  2. OK, I figured it out after some more poking: A recent change to afptool seems to be causing some problem. Using a specific older commit `ff93e32479183a3be0c86ff5441297cb8a7336d1` produced an image that upgrade_tool could successfully install and boot. I'll open an issue with afptool-rs but my ability to describe the problem is a bit weak: "something broke" The local workaround is below. Just FYI, not really something I'd PR and expect merged in vs an upstream fix. ``` $ git diff diff --git a/image-tools/repack-afptool-rs.sh b/image-tools/repack-afptool-rs.sh index 85bac3a..13b559e 100755 --- a/image-tools/repack-afptool-rs.sh +++ b/image-tools/repack-afptool-rs.sh @@ -168,7 +168,8 @@ build_patched_afptool() { mkdir -p "$src_dir" rsync -a --delete "$APFTOOL_RS_SRC/" "$src_dir/" elif [[ ! -d "$src_dir/.git" ]]; then - git clone --depth=1 --branch "$src_ref" "$src_url" "$src_dir" + git clone "$src_url" "$src_dir" + (cd "$src_dir" && git checkout ff93e32479183a3be0c86ff5441297cb8a7336d1) fi if ! grep -q 'RK3528_LEGACY' "$src_dir/src/pack.rs"; then ```
  4. hi @Sancho, both modes were attempted at various times. I get them mixed up, but one is where `uf` works directly, and the other where MiniLoaderAll.bin needs to be done first. To be precise, `upgrade_tool uf <your-image>` works consistently, and `upgrade_tool uf <locally-built-image>` fails immediately after `Download Firmware Start`. I enabled logging with `upgrade_tool lg`, but not very informative: `ERROR:DownloadImage-->CheckParamPartSize failed` Basically the `parameter` partition. But the problem isn't obvious to me after unpacking both partitions and comparing `partition-metadata.txt`. ``` package-file,package-file,0x00000000,0xffffffff,0x00000800,0x00000001,0x0000009d bootloader,Image/MiniLoaderAll.bin,0x00000000,0xffffffff,0x00001000,0x000000de,0x0006e9c0 -parameter,Image/parameter.txt,0x00002000,0x00000000,0x00070000,0x00000001,0x00000180 +parameter,Image/parameter.txt,0x00002000,0x00000000,0x00070000,0x00000001,0x00000174 uboot,Image/uboot.img,0x00004000,0x00004000,0x00070800,0x00001000,0x00800000 boot,Image/boot.img,0x00080000,0x00008800,0x00870800,0x00020000,0x10000000 -rootfs,Image/rootfs.img,0x039b4fbf,0x00089000,0x10870800,0x0012ce00,0x96700000 +rootfs,Image/rootfs.img,0x039b4fbf,0x00089000,0x10870800,0x00124600,0x92300000 ``` Also attempted: flash original image, then overwrite rootfs partition directly with a WriteLBA. This had a low chance of working, and it was also unsuccessful. I'm happy to try a few more things and report back. I'll try a fresh build and check deeper for differences between the images.
  5. @AurealNix - Firstly massive kudos to where you've got this board there will be lots of people here quite happy they can get onto a 6.18 kernel .. Well done sir. You 'll be pleased to hear I pulled my ebay listing as a result of what you and Claude achieved. I also signed up to a Claude subscription to save me being so abusive to Gemini when it doesn't meet the standard - thank you! So I just downloaded the headless image and imaged to an M.2 NVMe ... Connected the Serial cable powered on and nothing on the screen I'm afraid. So I armbian-imaged it onto an SD and everything booted fine, lots of text - I logged in and "fdisk -l" only showed my SD card. so I guess that's a negative with the NVMe ... one thing I haven't done is imaged the orangepi-4a 5.x kernel onto the NVMe to see if it boots as it might be that the boot protocol only looks on the SD - will post if I can image the 5.x onto the M.2 and get it to boot later. I've just tried to find a headset cable to test the audio port but only got a headphone cable so can't test yet - and I've seen in your git repo that you have already confirmed the audio port is good so no pressure for me unless you are still in need of testing ? Great stuff and cheers!
  6. I have an Orange Pi 5 Plus 16GB board, revision "1.3.1". I've been using it for about a year with official Armbian, Vendor kernel 6.1. The only issues I noticed were a non-working Type-C port and FAN connector. I thought it was an OS or DTS (Device Tree) bug... But it turned out to be a hardware problem. It started when I got another Orange Pi 5 Plus 8GB board for repair (needed to resolder the Type-C power connector). Same revision "1.3.1". (left is my 16GB board, right is the 8GB board for repair; the PCB solder mask is slightly different in shade of blue — probably different manufacturers or production batches) I inspected it under a microscope and found that both boards have floating (unconnected) vias — the ones that should control the FAN transistor, and also the EN-pin for the Type-C (USB3.1) power. So these are defective boards from some unknown revision where these vias are simply missing. On top of that, even if you force-enable the Type-C (USB3.1) EN pin — it still won't work. The reason is that the data lines are connected to TYPEC1 pins on the SoC, not TYPEC0 as shown in the OPI 5 PLUS_V1_3_1_Schematic.pdf So you need a DTS fix to enable the port via the correct node. The HUSB311 chip is also useless in this case. I don't know what exactly this revision is or why these errors exist. Fix: enabling power on the Type-C port To get the front Type-C (USB3.1) port working, I soldered the EN pin from the Power Switch — which was going TYPEC5V_PWREN_H Nowhere — to the nearest 3V3 Ethernet power rail. Now the Type-C port gets power after boot. The second step is to create a DTS overlay to make the port actually work: File: rk3588-orangepi-5-plus-TypeC-fix-hardware.dts /dts-v1/; /plugin/; / { model = "Orange Pi 5 Plus"; compatible = "rockchip,rk3588-orangepi-5-plus", "rockchip,rk3588"; fragment@0 { target = <&usbdrd_dwc3_1>; __overlay__ { dr_mode = "host"; maximum-speed = "super-speed"; snps,xhci-trb-ent-quirk; }; }; }; To apply the overlay, copy the file to your board and run: cd <path to file> sudo armbian-add-overlay rk3588-orangepi-5-plus-TypeC-fix-hardware.dts Also worth noting: since HUSB311 is missing on this revision, the CC1/CC2 orientation detection doesn't work properly. In practice this means: plug in a USB-C cable one way — the device shows up as USB2.0 (HighSpeed). Flip the cable 180° and replug — it shows up as USB3.0 (SuperSpeed). This happens because only CC1 or CC2 is connected (not both). If you need a PWM fan The PWM signal via for the FAN transistor is also floating on this revision — it goes FAN_CTL_H Nowhere. You can solder to it (either to the end of the nearby SMD resistor or scrape the VIA pad directly) and connect it to any free pin on the 40-pin header. Then update the DTS to assign that pin for fan control instead of the original one. P.S. Sorry for the low quality photos. Source: 4PDA
  7. That is interesting, I would expect the other way around. I use 'btop' to watch clocks and load. On some systems, it also show GPU load and power consumption. Anyway, there is also the edge kernel (7.1.0-edge-rockchip64😞 linux-image-edge-rockchip64/trixie,now 26.5.1 arm64 [installed]
  8. @Caleb Gilmour are you trying to flash using Rockchip Loader mode or Maskrom mode? Regarding wifi I will need to to do some performance testing when I have some time, I did not test it widely. Thanks for your feedback!
  9. Well, I will wait until it works, no worry's. I wil not go back to the 115 kernel because the sbc is getting 10 degrees warmer than the latest gnome version, 47 degrees in the 6.1.115 and 36 in 6.18.28. Both with Firefox in YouTube with the same content... Te dongle works fine... Ernst
  10. a very exciting development on mainline with VPU_GPU acceleration enabled https://github.com/ut-slayer/orangepi-4a-mainline/issues/2#issuecomment-5030458197
  11. Apologies this seems to have posted twice could admin please delete one of them Hi all, I built an image for my new Odroid M2 16 GB board using the parameters in my config-odroid.conf BOARD=odroidm2 RELEASE=trixie BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no Issued compile.sh odroid It built and booted first time I configured it using armbian-install to boot from the emmc and use a 1tb Samsung nvme as the system disk Rebooted after removing the sdcard Everything seemed to work until I tried to flash another image to the sdcard with dd The flash immediately stalled and killed my windows Putty session Some of the errors from dmesg mmc1: Card stuck being busy! __mmc_poll_for_busy dwmmc_rockchip fe2c0000.mmc: Busy; trying anyway mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80200000) GPT PMBR size mismatch (7675903 != 62333951) The primary GPT table is corrupt, but the backup appears OK. I have no idea what to do My intention was to try different images to ascertain which worked best which I can still do but i have to flash the card on another box I hope this makes sense Kind regards Pete Kane
  12. Hi all, I built an image for my new Odroid M2 16 GB board using the parameters in my config-odroid.conf ``` BOARD=odroidm2 RELEASE=trixie BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no ``` And issued compile.sh odroid It built and booted first time I configured it using armbian-install to boot from the emmc and use the 1tb Samsung nvme as the system disk Rebooted after removing the sdcard Everything seemed to work until I tried to flash an image to the sdcard with dd The flash immediately stalled and killed my Putty session Some of the errors from dmesg ``` mmc1: Card stuck being busy! __mmc_poll_for_busy dwmmc_rockchip fe2c0000.mmc: Busy; trying anyway mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80200000) ```
  13. Feel free to test and send a pr with a patch backporting this to 6.18
  14. Yesterday
  15. Actually spoke to soon, seeing this issue on the 6.18 kernel but happens randomly, its a known upstream issue that has been fixed in 7.1, but you guys should back port this fix here: Upstream fixed this exact Radxa/RTL8852BE problem by retrying the eFuse operation five times. The fix is https://chatgpt.com/g/g-p-69619e56d4d48191866d830f3ebddfc0/c/6a5ee909-da2c-83ea-981e-de8591585c8c, with the Wi‑Fi/BT contention confirmed by the Realtek maintainer in the patch discussion https://patchew.org/linux/20260301042422.195491-1-christianshewitt%40gmail.com/?utm_source=chatgpt.com. The fix: Is absent from 6.18.28 kernel. Is still absent from vanilla 6.18.39. First shipped upstream in Linux 7.1. A matching ROCK 5B+ Armbian trace shows the PCIe device and firmware loading successfully, followed by the eFuse failure and error -16. Matching Armbian report.
  16. i got the same problem my ethernet is gone. how does one downgrade i cant figurer it out at all
  17. More likely: friendlyelec is maintaining a separate patch (source code additions to the official ffmpeg), that allows it to do it. The code should be available in the friendlyelec github, to be shared with the public. "No v4l2request"... that means that they implemented another protocol and/or another kernel module to work with the video decoder.
  18. Thank you for your reply. My H96 Max M9 is running Android 14 with the original stock firmware. I have not installed Armbian or any Linux-based operating system. Therefore, I don't think I can run sudo armbianmonitor -u on the TV box. Is there an equivalent way to collect and share the Android system logs, for example using ADB and adb logcat or dmesg? The problem appears when Android's system file picker/Storage Access Framework is used by applications such as PPSSPP and Dolphin Emulator.
  19. 6.18.10 or 6.18.35? Gnome build? I look for kernels in armbianconfig... Ernst
  20. Hi Armbuilder, I tried them all but only 6.1.115 made the internal WiFi work. Are there different versions of the board maybe? Ernst
  21. @robertoj: $ ffmpeg ffmpeg: symbol lookup error: ffmpeg: undefined symbol: av_buffersrc_get_status, version LIBAVFILTER_10 Looks like Friendlyelec deleted some functions in their version of the library, or based it on an outdated version. ffmpeg is version 7:7.1.5-0+deb13u1 Filename: pool/main/f/ffmpeg/ffmpeg_7.1.5-0+deb13u1_arm64.deb MD5sum: 18e560e3b4c4b992d74d2bf3020d9a53 No v4l2request info with `mpv -v`
  22. @eselarm: Thanks enormously for this information. I'm not a hardware expert, so much of this is over my head, but you clarified a number of things for me right away and raised a new bunch of questions. Will research things further. One correction: the Friendlyelec libav* libraries are under /usr/local and take preference to those under /usr, so they won't be affected by a Debian update.
  23. That's the advantage when you use a device that doesn't have a PMIC and only goes into deep sleep mode for Off Mode. This is only supported by the proprietary, closed-source manufacturer firmware, for which of course no publicly available API description exists. Mainline support will therefore most likely not become available. So it basically just leaves reverse engineering and an out-of-tree implementation. Good luck.
  24. moved to tvboxes
  25. The board should have RT8821CU as wifi chip. Since Linux 6.17 there is no out of tree driver necessary anymore, mainline i used. So perhaps this is a an issue or regression upstream. You can try to switch to edge kernel, perhaps this has been addressed but not back-ported.
  26. Last week
  27. I compiled Linux from hardkernel–it works with the devicetree from petitboot firmware. There's a emmc-data-4b node (not in their source code) which does: &emmc_conf_pull_up { mux { drive-strength = <3>; groups = "emmc_nand_d0", "emmc_nand_d1", "emmc_nand_d2", "emmc_nand_d3"; function = "emmc"; input-enable; bias-pull-up; }; }; Trying this with mainline e.g. overlay=g12b-odroid-n2-spi isn't enough here. No option to wakeup (ir, lan, keyboard) is another reason to stick with 4.9.
  28. Subject: Bluetooth: Unknown BR/EDR signaling command 0x16 / Wrong link type (-22) on meson-gx / Banana Pi M2 Pro Description: When connecting modern Android (POCO F7) and Windows/Linux devices (Lenovo Legion) via Bluetooth to Banana Pi M2 Pro, the dmesg log gets flooded with BR/EDR signaling errors during connection/disconnection phases. Steps taken: - Forced 'ControllerMode = bredr' in /etc/bluetooth/main.conf - Disabled USB autosuspend for the BT controller (set to -1) Logs: [ 345.122975] Bluetooth: Unknown BR/EDR signaling command 0x16 [ 345.123005] Bluetooth: Wrong link type (-22) Environment: - Board: Banana Pi M2 Pro (Amlogic S905X3) - Kernel version: 6.18.34-current-meson64 nano armbianEnv.txt extraargs=usbcore.autosuspend=-1 The problem with Bluetooth on bananapim2pro is that I constantly have trouble connecting. My tweaks to the settings fixed it somewhat, but not 100%... Finally, if all else fails, I use this method: sudo rmmod btusb sudo modprobe btusb sudo systemctl restart bluetooth sudo systemctl restart bluealsa But I have a question: are there any kernel/driver fixes or updates for this Bluetooth model?
  29. Hello guys, i got 2 old fullbox rikomagic mk802 stick android mini pc. Variant Allwinner A10,Ram 512Mb. I tested armbian 26.05 via 4 config : limea1000 boot ok pcduino1 ok cubieboard ok olimex a10 lime stuck at boot os stage, same with official debian 3.4 kernel images of olimex enabled video output for desktop environment. It boot but will take a lot of time to finish
