  2. After upgrading armbian to 26.2.1 with kernel 6.18.10 performances on WAN interface dropped to 20Mbps for a single TCP connection. The interface is end0, renamed from eth1, driver from ethtool -i is "st_gmac". I used armbian-config to rollback to kernel 6.12.58 and performances are ok now. Will it be fixed in the future kernels ?
  3. Today I realized a higher version of zfs-dkms(2.4.1) was actually offered in the Armbian repository. So I entered the command below to upgrade zfs-dkms to 2.4.1 and it was successful:
  4. Maybe because it's a "zombie" system with systemd removed and the monitor tools fails to address Here's the dmesg of current system https://paste.armbian.com/zuyaxiwugo.yaml
  5. Hm does not contain 7.1.0 dmesg boot log
  6. Seems like the same "issue" like here. tl;dr: upstream uses "otg" to allow user to change the usb port behaviour as they like. https://forum.armbian.com/topic/59094-usb-2-port-not-available/#comment-237191
  7. The upstream default seems to be "otg" to allow users in userspace to change the usb port behavior. Try this and use armbian-add-overlay /dts-v1/; /plugin/; / { fragment@0 { target = <&usb_host0_xhci>; __overlay__ { dr_mode = "host"; }; }; };
  8. Thanks for your update. I checked rk3588-orangepi-5-plus.dtb after decompiling, it says: It seems line dr_mode = "otg" does On The Go, they seem to switched it from the 6.1.115-vendor-rk35xx dtb. What could be the use case? As I understand you can set it to dr_mode = "peripheral" ?
  9. In mainline kernel 6.18 or above, the USB 2.0 port (and USB-C port) is configured as device mode. You can use following cmd to change to host mode to connect other USB devices, but you need to do it again after reboot. sudo bash -c "echo host > /sys/kernel/debug/usb/fc000000.usb/mode" It could be done by dtb overlay but there is no one available now.
  10. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  11. No problem, just to let you guys know Everything else is working Cheers !
  12. must be specific to this board. rock-3a which also uses RK3568 is not affected. btw. bleedingedge is intended to be used by developers only since breakage just like you noticed, is very much expected.
  13. Connecting a usb keyboard doesn't seem to work with 7.1 .. [ 2.836541] usb 7-1: new full-speed USB device number 2 using ohci-platform [ 3.024538] usb 7-1: device descriptor read/64, error -62 [ 3.304535] usb 7-1: device descriptor read/64, error -62 [ 3.596542] usb 7-1: new full-speed USB device number 3 using ohci-platform [ 3.780527] usb 7-1: device descriptor read/64, error -62 [ 4.076543] usb 7-1: device descriptor read/64, error -62 [ 4.180566] usb usb7-port1: attempt power cycle [ 4.372529] usb 7-1: new full-speed USB device number 4 using ohci-platform [ 4.780541] usb 7-1: device not accepting address 4, error -62 [ 4.964529] usb 7-1: new full-speed USB device number 5 using ohci-platform [ 5.372526] usb 7-1: device not accepting address 5, error -62 [ 5.372569] usb usb7-port1: unable to enumerate USB device
  14. Search root for this motherboard. The device is tvbox Fobem Duo
  15. Bleedingedge Kernel 7.1 rc2 fixed it [ 12.686942] panfrost fde60000.gpu: clock rate = 594000000 [ 12.686994] panfrost fde60000.gpu: bus_clock rate = 500000000 [ 12.710029] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0 [ 12.710053] panfrost fde60000.gpu: features: 00000000,00000df7, issues: 00000000,00000400 [ 12.710062] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7 [ 12.710070] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
  16. Hello! I noticed that x96q lpddr v1.3 is now an official (or something close to that) release, as it appears on the main page when searching. I used to use @sicxnull fork but now I have the impression that his changes were incorporated and he is the official maintainer of this device. I installed the Armbian 26.02 in an SD card and tested it in my X96Q lpddr v1.3 device and it works great! The problem is when I installed it to the internal eMMC, it will not boot anymore. I have the serial cable attached and I can see that very very early in the boot process u-boot cannot read from flash and the boot hangs. I know this has been discussed to some extent in another thread but I wanted to start fresh on this one since now we're talking about the Armbian official release and not the fork anymore. My intent with this thread is focus exclusively on fixing eMMC on the official release. My tests: Test 1 Download latest release, from here, more specifically this one. Direct link to the image here (name: Armbian_community_26.2.0-trunk.858_X96q_resolute_current_6.18.27_xfce_desktop.img.xz). Write to SD card using balena etcher, boot in my x96q device. It works well, boots through the initialization process, create user account, etc. The, run armbian-install and install it to internal eMMC. Remove SD card. Reboot. It will not boot, with the following error: Trying to boot from MMC2 MMC Device 1 not found spl: could not find mmc device 1. error: -19 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### Booting from SD card again, re-running the installer and forcing to update the eMMC bootloader does not help. Test 2 I swapped only u-boot for the one from miniarch/minimyth2 project, compiled for the same hardware. Miniarch project can be found here. An image that works on this hardware (in my specific device) can be found here, more specifically this one. This image works well, and it also works well when installed to eMMC. The reason I don't use it is that I prefer Ubuntu over Arch, which I can get with Armbian instead. Download that image, and extract the file u-boot-sunxi-with-spl.bin from the first partition of that image. I used unxz + losetup + loopback mount the image's first partition in linux, but it may be easier for you to just write that image to an SD card, then copy the file from it. It is in the first partition in the path /bootloader/u-boot-sunxi-with-spl.bin. Copy it to a usb stick and plug it into the x96q device or scp it directly. Now, boot the x96q with the SD card, go through all initial setup. Run armbian-install, and install it to eMMC. Finish the installer (quit). Copy the file you extracted from miniarch to the booted system in x96q (using the usb stick or scp'ing it directly). Overwrite the file with the same name at /usr/lib/linux-u-boot-current-x96q/u-boot-sunxi-with-spl.bin with the new one. Run the armbian-install command again, this time chose to update the bootloader in the eMMC. Mount the eMMC temporarily at /mnt and edit the /mnt/boot/armbianEnv.txt file, add this line: fdtfile=allwinner/sun50i-h313-x96q-lpddr3.dtb This is because the hardcoded path for the DTD file in miniarch is different from the one from armbian, so you need to override it. It can also be done in realtime on the u-boot boot prompt if you have serial cable attached. Reboot, remove the SD card and let it boot from the eMMC. It should work, now you have a working Armbian on the eMMC. This will get undone if the bootloader is updated again with the original one (and is not meant as a permanent fix). Thoughts Miniarch uses 2025.04 u-boot while Armbian x96q board is using 2024.01 but I'm not sure this is really relevant. My guess is that the difference is in some of the patches they apply and not in the improvements of this new version of u-boot itself. But I could be wrong. You can find the list of patches that miniarch applies over to stock u-boot here. Many of those patches do not exist in Armbian. I wonder if it is any of those that is making the difference. Question to @sicxnull: do you have a good idea of what is going on and have any direction for further testing? I wanted to ask before I start applying the extra patches one by one, that would take quite some time. Thanks!
  17. Is it possible on a Banana Pi M4 Zero to reboot Armbian running from SD card, so that the next time it boots from the internal storage, without removing the SD card? (and without modifying sdcard boot sector) I want to create an automatic backup internal storage - so that the system (booted from emmc) reboots, starts from the SD card, backs up content emmc to sdcard, and then reboots again, booting from emmc. Is it possible some how?
  18. @epost.deb Hmmm, I am a bit skeptical about that; mainly because the SoC (on my board <-- this is important!) does not peek for sdcard at all during boot, thus u-boot is not involved; moreover if I read the SARADC2 from userland, I get it in the range of the eMMC-only boot configuration. I emphasize this is on my board, because the manufacturer can chose the boot configuration placing a pair of resistors on the board. The manufacturer of my board choose the eMMC-only boot configuration. If I find the two resistors, and remove the "pull-down" one, my board would try booting from all the options.
  19. somehow I'm in troble to run the armbian build into 24.04 localhost. cd build ./compile.sh BOARD=h96-tvbox-3566 BRANCH=edge BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=resolute [๐Ÿ’ฅ] Problem detected [ Docker installed but not usable ] [๐Ÿ’ฅ] Exiting in 10 seconds [ Press <Ctrl-C> to abort, <Enter> to ignore and continue ] [๐Ÿ”จ] E: Unable to correct problems, you have held broken packages. [๐Ÿ’ฅ] error! [ Failed to install host packages; make sure you have a sane sources.list. ] [๐Ÿ’ฅ] Exiting with error 43 [ at /home/nicolas/Downloads/build/lib/functions/logging/traps.sh:1 so let's try docker, cd build ./compile.sh docker BOARD=h96-tvbox-3566 BRANCH=edge BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=resolute then also docker: Failed to update binfmts [ update-binfmts --enable qemu-aarch64 ] ... arm64: not supported on this machine/kernel how to fix: sudo apt update sudo apt install -y qemu-user-static binfmt-support sudo systemctl restart systemd-binfmt update-binfmts --display qemu-aarch64 docker run --privileged --rm tonistiigi/binfmt --install all docker run --rm --platform linux/arm64 arm64v8/ubuntu uname -m now, run the build inside the docker shell: cd build newgrp docker ./compile.sh docker-shell ./compile.sh BOARD=h96-tvbox-3566 BRANCH=edge BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=resolute Now let's prepare this board for kernel 7
  20. I have attached both the dtbs for linux 6.6 and 6.12 to this message in the forum.
  21. Okay, here's the error I'm getting from the serial console: DDR Version 1.25 20210517 In channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 928MHZ channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 928 MHz, current 856MHz OUT U-Boot SPL 2022.07-armbian (Jun 30 2024 - 19:41:33 +0000) Trying to boot from SPI Trying to boot from MMC1 Card did not respond to voltage select! : -110 spl: mmc init failed with error: -95 Trying to boot from MMC2 NOTICE: BL31: lts-v2.8.8(release):armbian NOTICE: BL31: Built : 19:41:23, Jun 30 2024 INFO: GICv3 with legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: Maximum SPI INTID supported: 287 INFO: plat_rockchip_pmu_init(1624): pd status 3e INFO: BL31: Initializing runtime services INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2022.07-armbian (Jun 30 2024 - 19:41:33 +0000) SoC: Rockchip rk3399 Reset cause: POR DRAM: 3.9 GiB PMIC: RK808 Core: 339 devices, 31 uclasses, devicetree: separate SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB MMC: mmc@fe320000: 1, mmc@fe330000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Model: Helios64 Revision: 1.2 - 4GB non ECC Net: dw_dm_mdio_init: mdio node is missing, registering legacy mdio busNo ethernet found. scanning bus for devices... Hit any key to stop autoboot: 0 Card did not respond to voltage select! : -110 switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3906 bytes read in 17 ms (223.6 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 0:1 179 bytes read in 13 ms (12.7 KiB/s) 20409746 bytes read in 1952 ms (10 MiB/s) 39770624 bytes read in 3781 ms (10 MiB/s) 90994 bytes read in 79 ms (1.1 MiB/s) 2825 bytes read in 173 ms (15.6 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Moving Image from 0x2080000 to 0x2200000, end=48b0000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 20409682 Bytes = 19.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f4b66000, end f5edcd52 ... OK Loading Device Tree to 00000000f4ae7000, end 00000000f4b65fff ... OK Starting kernel ... ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003) ERROR: rockchip_plat_sip_handler: unhandled SMC (0x82000003)
  22. Hey guys, So I wanted to update the OS on my NAS to patch the Copy Fail vulnerability today. I installed everything, I also did an apt-upgrade (not a full one) to make sure my kernel was as up to date as I could get it, and I also updated the initramfs, too. Now when I boot up the Kobol, I can hear the disks spinning up after a few seconds upon powering up, they make an odd noise and then just stop. The LEDs on the front panel also no longer show blue anymore, and `fdisk -l` no longer shows anything. I know for a fact these HDDs are not dead. They have worked perfectly fine before the upgrade, and the SATA pins look perfectly clean. I even tried swapping from bays 1 and 2 to 3 and 4 and still no dice. I may go through and attach serial or dmesg output. But yeah, nothing much about "ata" shows up in `dmesg` after booting.
  23. (I am not part of Armbian other than the community, and have donated money, so I feel no obligation to be "professional") Ok, if you want to act like a clown, I'll treat you like a clown: Don't click unknown links, don't download unknown scripts or applications and you are fine. You know, use common sense. I'm sorry you feel "wronged" by this free and open source project because it doesn't focus the tiny amount of assets they have to manually remove something that pretty much is a nothing burger (and will be solved in the next update), unless you make yourself vulnerable by infecting yourself with with an RCE malware/virus or give physical access to people you can't trust. If you think making a text on their website would "protect" people, when this exploit has been mentioned by more or less every single linux outlet in existence, I don't know what to say. You are not doing this to "protect others", you do it for ego reasons. (Sorry mods, I won't respond more with the risk of starting a war, but if being mentioned in the way op did, I WILL defend myself.) Also, a link about Dirty Frag: https://thehackernews.com/2026/05/linux-kernel-dirty-frag-lpe-exploit.html Mitigation:
  24. For those who want to follow the linux-sunxi mailing list but not as plain emails but in patchwork format, feel free to use https://patchwork.armbian.eu/project/patchwork/list/
  25. Multiple options: - wait for upcoming 26.05 release which will most likely have an updated kernel package including a fix for this - as suggested use nightly - use the build framework to build an most up-to-date kernel package set by yourself (its very easy) which then can be installed via dpkg -i However since "dirty frag" just showed up, there is more to fix anyway... Edit: looks like fix for dirty frag hit upstream earlier today
ร—
ร—
