  2. I managed to build "meson-sm1-x96-air-gbit.dtb" using the method described by @Jean-Francois Lessard but I haven't added anything to the "extlinux.conf" file yet. Then I issued the command "$ make module" and it seems to me that the compilation went correctly. Then I did "$ sudo make module-install" and here are the errors: $ sudo make module-install make -C /lib/modules/6.12.33-current-meson64/build M= modules_install INSTALL_MOD_PATH=/ make[1]: Enter the directory '/usr/src/linux-headers-6.12.33-current-meson64' SYMLINK //lib/modules/6.12.33/build make[3]: *** No rules to make an object 'modules.order', required by '//lib/modules/6.12.33/modules.order'. Stop. make[2]: *** [/usr/src/linux-headers-6.12.33-current-meson64/Makefile:1853: modules_install] Error 2 make[1]: *** [Makefile:224: __sub-make] Error 2 make[1]: Leaving the directory '/usr/src/linux-headers-6.12.33-current-meson64' make: *** [Makefile:35: module-install] Error 2
  3. It is Allwinner H618, Quad-core ARM Cortex™-A53 processor. Yes it is external USB network card, which I used just to be able to send logs made via armbianmonitor to the internet. The state You see in the logs is just latest stage of many different attempts: with custom overlays and/or fixes on the sun50i-h618-bananapi-m4-zero.dtb (decompile, fix, compile, boot). In addition have tried some patches using H616 files. I also found problem is due to, PHY isn't properly powered on, based on topic: https://github.com/armbian/build/pull/6617 but after plenty of tries didnt manage to make it work ;(
  5. @KrzyPacu The Amlogic TV Box builds use extlinux.conf. So you should add your overlay info in that file (/boot/extlinux/extlinux.conf). I believe the syntax for extlinux is: OVERLAYS /dtb/amlogic/overlay/... (I'd recommend placing it just below the FDT line) (Note: I've never tried to load an overlay through extlinux, but have been intending to try it some day. Let us know how it goes)
  6. Hello everyone, I'm currently working on a custom firmware project for the Allwinner V851S/V851SS SoC (e.g., dash cam or smart camera). I've reached the stage where I need to modify and re-sign the firmware images (TOC0/TOC1) for use with tools like PhoenixCard. Unfortunately, the tools found on GitHub (e.g., dragonsecboot, pack_tools, boot0, etc.) are often incomplete or fail to build due to missing references (e.g., rsa_sign_main, GetFullPath, etc.). 🔍 I'm looking for a complete and working version of the following tools: dragonsecboot pack boot0 sunxi_tools Full config files such as dragon_toc.cfg, sys_config.fex Working pack_tools with all required source files Full Tina SDK for V851S or V851SS 🎯 My goal is to properly sign and rebuild TOC0/TOC1 and PACKAGE images, and build a customized embedded Linux system. 📤 If anyone has the official SDK or a working toolchain, I’d really appreciate it if you could share it via Google Drive, Mega, Transfer.sh, or any other file host. Thank you in advance to anyone who can help 🙏
  7. > sunxi-gmac 5030000.ethernet end0: No PHY found! The first question. What brand of chip is used in your case? The second question. Is this an external device? [ 341.101053] usb 2-1: new high-speed USB device number 2 using ehci-platform [ 341.257994] usb 2-1: New USB device found, idVendor=0b95, idProduct=772b, bcdDevice= 0.01 [ 341.258024] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 341.258033] usb 2-1: Product: AX88772B [ 341.258039] usb 2-1: Manufacturer: ASIX Elec. Corp. [ 341.258045] usb 2-1: SerialNumber: E5A1DD [ 341.902647] asix 2-1:1.0 (unnamed net_device) (uninitialized): PHY [usb-002:002:10] driver [Asix Electronics AX88772C] (irq=POLL) [ 341.905987] Asix Electronics AX88772C usb-002:002:10: attached PHY driver (mii_bus:phy_addr=usb-002:002:10, irq=POLL) In order for the ethernet-phy to work, it is necessary to turn on the PWM on the internal pin of the processor. As example see: arch/arm64/boot/dts/allwinner/sun50i-h618-orangepi-zero2w.dts and arch/arm64/boot/dts/allwinner/sun50i-h618-orangepi-zero2w.dts#L521-L539
  8. Building on our Open Source strengths in AI and data-driven solutions, Collabora's ML team, led by Marcus Edel, Vineet Suryan, & Aaron Boxer, has taken first place in Track 3 of the ICME 2025 Grand Challenge on Video Super-Resolution for Video Conferencing. View the full article
  9. @KrzyPacu Start by copying your original dtb into tm16xx-display folder: cd tm16xx-display cp meson-sm1-x96-air-gbit.dtb original.dtb # or alternatively run: make extract-dtb Then, assuming the corresponding device tree source overlay in the "devices" subfolder is "x96-max-1gbit.dtso", build the updated dtb: make x96-max-1gbit.dtb # <-- same name as the dtso file in devices subfolder but with dtb extension Finally, replace the original dtb of your boot path with the updated one (first keep a copy of your original dtb somewhere else, just in case) and reboot: cp release/x96-max-1gbit.dtb /boot/dtb/{YOUR_DTB_PATH}.dtb reboot
  10. $ make meson-sm1-x96-air-gbit_mod.dtb ORIGINAL_DTB=meson-sm1-x96-air-gbit.dtb make: *** No rules for object execution 'meson-sm1-x96-air-gbit_mod.dtb'. Stop. https://github.com/jefflessard/tm16xx-display/blob/main/README.md#configure-the-device-tree I can't do option 1 because I don't have the "/boot/armbianEnv.txt" file . Where do I add the entry "user_overlays=tm16xx"
  11. Hi @KrzyPacu I can only provide basic instructions without any support regarding loading overlays. It's not supported on every device (and I personally don't own a device which supports this). You can always search for other posts on device tree overlay for your device if you absolutely want to use overlays. Though, you can easily embed the device tree overlay into your dtb instead. This is what I do personally. You can check instructions of Option 2: Create an updated dtb at : https://github.com/jefflessard/tm16xx-display/blob/main/README.md#configure-the-device-tree
  12. I am trying to run this driver on Vontar X3 Armbian 25.8.0-trunk.163 bookworm. I stopped at the point "Edit /boot/armbianEnv.txt to load the overlay" because I do not have the armbianEnv.txt file. What should I do next to add the generated file "hk1-x3.dtbo" to my device tree file "meson-sm1-x96-air-gbit.dtb"?
  13. armbianmonitor logs: https://paste.armbian.com/rolisaboru I’m running Armbian 25.2 on a Banana Pi BPI-M4-Zero (Allwinner sun50i-h618). EMAC1 (ethernet@5030000) with its internal PHY never comes up: sunxi-gmac 5030000.ethernet end0: renamed from eth0 … No PHY found! … phy init again… No PHY found! … phy init failed So far I have tried: 1. Directly patching full.dts Enabled /soc/ethernet@5030000 (status = “okay”) Added phy-mode = "rmii", pinctrl-0 = <&rmii_pins>, phy-handle, phy-supply etc. Defined a simple ethernet-phy@0 under MDIO. Recompiled to sun50i-h618-bananapi-m4-zero.dtb and rebooted. 2. User overlay (.dts → .dtbo) Created fragments to: Turn on /soc/ethernet@5030000/mdio Inject an ethernet-phy@0 node Enable EMAC1, assign RMII pins, MDIO and PHY handle Compiled with dtc -@ and loaded via user_overlays=bpi-m4z-eth in armbianEnv.txt. 3. Following Armbian build PR #6617 Tried the patch for H618’s internal AC300 PHY from https://github.com/armbian/build/pull/6617 No change: PHY still not detected, no power-up. 4. Troubleshooting notes Overlay apply errors: FDT_ERR_NOTFOUND dtc compile errors on duplicate or missing phandle references Verified pinctrl entries (rmii-pins) and alias names match base DTS I’ve collected a full hardware/software report via armbianmonitor—see the logs here: https://paste.armbian.com/rolisaboru What I’m looking for A known-good snippet of device-tree (base DTS or overlay) that brings up the internal EMAC1 PHY on sun50i-h618 Advice on any missing power-or-clock settings or MFD nodes required for the AC300 PHY Confirmation whether additional kernel/config patches are needed Thanks in advance for any pointers!
  14. It sounds like you're in a tough spot with your x88 box, but there are definitely a few things you can try to unbrick it. Check Power Supply: As you mentioned, the power supply might be outputting 13V, which is not ideal. It's crucial to have a stable 5V supply for the device to boot properly. If you can, try using a different power adapter (5V, 2A) and see if that helps stabilize the boot process. Use a Correct Recovery Image: Make sure you're using the correct image for the box. It seems like you were trying to burn the image directly, but if the process was interrupted, it could leave your internal storage in an inconsistent state. Try downloading the official firmware for your box model from the manufacturer's site (if available) or from trusted forums where users with similar devices share their files. Try the USB Burning Tool: Some boxes like this one can be recovered using a tool like the USB Burning Tool (if it's based on Rockchip). You can try flashing the firmware through USB using the tool while the box is in recovery mode. Here’s a general approach: Download and install the USB Burning Tool. Put your box into MaskROM Mode (this usually involves shorting specific pins or pressing a button while plugging the box into your computer via USB). Connect your device to the PC and use the USB Burning Tool to flash the firmware. Serial Console Output: If you're comfortable with it, connecting a serial console to the box can give you a lot of insight into where things are failing. This could help identify whether it's a hardware or software issue. The serial output could give you error messages that could point to a specific issue (e.g., faulty bootloader or file system corruption). SD Card Recovery: If you can't get it to boot from the internal flash, continue using the SD card with a stable Armbian image. If the internal storage is corrupt, you might still be able to boot and recover your box through the SD card by reinstalling the firmware on the internal storage via the system running off the SD card. If you haven't already, you could also try reaching out to the manufacturer or seller for support, as they might be able to help you with the recovery process. But if that’s not an option, digging into the serial console is definitely your best bet. Good luck! Hopefully, you'll be able to get your device back up and running soon.
  15. Good day, respected Balbes150. Please advise an Armbian build for the Roc-rk3588s-pc v1.1, with support for an M.2 NVMe SSD, intended to be used as a "smart home" server. The image will be installed on an SD card. The single-board computer is connected to the home router via Ethernet cable. HDMI is only used temporarily to connect to a TV for initial setup (further configuration will be done via SSH). The board will run Docker containers. Thank you so much in advance!
  16. Hello! I try to flash my H96Max on RK3318 but i cannot load armbian. After success flash armbian to emmc i remove sd and nothing, nothing load and nothing in uart port, only red led light and thats all. Здравствуйте! Я пытаюсь прошить свой H96Max на RK3318, но не могу загрузить armbian. После успешной прошивки armbian на emmc я извлекаю SD-карту, и ничего, ничего не загружается и ничего не отображается в последовательном порту, только красный светодиод и всё. when i'm load from sd multitool i get this log from uart i'm try to find u-boot on my h96max emmc and nothing, first 100bytes empty. Where i can get u-boot? LoadLog.txt
  17. They will provide you new drivers only if you will pay them to do that for you. End users, including this project, can do nothing about - we have negative budget and can only do best-effort work to keep those drivers at least operational with recent kernels: https://github.com/armbian/build/tree/main/patch/misc while bulk of the patches goes directly to the Git of specific driver. What you are hoping exceeds ability of amateur maintainers, those few people that are actually looking into the code and fix bugs that are made by kernel API changes. HW vendor is usually long gone from there - their development capacity is also limited and they are focused into current products. FYI
  18. A10 / A20 hdmi support was reported as broken and bug was recorded https://armbian.atlassian.net/browse/AR-2674 some time ago.
  19. there are a few caveats that may need a bit of attention It is documented somewhere that if you use channel 0, the driver would automatically select an appropriate channel / frequency. However, it seemed that back then initially while I tested it, that didn't seem to work. (i'm not sure if it may have changed) hence to list the channels one needs to run iw list and you would get a list of channels like such * 2412 MHz [1] (20.0 dBm) * 2417 MHz [2] (20.0 dBm) * 2422 MHz [3] (20.0 dBm) * 2427 MHz [4] (20.0 dBm) * 2432 MHz [5] (20.0 dBm) * 2437 MHz [6] (20.0 dBm) * 2442 MHz [7] (20.0 dBm) * 2447 MHz [8] (20.0 dBm) * 2452 MHz [9] (20.0 dBm) * 2457 MHz [10] (20.0 dBm) * 2462 MHz [11] (20.0 dBm) * 2467 MHz [12] (20.0 dBm) * 2472 MHz [13] (20.0 dBm) * 2484 MHz [14] (20.0 dBm) * 5170 MHz [34] (disabled) * 5180 MHz [36] (20.0 dBm) * 5200 MHz [40] (20.0 dBm) * 5220 MHz [44] (20.0 dBm) * 5240 MHz [48] (20.0 dBm) * 5260 MHz [52] (20.0 dBm) (radar detection) * 5280 MHz [56] (20.0 dBm) (radar detection) ... * 5720 MHz [144] (20.0 dBm) (radar detection) * 5745 MHz [149] (20.0 dBm) * 5765 MHz [153] (20.0 dBm) * 5785 MHz [157] (20.0 dBm) * 5805 MHz [161] (20.0 dBm) * 5825 MHz [165] (20.0 dBm) what I normally do is to do a scan and pick an unused / least used channel : iw wlan0 scan pick an appropriate channel and specify it in hostapd.conf. 5ghz channels (hw_mode=a) delivers a max throughput of like 140 Mbps which is fast. https://docs.armbian.com/WifiPerformance/#uwe-5622 accordingly there are some country specific requirements for 5ghz channel selections and one may like review https://en.wikipedia.org/wiki/List_of_WLAN_channels iw reg set etc I did a google search and some of these resources may be useful https://wiki.archlinux.org/title/NetworkManager https://www.baeldung.com/linux/nmcli-wap-sharing-internet in a same way you may need to set the channel if necessary then that this repo is found in a google search which may be useful https://github.com/pi-top/Wi-Fi-Access-Point-and-Station-Mode/tree/master
  20. I downloaded and wrote the image to the SD card. I can see the U-Boot messages at the very beginning, but after a few moments, nothing is displayed anymore. I believe the OS is still booting because the activity LED on the board keeps blinking. Any idea what might be happening ? Thanks in advance for any help !
  21. Yesterday
  22. I'm trying to compile an LED display driver: https://github.com/arthur-liberman/linux_openvfd I follow this description: https://github.com/bk3a12/openvfd_enable_for_tx3_mini However, I can't build anything and the whole process ends with errors: sh ./scripts/modules-check.sh /home/user/INSTALKI/linux_openvfd/driver/modules.order make -f ./scripts/Makefile.modpost make[3]: *** No rules to make an object '/home/user/INSTALKI/linux_openvfd/driver/modules.order', required by '/home/user/INSTALKI/linux_openvfd/driver/Module.symvers'. Stop. make[2]: *** [/usr/src/linux-headers-6.12.33-current-meson64/Makefile:1897: modpost] Error 2 make[1]: *** [Makefile:224: __sub-make] Error 2 make[1]: Leaving the directory '/usr/src/linux-headers-6.12.33-current-meson64' make: *** [Makefile:5: modules] Error 2
  23. @werner Sorry the delay, I was trying to get the TTL adapter. Here is what I get from the TTL in the first boot after flashing Armbian_community_25.8.0-trunk.228_Orangepi5pro_bookworm_vendor_6.1.115_minimal.img DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18 ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 ch0 ttot7 LPDDR5, 2400MHz channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch1 ttot7 channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch2 ttot7 channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch3 ttot7 channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB Manufacturer ID:0xff DQS rds:l0,l0 CH0 RX Vref:27.1%, TX Vref:20.0%,20.0% DQ rds:h3 h4 h2 h1 h5 h2 h2 h1, h1 h3 h3 h5 h1 h3 h2 h2 DQS rds:l0,h1 CH1 RX Vref:27.9%, TX Vref:21.0%,20.0% DQ rds:l0 h1 h2 h3 h6 h2 h3 h6, h4 h2 h2 h2 h2 h1 h4 l0 DQS rds:l0,l0 CH2 RX Vref:26.7%, TX Vref:19.0%,21.0% DQ rds:h3 l0 l0 l0 h4 h1 h7 h3, h2 l0 h1 l0 h2 h4 h1 h1 DQS rds:l0,h1 CH3 RX Vref:27.9%, TX Vref:20.0%,20.0% DQ rds:h5 h3 h7 h4 h2 h2 h4 h4, h4 h3 h4 h2 h3 h1 h3 h1 stride=0x2, ddr_config=0x6 hash ch_mask0-1 0x20 0x40, bank_mask0-3 0x0 0x2400 0x44800 0x89000, rank_mask0 0 x2000 change to F1: 534MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F2: 1320MHz ch0 ttot8 ch1 ttot8 ch2 ttot8 ch3 ttot8 change to F3: 1968MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F0: 2400MHz ch0 ttot7 ch1 ttot7 ch2 ttot7 ch3 ttot7 out U-Boot SPL board init U-Boot SPL 2017.09 (Jun 13 2025 - 02:18:34) unknown raw ID ff ff ff unrecognized JEDEC id bytes: ff, ff, ff Trying to boot from MMC1 Card did not respond to voltage select! spl: mmc init failed with error: -95 Trying to boot from MMC2 Card did not respond to voltage select! spl: mmc init failed with error: -95 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### # Reset the board to bootrom # Not sure if it matters, but I have a EMMC installed and flashed the image to it using the rkdevelop tool. ( The same way I do to flash the firmware from orangepi site ) Just in case, here are the commands I use ./rkdeveloptool db MiniLoaderAll.bin ./rkdeveloptool wl 0 Armbian_community_25.8.0-trunk.228_Orangepi5pro_bookworm_vendor_6.1.115_minimal.img ./rkdeveloptool rd
  24. Thank you!
  25. Hi, I also tried to run this sensor, tried different ports but to no avail. maybe you found a way to solve this problem?
