  2. Orange PI has very good hardware (better than RPI) but bad support of software from factory devellopers. Raspberry PI 5 is a bit slower but we have more support and always new versions. I have both.
  4. Hi All, I'm struggling with my Orange PI 5 Plus and various Armbian Flavors for 3 days. My Preferred DE, Armbian_25.8.1_Orangepi5-plus_noble_vendor_6.1.115_kde-neon_desktop, after all setup on second boot... failed msg: wait until boot finishes... XFCE, Sound does not work over HDMI. Finally, Armbian_25.8.1_Orangepi5-plus_trixie_vendor_6.1.115_cinnamon_desktop, is doing well. Except for, I'm missing start button. If I want Firefox, I have to open it via cmd If I want to capture screen... I dont know even the name to call via cmd... See my Phone shot https://drive.google.com/file/d/1d6K4i_yshHCrKvXR-13VFkpWzPKx8GaA/view?usp=sharing Could somebody tell me what is wrong? Thanks,
  5. The ffmpeg discussion posted a way to test the code (at the bottom of https://code.ffmpeg.org/FFmpeg/FFmpeg/pulls/20847 ) *install all the ffmpeg dependencies, then: $ git fetch -u https://code.ffmpeg.org/Kwiboo/FFmpeg v4l2request-v3:Kwiboo-v4l2request-v3 $ git switch Kwiboo-v4l2request-v3 * compile and install Then rebuild mpv+PR14690 (https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/page/5/#findComment-226567)
  6. So I managed to get my hands on a v1.1 board version of this TV Box So far https://github.com/sicXnull/armbian-build/releases/download/v24.8.0-trunk.425/Armbian-unofficial_24.11.0-trunk_X96q_bookworm_current_6.6.44_mate_desktop.img.xz doesnt seem to work and I havent found any mention of a v1.1 image Any ideas?
  7. @Maurizio Finesso Try editing on a linux machine instead of windows. I've seen some windows machines not be able to read the boot partition
  8. Moved to the correct sub-forum
  9. Yesterday
  10. Please open the case and post images of your board so we can see what Ethernet chip you have.
  11. In this case ethernet chip is realtek so it should be supported by armbian kernel? So problem is to find or make a modern DTS for this board?
  12. Hi I'm trying to load the bookworm version on an amlogic S905X tv box that was working pretty fine with the bullseye version. What I'm not able to do is to have the boot partition where I can edit on SD Card. This happens with every of the compressed image file that are available for Amlogic tvbox. Probably I'm doing something wrong but after that I load the compressed file on SD card using Balena Etcher I don't find the boot partition readable in Windows. I'm using same procedure with older image (armbian 20.10 bullseye) that works fine. Please, help me to understand how to create it correctly. I have already look into docs but I don't find a solution.
  13. Preexisting builds of Armbian won't run on my X96Q TV box because mine uses DDR3 instead of LPDDR3. U-Boot SPL 2024.01_armbian-2024.01-S866c-P4a40-H8869-Vad24-Bbf55-R448a (Nov 15 2025 - 02:36:36 +0000) This DRAM setup is currently not supported. How do I change the DRAM (and possibly other) configuration U-Boot is built with? I'll be quite frank: Quite annoyed by this whole process. The build process for both Armbian and U-Boot has exhausted my patience and I'm very much not in the mood for digging through (often hard to find) documentation. (Like why is there no standard for adding a board?) Here's the UART boot log of the device:x96q_boot_log.cap Oh and I almost forgot! The stock firmware! https://archive.org/details/x96q_h313_mmcblk0.img.7z Something about extracting "device trees" or something? Honestly I couldn't locate the copy of u-boot in there, but I'm probably doing something wrong there. I'm sure someone WAY smarter then me in this stuff could probably figure it out.
  14. You need the "normal" non 5-1 version: https://github.com/sicXnull/armbian-build/releases/download/v24.8.0-trunk.425/Armbian-unofficial_24.11.0-trunk_X96q_bookworm_current_6.6.44_mate_desktop.img.xz
  15. Good evening everyone. First of all, thank you for this forum and for any help you can provide. I have an X96Q 2G/16G case with an Allwinner H313 chipset and I'm trying to install Armbian. I first tested with the MiniArch-20231112-6.6.2-board-h313.x96_q-SD-Image.img image: it boots correctly. However, when I try with the https://github.com/sicXnull/armbian-build/releases/download/v24.8.0-trunk.425/Armbian-unofficial_24.11.0-trunk_X96q-v5-1_bookworm_current_6.6.44_mate_desktop.img.xz the box doesn't boot and the LED remains red. I'm not an expert in this area; I simply want to install Armbian on this box. If anyone can help me, that would be great. Thank you in advance for your feedback.
  16. This site deals with Armbian Linux not android. You should direct your question about restoring Android to a more appropriate forum
  17. Hi : My problem is this. After manually updating my TV BOX , the serial number X88PROB-H313-D4-V1.0 is printed on the motherboard. The WiFi number AW859A has stopped working. I've tried everything, including reinstalling the firmware using PhoenixCard or PhoenixSuite. I downloaded and updated the T95-H616-A27.img and T95-H616-A29.img files, as well as the X88-PRO-S-H616 file. The installation was successful, but the device only displays the HDMI boot screen. Is there a solution? I would like to restore my device to Android 10 or 12 firmware, if possible. Is there a way to restart it if it's corrupted?
  18. not recommended for rockchip socs since it cannot handle the rather high baud rate of 1.5Mbaud. Use FT232, CH340 or CP2104 instead.
  19. I used a regular ch340, most likely a fake. Keep in mind that the baud rate is 1500000 in both u-boot and Linux.
  20. Use the one that works / safe to ignore. I think one device is normal and the other for WiFi direct.
  21. Collabora’s long-term leadership in KernelCI has delivered a completely revamped architecture, new tooling, stronger infrastructure, and deeper integrations—modernizing the entire ecosystem and enabling reliable, scalable upstream kernel testing. View the full article
  22. As highlighted by an issue on BTT's GitHub, why are two wireless interfaces present (wlan0 and wlan1)? What should we use ? armbian-config presents them both.
  23. Hello all, Ok, I'm going to comment on my own question here... I just now installed the Armbian 25.8.0 6.18.0 RC5 xfce version. It's not yet on the nvme drive but, it's significant faster than the 25.5.1 version. Now HD video works on the 5b+. It needs 2 seconds to stabilize but than it is perfectly fine to watch. I use Firefox as my browser. So thanks to the team! Ernst-Jan
  24. Hi, can you please share which USB to TTL adapter to use for uart logs? I have an RK3399 board but it failed to show uart logs with CP2102 and CH340 adapters. Thank you!
  25. Hi all, I would like to ask support for the board EMB-3531. I'm having problem with booting this board from SD card. Here are some informations about this board. I hope that someone can help me with it. Thank you so much! I try to erase the emmc and flash the MiniLoaderAll.bin but it doesn't help. Or i don't have a correct image with armbian for this board. https://my.kos.org.cn:5154/rockchip/EMB3531/emb3531.pdf
  26. Hy all, For some time now I have a Rock 5b + with 16Gig memory. The problem I have is playback video' s in youtube. Video's are not even watcheble in the lowest resolution. Other 4k video' s play fine. I tried several bechmark video' s from online sources. I looked around to see if others experiance the same problem but cannot find anny clu in this matter. I use Armbian ver. 25.5.1 Do others have the same issue? Is there a soltion for this problem? Also I find this board not the fastest. It's a bit faster than mi RPI5 with 4Gig mem. The PI5 plays HD on youtube. I also have a OrangePi 5 ultra with 16 gig memory on stock Orangepi ubuntu witch is a dream to work with. This board is fast, has a small formfactor and became my daily PC for everything. This board also play's youtube video' s in HD. A direct comparacing with the Rock 5b+ is not possible because no Armbian version will boot on this OrangePi board sadly. I tested on wired and WiFi network with no vissible difference. Anny advise is welcome! Ernst-Jan
  27. Try from here: https://fi.mirror.armbian.de/incoming/igorpecovnik/ (this is going to be next release - first test build).
  28. Your best bet is to compile your own image. It's super easy: "git clone https://github.com/armbian/build.git;cd build;./compile.sh" https://docs.armbian.com/Developer-Guide_Building-with-Docker/ https://docs.armbian.com/Developer-Guide_Build-Preparation/ https://www.youtube.com/watch?v=kQcEFsXEJEE
