@Harleyyyu Your project could be interesting , I would suggest to open a dedicated 3ad on It own so people can contribute. As you have already realized by yourself quite all hardware and drivers aspects of this rk322x soc have bene investigated by @jockand/or @ilmich But if you achieve any progress on GENERAL drivers and performance that isn't already been discussed or achieved you can came back here to share Thanks
Okay here's a huge update and a win for me: While i stopped playing with the kernel, i focused on improving openauto by replacing GStreamer with ffmpeg and utilizing the same RTAudio to Alsa Patch which achieved the following things: 720p 60 1080p 60 FPS Stream (cma set to 265) RTAudio to Alsa (Video and Audio are synced) Low Latency Touch or Mouse Response Now while there is still some bugs like when i disconnect my phone by pulling the usb cord results into a segment fault i'd say that's just a minor bug that can be fixed along the way. Huge thanks to the experimental ffmpeg patches and the guide @jock PS: hopefully someone can help me improve the code even more, i know this board is capable of being an android auto head unit for those who like to build it on their own: Github: Openauto-rk3229-armbian (requires you to compile aasdk)
@Werner, @Igor: Is the Raspberry Pi 500 supported by Armbian? It’s the successor to the RPi 400, for which support is mentioned. Internally, it looks similar to the RPi 5, except that it seems to lack wifi.
Pablo Navarro replied to SteeMan's topic in FAQ
Hi! This is my first message here, congrats to the community for building this I would also like to corroborate that the current Balena Etcher, in Windows at least, is not writing the image correctly to the SD card. The Armbian imager did it well for me. I just booted an unused A95X (S905X) "Mini Kitty" with Armbian, but I don't think I will spend too much time with it, I already got a lot of mini PCs for servers and it's too slow for a terminal 😅 What do you recommend me to do with this little box? Thanks! -
Very strange behavior: complete freeze after boot
Frans Rampen replied to Frans Rampen's topic in Rockchip
It is a AP-mode problem of the Realtek 8822CE chipset. Replaced the M2 card with Intel AX200 card and since then solid as a rock -
Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + Box64 arm64 v0.4.1 72807b6b9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + dgVoodoo2 (https://github.com/dege-diosg/dgVoodoo2/releases) + DXVK-stripped v1.7.1 50~60fps@1080p (no AA) box64 environment variables: FlatOut 2 Enhanced -
Armbian 25.11.2 Noble XFCE (BSP Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + Box64 arm64 v0.4.1 72807b6b9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + dgVoodoo2 (https://github.com/dege-diosg/dgVoodoo2/releases) + DXVK-stripped v1.6.1 ~60fps@1080p (no AA) box64 environment variables: FlatOut Enhanced -
@Nick A I flashed your latest build in Dec.2025 which is named to use for Transpeed, and in addition, manually added brcmfmac4334 firmware. Wifi is working now but bluetooth. Other malfunction in previous rom version April.2025 also disappear. Thank for your time to advise me
Ordered 2 more X96Qs off aliexpress. will see what versions i get. Will build images for them if they're different.
@SuzSinclair Start by reading the first post of this thread, which has all the information you should need to get started.
There is no way. You need a dedicated image for your hardware. https://docs.armbian.com/User-Guide_FAQ/
@Torte continued to help on his github site. The boot.img of the OEM firmware appears to set up a serial framebuffer screen and some shenanigans with the camera. I'm pausing the thread for now - need to figure out a path to reverse engineer the boot.img. Otherwise, alternative boards will need to be adapted.
Coming late to the party, but I have observed a similar thing with moderm kernels on PCduino 3 nano. To know what is happeneing, have you tried connecting to UART? That gives you more info about what is going on. Now I have trouble with the OTG port. I am unable to configure it for mass storage.
SuzSinclair replied to jock's topic in Rockchip CPU Boxes
can someone please help thanks -
Mine is M1, no plus, so no WiFi. I used the following 2 years ago when I got the SBC: https://fi.mirror.armbian.de/oldarchive/bananapi/archive/Armbian_23.11.1_Bananapi_bookworm_current_6.1.63.img.txt
Okay, that explains why the SATA connection works on the BPI M3 but not on the BPI M1+. So, does anyone know of an image that supports the SATA connection on the BPI M1+ and is newer than Ubuntu 16.04, which is currently running on my BPI M1+?
What is this topic about? M3 - it has Allwinner A83T and no SATA on the SoC but added via USB2 see https://banana-pi.org/en/banana-pi-sbcs/51.html M1(+) - it has Allwinner A20 and SATA on the SoC see https://banana-pi.org/en/banana-pi-sbcs/10.html Mine is the latter.
@kvvvp I don't have any issues building from branch v20250306. Do you have docker installed?
Hello I've now tested the image: Armbian_community_26.2.0-trunk.332_Bananapim3_forky_current_6.12.67_minimal.img on the BPI M3 and I'm happy... SATA works really well. Maybe this will help.
@Nguyễn Lân The HK6334Q Wi-Fi/BT chip uses the brcmfmac4334 firmware. If your Wi-Fi chip is detected by the kernel, the dmesg log will show the names of the .bin and .txt files it is looking for.
Just to note some more: I use none of those images, instead is it in-place upgraded Armbian, originally: root@banlipi:/tmp# grep VERSION /etc/armbian-image-release VERSION=23.11.1 Now Trixie: root@banlipi:/tmp# cat /etc/os-release PRETTY_NAME="Armbian 25.8.1 trixie" NAME="Debian GNU/Linux" VERSION_ID="13" VERSION="13 (trixie)" VERSION_CODENAME=trixie DEBIAN_VERSION_FULL=13.0 ID=debian HOME_URL="https://www.armbian.com/" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" ARMBIAN_PRETTY_NAME="Armbian 25.8.1 trixie" I log some stuff to terminal in my backup script; I see: U-Boot SPL 2024.01-armbian-2024.01-S866c-P7738-Hb9d3-Vf23c-Bb703-R448a (Jun 21 2025 - 02:53:13 +0000) Maybe also good to know, I use extlinux on real HW, grub on KVM root@banlipi:/boot/efi/extlinux# cat extlinux.conf menu title Select the kernel variant DEFAULT default TIMEOUT 80 LABEL default KERNEL zImage INITRD uInitrd FDT sun7i-a20-bananapi.dtb FDTOVERLAYS sun7i-a20-analog-codec.dtbo APPEND root=LABEL=armbianrfs rootwait rw earlyprintk console=ttyS0,115200 But I am not sure how valid the release info is, will need to look at lists files etc and also run update to it is latest Debian 13.3 I think. I just ran apt update && apt full-upgrade and now it is 'latest debian trixie' but I use apt pinning and I see it is too strict and also an error, so os-release not changed It is essentially Debian Trixie armhf up to date with manually written U-Boot and manually copied sunxi kernel.
