This is from Hardkernel, I don't have an Amlogic SBC, but I once saw petitboot is sort of boot-selection and/or OS installer (menu driven) thing. Same as for Rockchips where old RK35xx mostly 2017.09 based U-Boot does not work with newer mainline based kernel, you can expect the same here. So wherever that U-Boot is stored (SPI-flash, eMMC), you need to make sure it is not used, so wipe it or bypass it or overwrite it with the U-Boot binary that comes with the Armbian image you try to boot. In your currently running system, so with old kernel but new userspace, you should be able to use armban-config to flash the current and kernel 6.18 matching U-Boot to the specific storage where petitboot is now stored. But means overwriting, I would first save it, done that for some other ARM boards (also smartphones) at least as you never know if you might need the exact old/vendor firmware/bootloader for fixing some problem many years from now. So make sure you know the right sector numbers for that Amlogic SoC where it look for bootloader at power on. Can be found in docs (Hardkernel) or see /usr/lib/u-boot/platform_install.sh
Update: if I wait long enough, then I finally see the Reboot screen. After reboot, I can go to http://<IP_address_Le_Potato>:8123 and I do see the Home Assistant intro screen. After creating an account, giving the location parameters and so on, I finally get the Home Assistant screen. I see in the command terminal that the following containers are available: hassio_observer hassio_supervisor See attached image. However, when I go to Settings, I don't see the Add-ons section. I admit I'm not a Home Assistant expert yet (first steps into HA) but I thought that the superviisor was just to have the Add-ons section available to the user? That's the reason I tried the Armbian Home Assistant image, hoping the Add-ons section would be available. Do I have to make myself a "supervisor" (again, I'm not a Home Assistant expert yet...)? If so, how can this be done? I need MQTT and Zigbee2MQTT, hence the need for the Add-ons section, which I currently don't have... Best, --Geert
Where did you get this uboot? I strongly believe this is not from Armbian, hence support is impossible.
Hi, First post here. I'm fairly new with Armbian. I have a LibreComputer Le Potato that I want to use for Home Assistant. To avoid all the hassle of setting up Home Assistant with docker, I used the Armbian imager to install the Armbian 26.2.1 Home Assistant on an SD card. Once the SD card was flashed, I put it into the Le Potato board. The board starts up fine, asks for the root password, creates a new user and so on. Later on, the Preparing Home Assistant Supervised window appears. However, after the first round to 100% I get a "RTNETLINK answers: Invalid argument" on the screen. The preparation goes on and on, moving the progress bar over and over to 100%. But the installation seems to never stop. See the image attached for the error I get. Anyone any idea? Best, --Geert
Thanks for the great work Nick. I recently bought a SPI screen and managed to drive it with panel-mipi-dbi in the newer kernel (apparently this module didn't exist in Radxa's official image with kernel 5.15). The panel was a ST7789V 240*320 TFT LCD and I have a A7Z, with the `Radxa-cubie-A7a-a7z-v0.6.4` server image installed. And I have put the work on [Github](https://github.com/parker-int64/sun60i-a733-dtoverlays). During the experiment, I discovered that the PWM (used for display backlight) in the allwinner BSP seems to have a bug. The Allwinner Sunxi PWM driver may incorrectly reverts the PWM pin to GPIO input immediately after switching the pinctrl state. Thus I can control the PWM with the file nodes but can't attached it to related pins. For example, I'm using the `sun60i-a733-pwm1-7.dtso` overlay, which is supposed to enable the PJ25. After enabling the overlay, I noticed that the PWM nodes were created and I can controll these nodes. But the pinctrl suggest that it was unclamied: $ cat /sys/kernel/debug/pinctrl/2000000.pinctrl/pinmux- pins | grep PJ25 pin 313 (PJ25): UNCLAIMED Later on, AI found out that the `devm_pinctrl_put(pctl);` in bsp/drivers/pwm/pwm-sunxi.c may have been incorrectly called on the clean stage of the `sunxi_pwm_pin_set_state`: 520 static int sunxi_pwm_pin_set_state(struct device *dev, char *name) 521 { 522 struct pinctrl *pctl; 523 struct pinctrl_state *state = NULL; 524 int err; 525 526 pctl = devm_pinctrl_get(dev); 527 if (IS_ERR(pctl)) { 528 sunxi_err(dev, "pinctrl_get failed\n"); 529 err = PTR_ERR(pctl); 530 return err; 531 } 532 533 state = pinctrl_lookup_state(pctl, name); 534 if (IS_ERR(state)) { 535 sunxi_err(dev, "pinctrl_lookup_state(%s) failed\n", name); 536 err = PTR_ERR(state); 537 goto exit; 538 } 539 540 err = pinctrl_select_state(pctl, state); 541 if (err) { 542 sunxi_err(dev, "pinctrl_select_state(%s) failed\n", name); 543 goto exit; 544 } 545 546 exit: 547 /* 548 * devm_pinctrl_put() releases the last pinctrl reference, 549 * causing pinmux_disable_setting() to restore the pin to 550 * its default GPIO function. The devres framework will 551 * release this resource automatically when the device is 552 * destroyed. 553 */ 554 devm_pinctrl_put(pctl); 555 return err; 556 557 } Also it gives me a workaround `sunxi-pwm-child-pinctrl.c`, introduces an additional pinctrl reference, preventing `devm_pinctrl_put()` from reducing the reference count to zero. Both the patch file and the workaround source is available on Github. However I only tried the workaround since I have some trouble compile the full kernel at the moment, will try some time later and update more details on Github. And at last the pwm-backlight worked as expected and my LCD light up.
Finally got an UART device for logs U-Boot 2015.01 (Sep 01 2020 - 18:41:51) DRAM: 3.5 GiB Relocation Offset is: d6eeb000 spi_post_bind(spifc): req_seq = 0 register usb cfg[0][1] = 00000000d7f83da8 MMC: aml_priv->desc_buf = 0x00000000d3edb7c0 aml_priv->desc_buf = 0x00000000d3eddb00 SDIO Port C: 0, SDIO Port B: 1 co-phase 0x3, tx-dly 0, clock 400000 co-phase 0x3, tx-dly 0, clock 400000 co-phase 0x3, tx-dly 0, clock 400000 emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 co-phase 0x3, tx-dly 0, clock 400000 co-phase 0x1, tx-dly 0, clock 40000000 aml_sd_retry_refix[983]:delay = 0x0,gadjust =0x12000 [mmc_startup] mmc refix success [mmc_init] mmc init success In: serial Out: serial Err: serial vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters vpu: driver version: v20190313 vpu: detect chip type: 9 vpu: clk_level default: 7(666667000Hz), max: 7(666667000Hz) vpu: clk_level = 7 vpu: vpu_power_on vpu: set_vpu_clk vpu: set clk: 666667000Hz, readback: 666666667Hz(0x100) vpu: set_vpu_clk finish vpu: vpu_module_init_config vpp: vpp_init vpp: g12a/b osd1 matrix rgb2yuv .............. vpp: g12a/b osd2 matrix rgb2yuv.............. vpp: g12a/b osd3 matrix rgb2yuv.............. cvbs: cpuid:0x29 cvbs_config_hdmipll_g12a cvbs_set_vid2_clk ** File not found boot-logo.bmp.gz ** ** File not found boot-logo.bmp ** movi: not registered partition name, logo movi - Read/write command from/to SD/MMC for ODROID board Usage: movi <read|write> <partition|sector> <offset> <address> [<length>] - <read|write> the command to access the storage - <offset> the offset from the start of given partiton in lba - <address> the memory address to load/store from/to the storage device - [<length>] the size of the block to read/write in bytes - all parameters must be hexa-decimal only [OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters [OSD]set initrd_high: 0x3d800000 [OSD]fb_addr for logo: 0x3d800000 [OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters [OSD]fb_addr for logo: 0x3d800000 [OSD]VPP_OFIFO_SIZE:0xfff01fff [CANVAS]canvas init [CANVAS]addr=0x3d800000 width=5760, height=2160 cvbs: outputmode[1080p60hz] is invalid vpp: vpp_matrix_update: 2 set hdmitx VIC = 16 config HPLL = 5940000 frac_rate = 1 HPLL: 0x3b3a04f7 HPLL: 0x1b3a04f7 HPLLv1: 0xdb3a04f7 config HPLL done j = 6 vid_clk_div = 1 hdmitx phy setting done hdmitx: set enc for VIC: 16 enc_vpu_bridge_reset[1319] rx version is 1.4 or below div=10 Net: dwmac.ff3f0000 Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 ## Attempting fetch boot.ini in mmc:0... ** File not found boot.ini ** ## Executing script at 04000000 Wrong image format for "source" command ## Attempting fetch boot.scr in mmc:0... ** File not found boot.scr ** ## Executing script at 04000000 Wrong image format for "source" command ## Attempting fetch /boot/boot.ini in mmc:0... 5578 bytes read in 5 ms (1.1 MiB/s) ## Executing script at 04000000 0 bytes read in 3 ms (0 Bytes/s) Found mainline kernel configuration HDMI cable is NOT connected 178 bytes read in 5 ms (34.2 KiB/s) ** File not found uImage ** 42404352 bytes read in 1187 ms (34.1 MiB/s) ** File not found dtb/amlogic/meson-g12b-odroid-n2-plus.dtb ** 83033 bytes read in 29 ms (2.7 MiB/s) ** File not found uInitrd ** 22881405 bytes read in 642 ms (34 MiB/s) ee_gate_off ... Wrong Image Format for bootm command ERROR: can't get kernel image! [rsvmem] get fdtaddr NULL! rsvmem - reserve memory Usage: rsvmem check - check reserved memory rsvmem dump - dump reserved memory rsvmem check failed ee_gate_on ... ## Attempting fetch /boot/boot.scr in mmc:0... 8133 bytes read in 3 ms (2.6 MiB/s) ## Executing script at 04000000 U-boot default fdtfile: meson-g12b-odroid-n2-plus.dtb Current variant: n2_plus For variant n2_plus, set default fdtfile: amlogic/meson-g12b-odroid-n2-plus.dtb Unknown command 'part' - try 'help' Current fdtfile after armbianEnv: amlogic/meson-g12b-odroid-n2-plus.dtb Mainline bootargs: root=/dev/mmcblk1p1 rootwait rootfstype=ext4 splash=verbose console=ttyAML0,115200 console=tty1 consoleblank=0 coherent_pool=2M loglevel=1 ubootpart= libata.force=noncq usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=memory ** File not found uInitrd ** ** File not found Image ** ** File not found dtb/amlogic/meson-g12b-odroid-n2-plus.dtb ** libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! ** File not found dtb/amlogic/overlay/-.dtbo ** ** File not found dtb/amlogic/overlay/-fixup.scr ** [rsvmem] get fdtaddr NULL! rsvmem - reserve memory Usage: rsvmem check - check reserved memory rsvmem dump - dump reserved memory rsvmem check failed Bad Linux ARM64 Image magic! ## Attempting fetch boot.ini in mmc:1... card out ** Bad device mmc 1 ** ## Executing script at 04000000 U-boot default fdtfile: amlogic/meson-g12b-odroid-n2-plus.dtb Current variant: n2_plus For variant n2_plus, set default fdtfile: amlogic/meson-g12b-odroid-n2-plus.dtb card out ** Bad device mmc 1 ** Unknown command 'part' - try 'help' Current fdtfile after armbianEnv: amlogic/meson-g12b-odroid-n2-plus.dtb card out ** Bad device mmc 1 ** Mainline bootargs: root=/dev/mmcblk1p1 rootwait rootfstype=ext4 splash=verbose console=ttyAML0,115200 console=tty1 consoleblank=0 coherent_pool=2M loglevel=1 ubootpart= libata.force=noncq usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=memory card out ** Bad device mmc 1 ** card out ** Bad device mmc 1 ** card out ** Bad device mmc 1 ** libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! card out ** Bad device mmc 1 ** card out ** Bad device mmc 1 ** card out ** Bad device mmc 1 ** [rsvmem] get fdtaddr NULL! rsvmem - reserve memory Usage: rsvmem check - check reserved memory rsvmem dump - dump reserved memory rsvmem check failed Bad Linux ARM64 Image magic! After this it loops it for all mmc/usb devices and breaks. I need to manually copy old kernel files to /boot to get it to work again (through petitboot) Anything after 6.12.58 seems to break for me. Thoughts?
If you can experiment with the board, then try few other kernels: https://docs.armbian.com/User-Guide_Armbian-Config/System/#alternative-kernels and report where wifi will be up.
Wow... OK, this is far beyond what I understand. I see a mediatek wifi dongle in USB 2-1 I think the plugged in dongle. But have no idea were the internal WiFi adapter is and how to activate it. It worked in a previous version of armbian ubuntu but not the latest I just found out... Ernst-Jan
https://paste.armbian.com/emoyipejug
There is a previous topic on this from 2020, but it's closed and not much action was taken except discussing workarounds. I'd like to continue this. Looking at the kernel configs in this repo, many of them have CONFIG_RT_GROUP_SCHED=y. This does not play nicely with modern systemd (cgroups v2), breaking things like rtkit-daemon. See https://bugs.gentoo.org/569546 and https://bugzilla.redhat.com/show_bug.cgi?id=655321. rtkit is an important part of making pulseaudio and pipewire work smoothly, as well as for many other low-latency applications. There are a few currently available workarounds, but none are ideal: 1. Linux 6.16 or later has boot time param rt_group_sched=0 to override it, but there is still some runtime overhead. No exact alternative for earlier kernels. 2. kernel.sched_rt_runtime_us=-1 in sysctl.conf -- potentially dangerous as it removes the 95% CPU time safeguard for RT processes, leading to lockups when badly behaving processes exist. 3. disable cpu and cpuset cgroup controllers in systemd configs -- has a lot of other side effects, like preventing systemd's CPU limits for services Since the last post on this (linked above), forcefully assigning an rt time time slice won't even work anymore, since cgroup v2 doesn't even have that ability anymore. So this kernel config option is somewhat useless now.
thanks. The image has been launched. I will try to test gpio and mipi camera.
Hello, I use with 6.18.15 the two way below. - new way with armbian-config and choses the overlay stabilty file for helios64 - the old way with my old dtb file for 6.18.xx kernel that i downloaded in this forum and work good with all 6.18.xx kernel until 6.18.10 kernel (rk3399-kobol-helios64.dtb-6.18.18-opp.zip) Have a good day -
I already did the apt update & upgrade, it actually seems like the 6.18.35 did solve that issue - or at least, that's how I'd read the newer "armbianmonitor -u" as posted here: https://paste.armbian.com/orawuzawun PS: I didn't test again if it works now without the script for reasons of lack of access to the bananapi + local screen + local keyboard in case it still came up without end0 - bot the output of armbianmonitor at least doesnt show up that failure you pointed at.
Added https://github.com/armbian/build/pull/10213
does rockpro64 armbian cli come with non free software?
eselarm replied to renky's topic in Pine RockPro64
You should check with: grep non-free /etc/apt/sources.list.d/*.sources And remove the non-free components and also remove/purge all packages that belong to non-free. You probably need some 'man apt-get' to figure out how to select those. -
I see in your log: [ 15.439789] sun7i-dwmac 1c50000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 15.466497] sun7i-dwmac 1c50000.ethernet end0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=POLL) [ 15.677165] sun7i-dwmac 1c50000.ethernet end0: Failed to reset the dma [ 15.758481] sun7i-dwmac 1c50000.ethernet end0: stmmac_hw_setup: DMA engine initialization failed [ 15.772254] sun7i-dwmac 1c50000.ethernet end0: __stmmac_open: Hw setup failed If I look at my bpi: root@banlipi:~# dmesg | grep ethernet [ 3.767952] sun7i-dwmac 1c50000.ethernet: IRQ eth_wake_irq not found [ 3.774414] sun7i-dwmac 1c50000.ethernet: IRQ sfty not found [ 3.780287] sun7i-dwmac 1c50000.ethernet: PTP uses main clock [ 3.894850] sun7i-dwmac 1c50000.ethernet: Version ID not available [ 3.902941] sun7i-dwmac 1c50000.ethernet: DWMAC1000 [ 3.907950] sun7i-dwmac 1c50000.ethernet: No HW DMA feature register supported [ 3.915196] sun7i-dwmac 1c50000.ethernet: TX Checksum insertion supported [ 3.922008] sun7i-dwmac 1c50000.ethernet: Normal descriptors [ 3.927689] sun7i-dwmac 1c50000.ethernet: Ring mode enabled [ 5.766296] sun7i-dwmac 1c50000.ethernet end0: renamed from eth0 [ 19.418540] sun7i-dwmac 1c50000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 19.465510] sun7i-dwmac 1c50000.ethernet end0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=POLL) [ 19.476982] sun7i-dwmac 1c50000.ethernet end0: No Safety Features support found [ 19.484490] sun7i-dwmac 1c50000.ethernet end0: RX IPC Checksum Offload disabled [ 19.491897] sun7i-dwmac 1c50000.ethernet end0: No MAC Management Counters available [ 19.508289] sun7i-dwmac 1c50000.ethernet end0: PTP not supported by HW [ 19.514967] sun7i-dwmac 1c50000.ethernet end0: configuring for phy/rgmii-id link mode [ 23.717977] sun7i-dwmac 1c50000.ethernet end0: Link is Up - 1Gbps/Full - flow control rx/tx root@banlipi:~# uname -a Linux banlipi 6.18.35-current-sunxi #1 SMP Tue Jun 9 10:28:53 UTC 2026 armv7l GNU/Linux So no DMA related problem. The AI advise is nonsense IMO; There might some (longterm) hidden bug/issue in the sunxi kernel when running on bananapi as mine usually hangs after a few days with a kernel paging issue, root cause I don't now. BUT, now tha I am challenging this with 24/7 kernellogging via serial console, 'it does not wanna crash': root@banlipi:~# uptime 14:32:05 up 7 days, 18:13, 1 user, load average: 0.07, 0.14, 0.12 I must say only thing it does is read out the AXP PMU values every 10s and pushes that into influxDb. Maybe I should hook up a SATA SSD or HDD and see if I can repeat. Maybe doe upgrade, so you get newer kernel (6.18.35): sudo apt update && sudo apt full-upgrade -y
Armbian_community_26.8.0-trunk.359_Rockpro64_trixie_current_6.18.38_minimal.img.xz If the image installs non free software on the computer can you tell which packages they are and how to remove them from the computer, such that no piece of non free software stays on the computer? In this post free software should be understood as coined by the fsf.org. Thank you.
I Installed this image and it works fine. Sadly the build in WiFi module is not working. I now use an external wifi dongle. What could be the problem here? Ernst-Jan
Hi, FYI, there might be an issue with old, slow hardware. Yesterday I installed the minimal Ubuntu 26.04 current 6.18.24 downloaded from https://armbian.com/boards/bananapi on my old Banana Pi on an similar old 8GB SD by sandisk. It runs normaly, but cannot set up the end0 during booting. Doing an "ip link set end0 up" manually on cli afterwards immediately activated end0, so my solution was using an script to do this command after booting. The AI aiding me thinks it's just the slow hardware causing a timeout when it should set up the interface during booting. Just wanted to let you know.
Using the KDE image on eMMC storage, this is how far the boot process get. The results or from the serial port. [217]HELLO! BOOT0 is starting! [220]BOOT0 commit : 595900dccf [224]periph0 has been enabled [227]set pll end [229]PL gpio voltage : 3.3V [233][pmu]: bus read error [236]PMU: AXP2202 [241]PMU: AXP1530 [245]power mode:33, sys_vol:920 [249]vaild para:1 select dram para0 [253]dram_para[0]:0x4b0 [255]dram_para[1]:0x8 [258]dram_para[2]:0x7070707 [261]dram_para[3]:0xd0d0d0d [264]dram_para[4]:0xe0e [266]dram_para[5]:0x84848484 [269]dram_para[6]:0x310a [272]dram_para[7]:0x8000000 [275]dram_para[8]:0x0 [277]dram_para[9]:0x34 [280]dram_para[10]:0x1b [282]dram_para[11]:0x33 [285]dram_para[12]:0x3 [287]dram_para[13]:0x0 [290]dram_para[14]:0x0 [292]dram_para[15]:0x4 [295]dram_para[16]:0x72 [297]dram_para[17]:0x0 [300]dram_para[18]:0x8 [302]dram_para[19]:0x0 [305]dram_para[20]:0x0 [307]dram_para[21]:0x26 [310]dram_para[22]:0x80808080 [313]dram_para[23]:0x6060606 [316]dram_para[24]:0x0 [318]dram_para[25]:0x74000000 [322]dram_para[26]:0x38000000 [325]dram_para[27]:0x802f3333 [328]dram_para[28]:0xc7c5c4c2 [331]dram_para[29]:0x3533302f [335]dram_para[30]:0xc60 [337]dram_para[31]:0x48484848 [340]board init ok [363]enable_jtag [365]card no is 0 [367]sdcard 0 line count 4 [370][mmc]: mmc driver ver 2023-03-24 16:23 [380][mmc]: Wrong media type 0x0 [383][mmc]: ***Try SD card 0*** [405][mmc]: HSSDR52/SDR25 4 bit [408][mmc]: 50000000 Hz [411][mmc]: 30436 MB [413][mmc]: ***SD/MMC 0 init OK!!!*** [425]boot param - magic error [428]DRAM BOOT DRIVE INFO: V0.67 [432]DRAM_VCC set to 1160 mv [559]DRAM retraining ten [577][AUTO DEBUG]32bit,2 ranks training success! [606]Soft Training Version: T2.0 [7410][SOFT TRAINING] CLK=1200M Stable memtest pass [7415]DRAM CLK =1200 MHZ [7418]DRAM Type =8 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [7428]DRAM SIZE =4096 MBytes, para1 = 310a, para2 = 10001000, tpr13 = 6461 [7459]DRAM simple test OK. [7462]dram size =4096 [7469]nsi init 2023-2-23 [7605]Loading boot-pkg Succeed(index=0). [7609]Entry_name = u-boot [7619]Entry_name = monitor [7623]Entry_name = scp [7626]Entry_name = dtb [7631]mmc not para [7632]Jump to second Boot. NOTICE: BL31: v2.5(debug):20a8ac62a NOTICE: BL31: Built : 17:17:28, Jan 22 2024 NOTICE: BL31: No DTB found. nsi init ok 2022-11-08 ERROR: Error initializing runtime service opteed_fast
@AurealNix download the KDE v0.2 again and I was able to write it to SD card . No issues. I am impressed, KDE loads just fine. Took a bit to load the first time. Wifi works just fine, loaded Chromium and launched Youtube. Playback is good, at the moment full screen drops frames. Audio through HDMI just worked, no issue. I also loaded the KDE image on eMMC, it did not boot. I will check what is going on use serial and report back if I see anything.
Of course. Kernel upgrade is handled via standard apt get update and upgrade. If you need to change to specific kernel, use https://docs.armbian.com/User-Guide_Armbian-Config/System/#alternative-kernels Make sure to update all packages before going that route, IIRC this problem is related to u-boot. Which is updated after all packages are up2date with armbian-install utility,
