  2. Just updated many armbian files shown as available for update. After the update sudo apt update shows the error message: E: The repository 'http://apt.armbian.com bookworm Release' is no longer signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. How can I fix this or was signing simply forgotten? Thank you!
  4. That's advanced as hell for build, but you can use any Rockchip SDK to make it, Some factoryes share the SDK online Some don't you will just compile a copy of the same file that you can find in the android image
  5. https://www.phoronix.com/news/Steam-Snap-ARM64-FEX
  6. @Werner Thank you for handling this. As a quick fix for developers making new images: use ./compile.sh SKIP_ARMBIAN_REPO=yes
  7. mirrors/repo are degraded at the moment. We're aware and working on it.
  8. Same error here on a bananapi m5 for debian bookworm The repository 'http://apt.armbian.com bookworm Release' is no longer signed with this definition : deb [signed-by=/usr/share/keyrings/armbian.gpg] http://apt.armbian.com bookworm main bookworm-utils bookworm-desktop
  9. And others: https://docs.armbian.com/Mirrors/#current-mirrors
  10. I'm experiencing the same issue on my Orange Pi 5 running Armbian 25.11.2 noble (Ubuntu 24.04). Error: E: The repository 'http://apt.armbian.com noble Release' is not signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default. What I've tried: Downloaded and installed the armbian.key multiple times: wget https://apt.armbian.com/armbian.key gpg --dearmor < armbian.key sudo tee /usr/share/keyrings/armbian.gpg > /dev/null sudo chmod go+r /usr/share/keyrings/armbian.gpg Copied the key to both locations: sudo cp /usr/share/keyrings/armbian.gpg /etc/apt/trusted.gpg.d/armbian.gpg Configured the repository using both .list and .sources formats The problem: The repository keeps redirecting to different mirrors (armbian.atomonetworks.com, armbian.lv.auroradev.org, etc.) and none of them have valid InRelease or Release.gpg files: $ curl -I https://armbian.atomonetworks.com/apt/dists/noble/InRelease HTTP/2 404 Workaround: The github.armbian.com/configng repository works fine, but the main apt.armbian.com repository appears to have infrastructure issues with signature files missing on all mirrors. Is this a known issue? System info: Distribution: Armbian 25.11.2 noble Ubuntu version: 24.04 LTS Architecture: arm64 Device: Orange Pi 5
  11. It works with this old drivers in windows. CP2102 doesn't reach high baud rates in linux. Baud rate: 1500000 Data bit: 8 Stop bit: 1 Parity check: none Flow control: none ☑️ CP2104 TTL Tested the original one! ☑️ CP2102 TTL Tested the chinese fake one! with this Driver
  12. I can confirm that booting Odroid M1 from SD card does not work with U-Boot versions newer than 2024.04. Many thanks to IAV for providing a workaround. Perhaps most people are booting from NVMe now, so this issue has flown under the radar? # Install U-Boot 24.5.1 (maps to upstream v2024.04) apt-get install -y linux-u-boot-odroidm1-edge=24.5.1 # Freeze the package at that version "printf 'linux-u-boot-odroidm1-edge hold\n' | sudo dpkg --set-selections" # Flash SPI directly from the package artifacts (or via armbian-install) flashcp -v /usr/lib/linux-u-boot-edge-odroidm1/idbloader.img /dev/mtd0 flashcp -v /usr/lib/linux-u-boot-edge-odroidm1/u-boot.itb /dev/mtd2 # Confirm strings /dev/mtd0 | grep -m1 "U-Boot" # U-Boot SPL 2024.04 (Jan 10 2026 - 10:54:44 +0100) strings /dev/mtd2 | grep -m1 "U-Boot" # FIT image for U-Boot with bl31 (TF-A) Now I can boot from sdcard again w/o RCY button. To use only ZFS on my system I compiled zfs into U-Boot. That worked but the problem was still with U-Boot's handling of the mmc1 somehow. Even though zfsls/zfsload were present in the SPI-flashed U-Boot, that build immediately reinitialized mmc1 in HS200 (1.8 V) mode and hit the “Card did not respond to voltage select! : -110” failure before the boot script could run. So the inability to boot the ZFS v28 pool was due to the SPI U-Boot’s bad MMC tuning, not the ZFS commands themselves. For future reference I’ll leave here on how to built U-Boot with ZFS support from the upstream sources: # Workspace & Dependencies apt install git gcc-aarch64-linux-gnu bison flex device-tree-compiler libssl-dev make python3 ninja-build build-essential mkdir -p ~/work/u-boot && cd ~/work/u-boot # Upstream U-Boot git clone --depth=1 --branch v2024.04 https://source.denx.de/u-boot/u-boot.git # Firmare blobs git clone --depth=1 https://github.com/rockchip-linux/rkbin.git # Prepare .config cd u-boot cp configs/odroid-m1-rk3568_defconfig .config scripts/config --file .config --enable CONFIG_CMD_ZFS yes "" | olddefconfig # Compile make -j$(nproc) \ BL31=../rkbin/bin/rk35/rk3568_bl31_v1.45.elf \ ROCKCHIP_TPL=../rkbin/bin/rk35/rk3568_ddr_1560MHz_v1.23.bin # Flash SPI directly from the package artifacts (or via armbian-install) cp spl/u-boot-spl.bin /usr/lib/linux-u-boot-edge-odroidm1/idbloader.img cp u-boot.itb /usr/lib/linux-u-boot-edge-odroidm1/u-boot.itb flashcp -v /usr/lib/linux-u-boot-edge-odroidm1/idbloader.img /dev/mtd0 flashcp -v /usr/lib/linux-u-boot-edge-odroidm1/u-boot.itb /dev/mtd2
  13. Realy cool, but is gpio supposed? I can't get it to work do I need to download some drivers?
  14. If that worked for you, then you're lucky. For me it did not (other board tested). I guess the files on there have an older state which is still good. Again, as mentioned, repo is being worked on and we're aware of the issues and trying our best to resolve this asap.
  15. I'm experiencing the same issue when trying to build image for Raspberry Pi 4B with: BOARD=rpi4b BRANCH=current RELEASE=noble Workaround (worked for me): Forcing the use of Werner's mirror: LOCAL_MIRROR="fi.mirror.armbian.de/apt" Posting this in case it helps others facing the same problem.
  16. System Information Distribution: Debian (armbian) Kernel Version: 6.1.115-vendor-rk35xx OpenZFS Version: 2.3.5 The kernel module does load. # zfs -V zfs-2.3.5-2~bpo13+1 zfs-kmod-2.3.5-2~bpo13+1 # zfs version Failed to initialize the libzfs library. Note: To keep this post short, I only pasted the errors from the trace below. # strace zfs version prctl(PR_CAPBSET_READ, 0x30 /* CAP_??? */) = -1 EINVAL (Invalid argument) prctl(PR_CAPBSET_READ, CAP_CHECKPOINT_RESTORE) = 1 prctl(PR_CAPBSET_READ, 0x2c /* CAP_??? */) = -1 EINVAL (Invalid argument) prctl(PR_CAPBSET_READ, 0x2a /* CAP_??? */) = -1 EINVAL (Invalid argument) prctl(PR_CAPBSET_READ, 0x29 /* CAP_??? */) = -1 EINVAL (Invalid argument) openat(AT_FDCWD, "/dev/zfs", O_RDWR|O_EXCL|O_CLOEXEC) = -1 ENODEV (No such device) openat(AT_FDCWD, "/usr/share/locale/en_US.UTF-8/LC_MESSAGES/zfs-linux-user.mo", O_RDONLY) = -1 ENOENT (No such file or directory) openat(AT_FDCWD, "/usr/share/locale/en_US.utf8/LC_MESSAGES/zfs-linux-user.mo", O_RDONLY) = -1 ENOENT (No such file or directory) openat(AT_FDCWD, "/usr/share/locale/en_US/LC_MESSAGES/zfs-linux-user.mo", O_RDONLY) = -1 ENOENT (No such file or directory) openat(AT_FDCWD, "/usr/share/locale/en.UTF-8/LC_MESSAGES/zfs-linux-user.mo", O_RDONLY) = -1 ENOENT (No such file or directory) openat(AT_FDCWD, "/usr/share/locale/en.utf8/LC_MESSAGES/zfs-linux-user.mo", O_RDONLY) = -1 ENOENT (No such file or directory) openat(AT_FDCWD, "/usr/share/locale/en/LC_MESSAGES/zfs-linux-user.mo", O_RDONLY) = -1 ENOENT (No such file or directory) write(2, "Failed to initialize the libzfs "..., 41Failed to initialize the libzfs library. ) = 41 exit_group(1) = ? +++ exited with 1 +++ The /dev/zfs file does exist # ll /dev/zfs crw-rw-rw- 1 root root 10, 249 Jan 9 16:48 /dev/zfs In addition the trace also contains the following, confirming the existence of the file faccessat(AT_FDCWD, "/dev/zfs", F_OK) = 0 zpool also has the same issue.
  17. Why is there no image for RK3288?
  18. After a ton of time porting the dts for modern kernels, i have a working release for the Bobcat 300 29X Variant To compile https://github.com/sicXnull/armbian-build/tree/Bobcat-29x . ./compile.sh build BOARD=bobcat-29x BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes EXPERT=yes KERNEL_BTF=no KERNEL_CONFIGURE=NO KERNEL_GIT=shallow RELEASE=bookworm Link to Prebuilt Armbian-unofficial_26.02.0-trunk_Bobcat-29x_bookworm_current_6.18.4.img.xz First check to see if you have a compatible version. Flip the unit over and check the serial number. It will start with G290 or 295. This does not work on 28 or 285. How to Flash 1) Install Rockchip Flash Tools 2) Download bootloader (rk356x_spl_loader_ddr1056_v1.10.111.bin) attached here. 3) Boot device into LOADER mode. Plug USB Cable in to back of the unit, powered off. Open the device. With it powered on hold the reset button for 1 second, then immediately let off and hold the recovery button down until the PC recognizes you in LOADER mode 4) Follow the flash procedure found here. WARNING While I2C/Spidev is functional, i did not install Helium or the Lora packet forwarder for testing. Flash this image at your own risk if you still wish to use helium mining. rk356x_spl_loader_ddr1056_v1.10.111.bin
  19. Yesterday
  20. For Australian users, there is an unofficial mirror at https://mirror.aarnet.edu.au/armbian/apt
  21. Yep Already tried that:- "chatgpt+gemini have given lots of ideas like patches, hooks, extensions but none of them work. (grrrrrr!)." Didn't work probably because the source is not an ASCII text file but a large CPIO binary. But....I am just running a make right now which looks like it might work..... don't want to jinx it....
  22. I have no complaints about the developers, it’s enough for me to just know that this is not a client-side problem and that someone is working on a solution.
  23. I suggest to try kernel-patch build command. Your changes then are compiled into a patch which is then applied to the kernel source before building.
  24. yes i have CONFIG_INITRAMFS_SOURCE working on my server no drama. i was hoping to be able to roll my own initrd on armbian as well. LONG ANSWER: the problem is that the armbian build system does housecleaning before the kernel make starts. part of this is to delete any folder thats not part of the source tree. so the questions are: 1) where do i put it so its visible to the make? 2) how do i stop the build from deleting it? chatgpt+gemini have given lots of ideas like patches, hooks, extensions but none of them work. (grrrrrr!).
