwc instead of xfce in lightdm login * from SSH session: DISPLAY=:0 foot& * in foot: mpv videofile.mpv * it plays most mp4s VERY SMOOTHLY * some resolutions will crash mpv with "Segmentation Fault" and cause a kernel crash shortly after
  19. Whatever garbage ones I can find on ebay for cheap. In this case: KIOXIA 256GB SSD BG5 M.2 2230 NVMe PCIe Gen4 x4 KBG50ZNS256G https://www.ebay.com/itm/176432690192
  20. do you have correct permissions? maybe run as root on my rock3a content is fine but got [Jul 4 20:19] warn_alloc: 19 callbacks suppressed [ +0.000026] dec0:0:hevc_rkm: page allocation failure: order:5, mode:0x40dc0(GFP_KERNEL|__GFP_COMP|__GFP_ZERO), nodemask=(null),cpuset=user.slice,mems_allowed=0 [ +0.000115] CPU: 2 PID: 2339021 Comm: dec0:0:hevc_rkm Not tainted 6.1.115-vendor-rk35xx #1 [ +0.000011] Hardware name: Radxa ROCK3 Model A (DT) [ +0.000011] Call trace: [ +0.000008] dump_backtrace+0xf0/0x12c [ +0.000023] show_stack+0x20/0x30 [ +0.000011] dump_stack_lvl+0x7c/0xa0 [ +0.000016] dump_stack+0x18/0x34 [ +0.000010] warn_alloc+0xe0/0x17c [ +0.000012] __alloc_pages+0x524/0x854 [ +0.000010] __kmalloc_large_node+0xb8/0x114 [ +0.000012] __kmalloc+0x4c/0x100 [ +0.000009] __regset_get+0x60/0xd8 [ +0.000013] regset_get_alloc+0x1c/0x28 [ +0.000010] elf_core_dump+0x500/0xbc8 [ +0.000011] do_coredump+0xabc/0x100c [ +0.000012] get_signal+0x1b8/0x634 [ +0.000013] do_notify_resume+0x194/0xda8 [ +0.000010] el0_da+0x5c/0x70 [ +0.000012] el0t_64_sync_handler+0xc0/0x13c [ +0.000010] el0t_64_sync+0x19c/0x1a0 [ +0.000013] Mem-Info: [ +0.000010] active_anon:112109 inactive_anon:125820 isolated_anon:0 active_file:31285 inactive_file:45270 isolated_file:0 unevictable:0 dirty:2210 writeback:0 slab_reclaimable:16665 slab_unreclaimable:16446 mapped:15455 shmem:105 pagetables:1861 sec_pagetables:510 bounce:0 kernel_misc_reclaimable:0 free:82604 free_pcp:125 free_cma:35560 [ +0.000022] Node 0 active_anon:448436kB inactive_anon:503280kB active_file:125140kB inactive_file:181080kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:61820kB dirty:8840kB writeback:0kB shmem:420kB writeback_tmp:0kB kernel_stack:4192kB pagetables:7444kB sec_pagetables:2040kB all_unreclaimable? no [ +0.000017] DMA free:330416kB boost:14364kB min:19988kB low:21964kB high:23940kB reserved_highatomic:2048KB active_anon:448188kB inactive_anon:503568kB active_file:125312kB inactive_file:181216kB unevictable:0kB writepending:8840kB present:2095104kB managed:2014252kB mlocked:0kB bounce:0kB free_pcp:544kB local_pcp:0kB free_cma:142240kB [ +0.000018] lowmem_reserve[]: 0 0 0 0 [ +0.000015] DMA: 20626*4kB (UMEHC) 16291*8kB (UMEHC) 4462*16kB (UMHC) 1263*32kB (UMHC) 92*64kB (MHC) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 330528kB [ +0.000049] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB [ +0.000010] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=32768kB [ +0.000008] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB [ +0.000009] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=64kB [ +0.000008] 129311 total pagecache pages [ +0.000007] 52636 pages in swap cache [ +0.000006] Free swap = 11240188kB [ +0.000007] Total swap = 11792380kB [ +0.000006] 523776 pages RAM [ +0.000006] 0 pages HighMem/MovableOnly [ +0.000006] 20213 pages reserved [ +0.000007] 135168 pages cma reserved command used /usr/share/jellyfin-ffmpeg/ffmpeg -y -c:v hevc_rkmpp -i 2025-06-29_22-05_rec.ts -map v -c:v h264 _rkmpp -b:v 8000k -map 0:1 -c:a copy -t 300 dvbt2.h264.ts
  21. I have a BananaPi M1, same SoC, same kernel (the upgrade went fine for me last week). Although I only use it for its SATA connector (big HDD as NBD, OS on SD-card), audio 3.5mm plug did work. Maybe I could see what mine does, but rather with a default Debian player, like mpv, works via ssh CLI. I can generate some FLAC file, but I don't want to search for the specific song/title. Also I could do a temp exfat on a loopdev or so or just play from NFS, Btrfs or Ext4 loopdev.
  22. Good to meet a fellow armbian android tv box fan. We need a logo or shorthand alias for fans 🤣. ZFS - was easy but not clear. Inside armbian-config under System/Storage is a script to install ZFS support. I did this and it didn't work... then undid it and then installed it a second time and it worked. Somewhere in there I also ran the standard commands for install: sudo apt install zfsutils-linux sudo apt install zfs-fuse Probably after the first uninstall... but the commands indicate failure. But then installing the second time seemed to work. Did that on both of these boxes I have working. Thanks for the ethtool command. Here's my results on box1 ports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised pause frame use: Symmetric Receive-only Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Link partner advertised pause frame use: Symmetric Receive-only Link partner advertised auto-negotiation: Yes Link partner advertised FEC modes: Not reported Speed: 1000Mb/s Duplex: Full Auto-negotiation: on master-slave cfg: preferred slave master-slave status: slave Port: Twisted Pair PHYAD: 0 Transceiver: external MDI-X: Unknown netlink error: Operation not permitted Current message level: 0x0000003f (63) drv probe link timer ifdown ifup Link detected: yes Not an expert and first time reading this command but looks like 1000 is the answer. Crazy thing - box 2 does not have the line "MDI-X: Unknown" shown towards the bottom and "Port: MII" instead of "Port: twisted pair" but is otherwise identical. Posting in case it helps anyone else - but these are beyond me. If you confirm that the above = 1000 I will update both my box running posts. By the way - Another favorite is Software/Management/Cockpit. Easy to see how the server is doing. Plus it has a built in terminal and file manager. Add that to Tailscale and you can check on the server or grab a file while out of the house. curl -fsSL https://tailscale.com/install.sh | sh Those are my favorites. What are yours?
  23. The way I understand it is that you only need the full firmware package in a few exceptional circumstances. What is the wifi chipset on your SBC? Do you have the wireless-regdb package installed? "dpkg -l wireless-regdb"
  24. Thank you for sharing. Would be good to have your findings corroborated by some of official documentation. Thanks again for sharing.
  25. If they boot, I wouldn't worry about any difference.
  26. sounds good. good luck and keep us posted!
  27. this is somewhat 'off-topic' but still relevant to 'orange pi zero 3' If Orange Pi Zero 3 is operated in warm climates (e.g. room temperature 30 deg C etc) , it can at times run up to like 60 deg C. this is in open still air adding a fan blowing at it reduce that by some 20 deg C to 40 deg C ! And this is my ghetto fan setup, no fancy case, no heatsink nothing, just a single long machine screw that lifts it up checking temperatures is easy > armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq Tcpu C.St. 18:03:39 480 MHz 0.00 0% 0% 0% 0% 0% 0% 40.8 °C 0/7^C strictly speaking, 60 deg C is 'nothing to scream about' , I've a Rpi 4 hitting up 80 deg C and it throttles. similarly use a fan blowing at it + a heat sink over the cpu, drastically reduce running temperatures. for 'occasional' use, I don't think it is necessary to have a fan blowing at the Orange Pi Zero 3. I think it is feasible to run at lower temperatures if I disable and unclock the GPU and HDMI, but for now I'm not sure how to go about doing that. Initially, I'm thinking maybe the wifi is causing it, but now I don't think so, it is moderately likely the gpu is heating it up a bit. And still air don't seem to dissipate heat very well.
  28. Hello @Aknot, better late than never? This is likely because USB OTG support is on out of the box now. You used to have to add an overlay to get it to work. You will need to modify the the overylays to change this.
  29. I disassembled my tv box - there are 4 screws under the 4 rubbery feet. Removed the motherboard and I drilled some holes of 1/4 inch (7 mm) diameter through the bottom plastic piece. Then I placed a USB fan underneath the tv box and wow the temperature really goes down and stays down around 45 C to 60 C depending on work load. The fans are 80mm and 120mm in size. I chose 120mm to be sure.
