Hi, I try to compile armbian with "Armbian Build Framework", and choosing the "rock-3a" board. No problem to compile, write on sd card with "dd". I only see one ethernet port. When I switch dtb file on "/boot/armbianEnv.txt", I see the second ethernet but it nor working at all .... I don't know how to fix this ...
The page for the NanoPi R76S has also an edge kernel (6.18) image. I noticed some issues related to sdcard and emmc. I know edge images are not officially supported and that is fine. But given the image is available I would like the parameters/configuration/conditions for the current available image. Could you explain the background or assumptions behind the 6.18 edge image for the R76S? (e.g., test conditions you used when building it)
laibsch replied to ずっと一人's topic in Orange Pi 5 Plus
suggested solution is to move to kernel 6.18 -
I was able to get it out. I'm pretty good at Linux, but not at screens. Maybe I'm missing something?
No overlays when kernel 6.18.1-edge-sunxi compile
Werner replied to eselarm's topic in Allwinner sunxi
https://github.com/armbian/build/pull/9094 -
Hm yes, around line 26785 there should be the overlay folder. Oddly when I tried it was there. -
As a follow up: got my board yesterday. 2GB RAM as announced, no obvious bringup probs. The Ubuntu image runs from SD, UART ok, got 80mb/s from SD and around ~300mb/s from an 128GB 2230 NVME. No boot from upper m.2, only lower m.2 boots (works as announced). The SBC starts via uboot stored on the 16mbyte SPI flash, so I think it should be possible to also boot from upper m.2 since the uboot recognizes media both m.2 slots. Currently unclear how to recover from damaged SPI flash, so I need to proceed carefully. Uboot env is closed (bootdelay=0), so first task is to open up uboot cmd line. Theres a boot switch that seems to trigger some USB boot from ROM but thats undocumented AFAICT. Plenty to investigate for my 50 bucks 😉
What kernel version are you using?
Updade: i tried to flash to memory using a male to male USB "Bus 003 Device 008: ID 1f3a:efe8 Allwinner Technology sunxi SoC OTG connector in FEL/flashing mode" Needless to say, i've been duped, scammed, fooled perhaps. I found a picture of a model exactly the same as that one, and it had a H3 chip, since from what i see Rockchip is best supported by the comunity, i'll give up on this board. Tomorrow i'll do one last update when the USB-TTL arrives, to see if my suspicions are confirmed.
Can you get an orange pi zero 3? As a hardware beginner, you need a very stable, well known linux board.
Sorry, I've never done anything like this before. I tried setting it up according to instructions in various GitHub threads, but it always failed. You're the only person who helps me with advice, and thanks to you, I've only been able to build an image with the required kernel module. I haven't achieved anything else, except for the white screen.
See build log https://paste.armbian.de/lesoquheja The kernel works, but installing the .deb failed because my extlinux script could not copy: /usr/lib/linux-image-6.18.1-edge-sunxi/overlay/sun8i-h3-analog-codec.dtbo The whole overlay folder does not exist. It does exist for 6.12.58-current-sunxi and last time I compiled kernel for the nanopineo was 6.16.8, the overlays were created. I remember it was also once the case with edge kernel for other SBC ( .deb package from the Armbian beta repo). That time own local build did create overlays. I am not sure where to look or what could be wrong.
Alright Did you ever make this LCD work with your H618 motherboard, with another kernel driver?
I just registered here to say thanks to @bAL, your solution works on my Odroid HC4. I was bashing my head against the wall because I couldn't find what was constantly changing the fan PWM value even after disabling the fancontrol service. Now I finally have full control over the fan PWM (and thus the noise levels). Thanks again! So yeah, this issue is still relevant in 2025. `lsb_release -a` output for the interested: Distributor ID: Debian Description: Armbian 25.11.2 trixie Release: 13 Codename: trixie
Odd. Should more look like this. Also the first time I hear there is an issue like this. Perhaps retry now since your group is no longer validation but members. https://x.na4.eu/KOTu3/PACoFIsE81.jpg
Try the X11 windowing manager or the Wayland compositor without lightdm (or another display manager). -
Thanks @Werner for the button-descriptions, but I simply don't see anything you're describing. Tried in 2 different browsers (LibreFox, Chromium). It still says "P3ter: Validating" next to my "P"-Icon. Maybe I don't have the rights yet? LibreFox has NoScript on, but allowing from armbian.com - and chromium as test-browser has all scripts enabled: So it shouldn't be a script-blocker issue.
@Jerry Falken I am pretty sure you jumped in this 3ad without reading all of it, and this is unfair . You are right, it is huge, but such question you ask have been already answered in the past many times , and I will answer just as a form of courtesy , but will not go back in the future on the same question again If you look at your board you can spot 3 pads : tx rx gnd . That is all is needed, no 5 volts just tx rx gnd Those pads are the "uart" , in other words there you will see ALL that happens when the board starts, if is a rk 322x or other fake print, if it is ddr3 or ddr2 manyyyyy manyyy infos to debug the whole process. For me it is a 3229 with ddr3 memory but uart will tell you Go find in the 1st post the speed of uart to use with putty or minicom ( spoiler :1500000 🙃 ) just for sake of coriousity, this si the setting I have in my lab: ALWAYS and I repeat ALWAYS a uart connected to debug what is going so if you need answer.. post the right questions and not generic ones g on
Output of the USB TTL converter or of another chip? the one's I've seen online have 5 pins, but you only mentioned three places for the pins to go to, that is unless the 5v and 3.3v lines aren't needed for this specific use case. For curiosity's sake, what should i expect to see from something like that? I'll need to purchase that, so while it arrives, is there any chance that the CPU simply had an incorrect print, and i need another version of Multitool? Sorry for asking so many questions, just that i have little experience doing this.
I've read your DXVK-stripped code on github. Looks like your code is far behind the original one. Is your code can match the release "stripped 2.7.1" libs you provide? Thanks you so much! -
@JuanEsf sunxi-edge is now on 6.18. You can add your patches for t527 there.
I noticed that some games are using DXVK while some are using wined3d, what is the reason? It that a way that force every game using DXVK? -
Sure. However, I am in PRC, Google is blocked. I cannot login in on my SBC since I am using Google account to login. I have to use my laptop which has vpn. I will find a way this weekend. -
Do you mind sharing some screenshots + your settings ? -
Sorry I missed the "dxvk-stripped", Now it works fine! thank you so much!
