I tried the image from "armbian.atomonetworks.com" and the exact same thing happens. Thanks, I'll compare the images.
The network card cannot be recognized on armsom
laibsch replied to chauncy's topic in Software, Applications, Userspace
are you sure all storage devices are working without issues? -
The latest Linux kernel brings expanded hardware support for MediaTek and Rockchip, enhanced graphics drivers, and more. Collabora played a key role in this release, with no less than 20 authored contributors! View the full article
ZFS-DKMS doesn't work on vanilla image https://dl.armbian.com/longanpi-3h/Bookworm_current_minimal Image is freshly burnt to the SD card. root@longanpi-3h:~# apt update root@longanpi-3h:~# apt install zfs-dkms root@longanpi-3h:~# modprobe zfs modprobe: ERROR: could not insert 'zfs': Exec format error root@longanpi-3h:~# modinfo zfs | grep -v parm filename: /lib/modules/6.12.23-current-sunxi64/updates/dkms/zfs.ko version: 2.3.1-1~bpo12+1 license: CDDL license: Dual BSD/GPL license: Dual MIT/GPL author: OpenZFS description: ZFS alias: zzstd alias: zcommon alias: zunicode alias: znvpair alias: zlua alias: icp alias: zavl alias: devname:zfs alias: char-major-10-249 srcversion: 2742833EE1C14D857611F06 depends: spl name: zfs vermagic: 6.12.23-current-sunxi64 SMP mod_unload aarch64 root@longanpi-3h:~# file /lib/modules/6.12.23-current-sunxi64/updates/dkms/zfs.ko /lib/modules/6.12.23-current-sunxi64/updates/dkms/zfs.ko: ELF 64-bit LSB relocatable, ARM aarch64, version 1 (SYSV), BuildID[sha1]=f87455b001529d816f09e1498e63a902d1af9be5, not stripped root@longanpi-3h:~# uname -a Linux longanpi-3h 6.12.23-current-sunxi64 #1 SMP Thu Apr 10 12:39:41 UTC 2025 aarch64 GNU/Linux logs After doing apt upgrade, reinstalling dkms module result is the same.
That was installed on my test machine which wasn't upgraded to latest (.115) yet.
If Rockchip reads this: knock it off and use a reasonable speed for console on your devices!
Audio selection not sticking after reboot ROCK 5B plus
sakittelsen replied to the skid's topic in Radxa Rock 5B
You delete all files in that folder. -
the skid replied to the skid's topic in Radxa Rock 5B
Then I will not hold my breath
These commands work for me: pactl list short sinks #shows available audio outputs sudo -H nano /etc/pulse/default.pa #opens the file for editing set-default-sink alsa_output.platform-hdmi0-sound.stereo-fallback #set your default audio output rm -r ~/.config/pulse #delete all files in this folder reboot -
Between days and month. Depending on time, issues, regressions,... Refrain from asking for ETA. Putting pressure on developers who give you something for free is abusive.
hi running Armbian 25.2.3 stable 6.1.99-vendor-rk35xx (Ubuntu noble) having to change audio every time on reboot (not sticking after selecting),and maybe not showing as they should ,currently using HDMI 0 but shows as below:
Linux 6.15 was released yesterday. How long does it normally take before it's ready for the armbian build process?
error when setting root password
sakittelsen replied to sakittelsen's topic in Software, Applications, Userspace
I guess the problem is that I'm using a simple 2 character password. It has been working fine until now. I'll try a long password next time. -
ssh.service inactive after frist boot
Werner replied to PP88PP's topic in Software, Applications, Userspace
Check journalctl/syslog for clues. -
If nvme is correctly recognized code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } armbian-install should do.
- 1 reply
1
https://debug.armbian.de for obtaining low level logs to debug further.
???It's turned into a brick, where's your img file
AaronNGray replied to PP88PP's topic in Software, Applications, Userspace
I am unable to reload or restart sshd now for some reason ? -
Hi @Michael Robinson, thanks for the help, but one of the first things i did was check the build process. Unfortunately there is no orangepi5-pro board in the v24.8.1 branch which makes that warning about 24.8.1 version even hard to understand. I tried to compile new versions, but none of those new versions boot. Hi @Wernerthanks for the tip, but unfortunately the oldest version on github is 24.11 and they do not boot
Please help, I've tried everything.
After booting up, the network card cannot be recognized on armsom. The network card is Broadcom's bcm4375. However, it was recognized after suspend once, but it can no longer be recognized afterwards. There is no relevant log in the log. When it was recognized, I wanted to open a p2p connection, but it could not be opened.
I'd probably try to code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } dd the Armbian image directly onto sda and boot.
rk bsp branch has been bumped to .115 (or rkr5.1 as they call it) a few weeks or month ago, so fairly recent.
