KickPi K2B not booting up: DRAM setup not supported
chuanzz replied to chuanzz's topic in KickPi K2B
Still no network. I checked the official SDK, it uses the following hardware: Wired network: Allwinner GMAC driver + external PHY; Wireless network: AIC8800 series WiFi module driver; Bluetooth: AIC8800 Bluetooth Low Energy driver; USB network: RTL8152 USB to Ethernet driver. Does this have any impact? -
c0rnelius replied to chuanzz's topic in KickPi K2B
Nice. -
The parameters I’m using were extracted from the official Linux SDK using GPT. At least the DRAM parameters are functional. Debian can boot and log in normally, but there’s no wired network or WiFi/Bluetooth. I’m currently investigating why this is happening. - Today
I was just about to post a binary with something similar. So does the above work for you? I was gonna try this: CONFIG_DRAM_SUNXI_DX_ODT=0x03030303 CONFIG_DRAM_SUNXI_DX_DRI=0x0e0e0e0e CONFIG_DRAM_SUNXI_CA_DRI=0x1f12 CONFIG_DRAM_SUNXI_TPR0=0xc0001002 CONFIG_DRAM_SUNXI_TPR10=0x2f1107 CONFIG_DRAM_SUNXI_TPR11=0xddddcccc CONFIG_DRAM_SUNXI_TPR12=0xeddc7665 CONFIG_MACH_SUN50I_H616=y CONFIG_SUNXI_DRAM_H616_DDR3_1333=y CONFIG_DRAM_CLK=648 -
I used ur project https://github.com/pyavitz/debian-image-builder changed this file "patches\uboot\v2025.07\sun50i-h618\002-Add-board-KickPi-K2B.patch" +CONFIG_OF_UPSTREAM=y +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_DEFAULT_DEVICE_TREE="allwinner/sun50i-h618-kickpi-k2b" +CONFIG_SPL=y +CONFIG_DRAM_SUNXI_DX_ODT=0x03030303 +CONFIG_DRAM_SUNXI_DX_DRI=0x0e0e0e0e +CONFIG_DRAM_SUNXI_CA_DRI=0x1f12 +CONFIG_DRAM_SUNXI_ODT_EN=0x0 +CONFIG_DRAM_SUNXI_TPR0=0xc0001002 +CONFIG_DRAM_SUNXI_TPR1=0x30fb +CONFIG_DRAM_SUNXI_TPR2=0x0000 +CONFIG_DRAM_SUNXI_TPR6=0x33808080 +CONFIG_DRAM_SUNXI_TPR10=0x2f1107 +CONFIG_DRAM_SUNXI_TPR11=0xddddcccc +CONFIG_DRAM_SUNXI_TPR12=0xeddc7665 +CONFIG_DRAM_SUNXI_TPR13=0x40 +CONFIG_MACH_SUN50I_H616=y +CONFIG_SUNXI_DRAM_H616_DDR3_1333=y +CONFIG_DRAM_CLK=648 +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_R_I2C_ENABLE=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_I2C=y +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_SYS_I2C_SLAVE=0x7f +CONFIG_SYS_I2C_SPEED=400000 +CONFIG_SUN8I_EMAC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_PHY_REALTEK=y +CONFIG_RTL8211F_PHY_FORCE_EEE_RXC_ON=y +CONFIG_RGMII=y +CONFIG_RMII=y +CONFIG_AXP313_POWER=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_MUSB_GADGET=y and maked a u-boot the debian was starting I was testing it -
verbosity was 7 already But no more log -
Change the loglevel to 7 in the armbianEnv file and if anything comes up after Starting kernel ... post it. -
Armbian with preinstalled OpenMediaVault (OMV)
usual user replied to Igor's topic in Software, Applications, Userspace
Out of curiosity, does it work if you drop my firmware build in place? dd bs=512 seek=1 conv=notrunc,fsync if=u-boot-meson.bin of=/dev/${entire-device-to-be-used} u-boot-meson.bin.tgz -
roastmeat replied to Igor's topic in Software, Applications, Userspace
This is my first time running Armbian on the odroid HC4, For some reason, I can boot without any drives (uSD card), and sometimes with one drive but never with two. Like no display on the monitor or can't ssh into the system. Anyone else getting something like this? I've wiped the 4 onboard memory locations so that it can boot from SD card (which it does without any drives) -
Hey @Adrienne, Github thread talks about two to three ways to so solve the issue. Did you apply the one that removes the symlinks ?
A phandle is a magical number assigned during DTB assembly, whose value is irrelevant as long as it references the same node with the phandle property. The magic value can change when the structure changes because it is assigned arbitrarily; for example, by inserting an additional node.
Thanks @Nick A for the details and link shared ! If I understand correctly, I can build kernel only locally and freeze kernel update. other packages can be downloaded from public repository Is that correct?
In an XWindow environment, these are realistically expected numbers. In a Wayland environment, this is somewhat better; see glmark2-wayland-odroid-m1.log as a reference. But it is in no way comparable to a Mali G610; see glmark2-wayland-odroid-m2.log as a reference. Use WebGL Report to be sure.
There is a minor difference in another node: "phandle = <0x2c2>;" in radxa.dts and phandle = <0x2c3>; No clue if that's the culprit or if there is something on software-side to make fan work.
Hi - I have a ZeroPi board running 'bookworm' as supplied by the vendor. I woudl like to run 'trixie' and downloaded it from this page https://www.armbian.com/zero-pi/ but had no luck getting it booted. Would anyone have an idea how to get this to work or what the status is of 'trixie' for the ZeroPi boad. Thanks
@Igor - Can you have a look at this please. I have retrieved the devicetree's for the radxa Debian release on which the fan works and my Armbian Ubuntu build using dtc -I fs /sys/firmware/devicetree/base uname -a lsb_release -a https://github.com/AaronNGray/radxa-rock-5b-plus The 'pwm-fan' nodes are the same.
@BipBip1981, can you please share again your feedback on fancontrol running on Trixie ? The site can't display the image.
He works as ili9341 and as ili9486. I use it now as ili9486. I`ll go further to make it work as native device. DRM frambuffer its something what needs to be kernel recompiled... as i know? And if i want to use it natively, i must edit or recompile u-boot.... DRM support for ILI9486 display panels modulename: ili9486.ko configname: CONFIG_TINYDRM_ILI9486 Linux Kernel Configuration └─>Device Drivers └─>Graphics support └─>Direct Rendering Manager (XFree86 4.1.0 and higher DRI support) └─>SPI support └─>DRM support for ILI9486 display panels In linux kernel since version 4.14.326 (release Date: 2023-09-23) DRM driver for the following Ilitek ILI9486 panels: * PISCREEN 3.5" 320x480 TFT (Ozzmaker 3.5") * RPILCD 3.5" 320x480 TFT (Waveshare 3.5") If M is selected the module will be called ili9486. I will use it for KlipperScreen 😆 But as i se how hard is working that orangePi PC,i`ll doubt if i need this... Any way i`ll try )) Yes. But HDMI not connected. On OrangePiOne image its switching. If HDMI is connected its use it with no output to SPI. But if no HDMI present its use SPI as basic overlay On the same board. Because OPiOne had only 1 usb, OPiPC work only 1 usb ))) if whey work all 3, i`ll didnt open up a topic 😑 ili9486.dts
In that case, dont try my solution: it is for the red ili9341. If you search ili9486 threads in this forum, that same blue LCD is ili9486... so you were wrong in calling it ili9341 in the first place If you have time, find another solution to get you a DRM frambuffer (instead of a classic FB). Then you can enjoy smoother animations and video. Regarding displaying boot messages to the LCD, instead of HDMI. I don't know, but it may be because your HDMI is /dev/fb0 and the LCD is /dev/fb1 Will you use X11?
I`ll think its china lcd, it`s been presented many ears ago by someone to me. Thanks to your sugestions. I read it before topic up. As U can read, it working now, with touch The last question is how to output to it when system boots... Something like auto switch from HDMI to SPI LCD. Or just SPI LCD output after U-Boot loading. rc.local with con2fbmap 1 1 in it is not an good thing. Any Advice?
I build a u-boot with it dd latest armbian.img and this u-boot, it showed: ▒[40]HELLO! BOOT0 is starting!r = 0x1d3 [43]BOOT0 commit : 4b34f2890a [46]set pll start [48]periph0 has been enabled [51]set pll end [54]unknow PMU [56]unknow PMU [59]PMU: AXP1530 [64]vaild para:15 select dram para1 [68]board init ok [69]enable_jtag [71]DRAM BOOT DRIVE INFO: V0.651 [74]the chip id is 0x2000 [77]chip id check OK [80]DRAM_VCC set to 1500 mv [86]read_calibration error [92]read_calibration error [98]read_calibration error [104]read_calibration error [110]read_calibration error [116]read_calibration error [122]read_calibration error [128]read_calibration error [135]read_calibration error [141]read_calibration error [143]retraining final error [152][AUTO DEBUG]32bit,1 ranks training success! [164]DRAM CLK =648 MHZ [166]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [174]Actual DRAM SIZE =2048 M [177]DRAM SIZE =2048 MBytes, para1 = 310a, para2 = 8000000, dram_tpr13 = 6041 [190]DRAM simple test OK. [193]rtc standby flag is 0x0, super standby flag is 0x0 [198]dram size =2048 [201]Use rtc to store dram tuning para [205]card no is 0 [207]sdcard 0 line count 4 [209][mmc]: mmc driver ver 2021-10-12 13:56 [214][mmc]: b mmc 0 bias 4 [222][mmc]: Wrong media type 0x0 [225][mmc]: ***Try SD card 0*** [240][mmc]: HSSDR52/SDR25 4 bit [243][mmc]: 50000000 Hz [245][mmc]: 119850 MB [247][mmc]: ***SD/MMC 0 init OK!!!*** [319]Loading boot-pkg Succeed(index=0). [323][mmc]: b mmc 0 bias 4 [325]Entry_name = u-boot [332]Entry_name = monitor [336]Entry_name = dtbo [339]Entry_name = optee [343]Entry_name = dtb [346]mmc not para [347]Jump to second Boot. NOTICE: BL3-1: v1.0(debug):54937d5 NOTICE: BL3-1: Built : 17:44:59, 2021-12-13 NOTICE: BL3-1 commit: 8 NOTICE: cpuidle init version V2.0 NOTICE: secure os exist MESSAGE: [0x0] TEE-CORE: OP-TEE version: 81ab7a47 #1 2020年 05月 06日 星期三 02:40:04 UTC arm NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3 and I found this: [177]DRAM SIZE =2048 MBytes, para1 = 310a, para2 = 8000000, dram_tpr13 = 6041 is this para what we need? -
Try this solution for the orange pi zero LTS, which is the same chip as the opiPC, but change the pin definitions to what you have. Do you have a 480x320 ili9341? Which one is it?
This one failed with "DRAM:This DRAM setup is currently not supported" I found something from kickpi's site:Linux_SDK_Compilation. including building u-boot https://github.com/tan-zhihao1/kickpi-book/blob/master/h618/en/04-SDK_Compilation_Guide/02-Linux_SDK_Compilation.md Its too huge so I deleted the folder "source" and "toolchains". hope it could help I tried to upload here but it shows errors. try this url: https://we.tl/t-t92S5rlCzD -
@Jeeva Kandasamy I would freeze your kernel updates using armbian-config. I’m using a custom kernel so it will break your system. I made google search and found this. https://github.com/MichaIng/DietPi/issues/4600
